扫一扫,分享给好友
各位大佬好,小弟在使用STC12C5A60S2的中断时遇到一点问题,我的想法是,在一个中断中用A/D轮流读取P1.0,P1.1,P1.2的值。但是我参考的例程有些问题,就是P1.1和P1.2的值都是P1.0的,应该是只读到了P1.0的值,或者没有清空P1.0。以下是我的代码,希望大佬们能帮忙看一下,谢谢!
#include "reg51.h" #include "stdio.h" #include "gsm.h" #include "intrins.h" /*Declare SFR associated with the ADC */ //STC12C5A60S2 特殊功能寄存器 关于AD部分的寄存器定义 sfr ADC_CONTR = 0xBC; //ADC控制寄存器 sfr ADC_RES = 0xBD; //ADC高8位数据寄存器(存AD转换的结果,共10位) sfr ADC_LOW2 = 0xBE; //ADC低2位数据寄存器(存AD转换的结果,共10位) sfr P1ASF = 0x9D; //P1第二功能选择寄存器 /*Define ADC operation const for ADC_CONTR*/ //ADC_CONTR寄存器的位变量定义 #define ADC_POWER 0x80 //ADC power control bit #define ADC_FLAG 0x10 //ADC complete flag #define ADC_START 0x08 //ADC start control bit #define ADC_SPEEDLL 0x00 //420 clocks #define ADC_SPEEDL 0x20 //280 clocks #define ADC_SPEEDH 0x40 //140 clocks #define ADC_SPEEDHH 0x60 //70 clocks void Delay(unsigned int n); //延时函数申明 void InitADC(); //AD初始化函数申明 unsigned int ad_out0; //10位AD数据缓存 unsigned int ad_out1; //10位AD数据缓存 unsigned int ad_out2; //10位AD数据缓存 void main() { float ad_out_tur; float ad_out_temp; float ad_out_ph; unsigned int delay; Http_Init(); InitADC(); //AD初始化 IE = 0xa0; //允许AD中断 //Start A/D conversion while (1) { EA = 0; //约间隔1秒打开AD中断,读取AD值 ad_out_tur = (ad_out0 * 5.00) / 1024; //浑浊度输出 ad_out_temp = (ad_out1 * 1.00) / 1024; //温度输出 ad_out_ph = (-5.65 * (ad_out2 * 5.00 / 1024) + 23.97); //PH输出 Http_Init(); Http_Send(ad_out_tur,ad_out_temp,ad_out_ph); //发送浑浊度、温度、PH if(delay++ > 6000) //约1秒读取一次AD值 { delay = 0; EA = 1; } } } /*---------------------------- ADC interrupt service routine ----------------------------*/ void adc_isr() interrupt 5 using 1 { ADC_CONTR &= !ADC_FLAG; //Clear ADC interrupt flag ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ADC_START | 000; ad_out0 = (ADC_RES << 2) + ADC_LOW2; //高8位+低2位 ADC_CONTR &= !ADC_FLAG; //Clear ADC interrupt flag ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ADC_START | 001; ad_out1 = (ADC_RES << 2) + ADC_LOW2; //高8位+低2位 ADC_CONTR &= !ADC_FLAG; //Clear ADC interrupt flag ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ADC_START | 010; ad_out2 = (ADC_RES << 2) + ADC_LOW2; //高8位+低2位 } /*---------------------------- Initial ADC sfr ----------------------------*/ void InitADC() { P1ASF = 0xff; //设置P1为A/D ADC_RES = 0; //Clear previous result ADC_LOW2 = 0; ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ADC_START | 000; Delay(2); //ADC power-on delay and Start A/D conversion ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ADC_START | 001; Delay(2); //ADC power-on delay and Start A/D conversion ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ADC_START | 010; Delay(2); //ADC power-on delay and Start A/D conversion } /*---------------------------- Software delay function ----------------------------*/ void Delay(unsigned int n) { unsigned int x; while (n--) { x = 5000; while (x--); } } |
4个回答
加qq1481670533解决问题
建议使用库函数版本的,获取AD很简单
每次中断只转换一个通道,分三次转换,如此反复。 /*---------------------------- Initial ADC sfr ----------------------------*/ void InitADC() { P1ASF = 0x07; //设置P1.0~1.2口为AD口 ADC_RES = 0; //清除结果寄存器高8位 ADC_LOW2= 0; //清除结果寄存器低2位 ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ADC_START | 0x00;//启动转换 Delay(2); //ADC上电并延时 } /*---------------------------- ADC interrupt service routine ----------------------------*/ void adc_isr() interrupt 5 using 1 { static unsigned char CH=0; switch(CH) { case 0: ADC_CONTR &= !ADC_FLAG; //Clear ADC interrupt flag ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ADC_START |CH; ad_out0 = (ADC_RES << 2) + ADC_LOW2; //高8位+低2位 CH++; break; case 1: ADC_CONTR &= !ADC_FLAG; //Clear ADC interrupt flag ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ADC_START |CH; ad_out1 = (ADC_RES << 2) + ADC_LOW2;//高8位+低2位 CH++; break; case 2: ADC_CONTR &= !ADC_FLAG; //Clear ADC interrupt flag ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ADC_START |CH; ad_out2 = (ADC_RES << 2) + ADC_LOW2;//高8位+低2位 CH=0; break; } } |
不错,很好的经验分享,这方面资料欠缺,非常感谢,麻烦了,谢谢。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
875 浏览 2 评论
【youyeetoo X1 windows 开发板体验】+ 影音处理和AI模型移植
730 浏览 5 评论
I.MX6ULL-飞凌 ElfBoard ELF1板卡- 移植zbar的方法
888 浏览 0 评论
1566 浏览 3 评论
由于 Windows 无法加载这个设备所需的驱动程序,导致这个设备工作异常?
2452 浏览 1 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
3773 浏览 31 评论
GMT+8, 2024-3-29 18:26 , Processed in 0.538233 second(s), Total 71, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
