回帖奖励 6 分积分 回复本帖可获得 2 分积分奖励! 每人限 5 次
[讨论] stc90c51和ad7705显示总是错的
[复制链接]
实习生
发表于 2018-1-23 13:40:25   342 查看 9 回复 显示全部楼层 倒序浏览
分享
我打算用51单片机和ad7705做一个电压采集,但是无论我读取ad7705的什么寄存器都显示255附件是原理图,下面是程序,有没有懂得人万分感谢了 还有如果将程序里main函数的int a;改成uchar a;就显示-256
#include"reg51.h"
#include"intrins.h"
#include "stdio.h"
#include"math.h"
sbit AD7705_SCLK = P2^0;
sbit AD7705_DRDY = P2^3;
sbit AD7705_DOUT = P2^2;
sbit AD7705_DIN  = P2^1;     // 通讯寄存器地址定义
#define uchar unsigned char
#define uint unsigned int
#define   WR_SETUP_REG           0x10       //选中设置寄存器,写
#define   RD_SETUP_REG           0x18       //选中设置寄存器,读
#define   WR_CLOCK_REG           0x20       //选中时钟寄存器,写
#define   RD_DATA_REG            0x38       //选中数据寄存器,读
#define   WR_OFFSET_REG          0x60       //选中offset寄存器,写
#define   RD_OFFSET_REG          0x68       //选中offset寄存器,读
#define   WR_FULL_REG            0x70       //选中full scale寄存器,写
#define   RD_FULL_REG            0x78       //选中full scale寄存器,读
#define   SYS_ZERO_CALI          0x80       //系统零校准模式
#define   SYS_FULL_CALI          0xC0       //系统满量程校准模式
#define   ZERO_CALIBRATION       0x00       //系统零校准
#define   FULL_CALIBRATION       0x01       //系统满量程校准
#define   CLOCK_REG_SET          0x04       //CLOCK寄存器设置,无分频,50HZ输出更新速率
#define   DELAY()              {_nop_();_nop_();_nop_();}
void v_DelayMs_f(unsigned int nDelay);
void v_Lcd_SendCmd_f(unsigned char byCmd);   //发送命令
void v_Lcd_SendData_f(unsigned char byData); //发送数据
void v_Lcd_Init_f(void); //初始化
void v_Lcd_SetAddress_f(unsigned char x,y); //地址转换
void v_Lcd_PutString_f(unsigned char x,unsigned char y,unsigned char *pData);
void  DelayMs(unsigned int nDelay);
sbit LCD_RS = P2^7;
sbit LCD_RW = P2^6;
sbit LCD_EN = P2^5;
sbit LCD_PSB = P3^2;
#define LCD_DATAPORT P0
#define SET_DATA  LCD_RS = 1
#define SET_INC   LCD_RS = 0
#define SET_READ  LCD_RW = 1
#define SET_WRITE LCD_RW = 0
#define SET_EN    LCD_EN = 1
#define CLR_EN    LCD_EN = 0
void  AD7705_Init(void);
void  AD7705_Reset(void);
void  AD7705_Start(void);
uchar AD7705_ReadByte(void);
void AD7705_WriteByte(uchar d);
int AD7705_ReadVol(void);
void main(void)
        int a;
        char z[16]="01231";
        AD7705_Init();
        AD7705_Start();
        a=AD7705_ReadVol();
        sprintf(z,"%d",a);
        v_Lcd_Init_f();
        v_Lcd_PutString_f(0,1,z);
void v_DelayMs_f(unsigned int nDelay) //延时
                unsigned int i ;
                for(;nDelay>0;nDelay--)
                        for(i=125;i>0;i--) ;
void v_Lcd_SendCmd_f(unsigned char byCmd)   //发送命令
                v_DelayMs_f(50);
                   SET_INC;//rs 0
                  SET_WRITE;//rw 0
                CLR_EN; //e 0
                LCD_DATAPORT=byCmd;
                  _nop_();
                  _nop_();
                SET_EN;  // e1
                _nop_();
                _nop_();
                  CLR_EN;//e 0
                SET_READ; //rw 1
                SET_INC; //rs 0
void v_Lcd_SendData_f(unsigned char byData) //发送数据
                v_DelayMs_f(50);
                SET_DATA; //rs1
                SET_WRITE; //rw0
                CLR_EN; //e0
                LCD_DATAPORT=byData ;
                _nop_();
                _nop_();
                SET_EN; //e1
                _nop_();
                _nop_();
                CLR_EN; //e0
                SET_READ; //rw1
                SET_INC; //rs0
void v_Lcd_Init_f(void) //初始化
                v_Lcd_SendCmd_f(0x30); //基本指令集
                v_DelayMs_f(50);
                v_Lcd_SendCmd_f(0x01); //清屏
                v_DelayMs_f(50);
                v_Lcd_SendCmd_f(0x06); //光标右移
                v_DelayMs_f(50);
                v_Lcd_SendCmd_f(0x0c); //开显示
void v_Lcd_SetAddress_f(unsigned char x,y) //地址转换
                unsigned char byAddress ;
                switch( y )
                        case 0 : byAddress=(0x80+x);
                        break;
                        case 1 : byAddress=(0x90+x);
                        break;
                        case 2 : byAddress=(0x88+x);
                        break;
                        case 3 : byAddress=(0x98+x);
                        break;
                        default:
                        break ;
                v_Lcd_SendCmd_f(byAddress);
                v_Lcd_SetAddress_f(x,y);
                while(*pData!='\0')
                        v_Lcd_SendData_f(*pData++);
void DelayMs(unsigned int nDelay) //延时
                unsigned int i ;
        uchar data i;
           for( i=0; i<<36; i++ )
                AD7705_SCLK = 0;
                   AD7705_DIN = 1;    // DIN端口连续写36个周期的高电平,保证复位
                   DELAY();
                  AD7705_SCLK = 0;
                   DELAY();
        DelayMs(1);             // 复位之后等待1MS
//功能:往AD7705写1个字节数据
//参数:要写入AD7705的数据
//返回:无
//备注:无
   int i;
   int temp;
   temp=0x80;
   for(i=0;i<8;i++)
   if((temp&d)==0)
      AD7705_DIN=0;
   else AD7705_DIN=1;
      AD7705_SCLK=0;
      AD7705_SCLK=1;
   temp=temp>>1;
//功能:从AD7705读一个字节的数据
//参数:无
//返回:读到的一字节数据
//备注:无
        uchar idata i, d=0;     // 读数据,高位在前
        for( i=0; i<16; i++ )
                d<<= 1;
                  AD7705_SCLK = 0;
            DELAY();
                   if(AD7705_DOUT) d++;
                   AD7705_SCLK = 1;
                  DELAY();
        return d;
//功能:先写offset寄存器,再写full scale寄存器,然后启动7705进行单次转换
//参数:
//返回:无
//备注:
        AD7705_Reset();    // 复位,防止接口迷失
        // 复位之后一定要重新设置各寄存器,复位之后默认状态为等待对通信寄存器的一次操作
        // 遵循先写命令,后写数据的原则,命令默认写到通信寄存器
        //写OFFSET寄存器
        AD7705_WriteByte(WR_OFFSET_REG);
        AD7705_WriteByte(0xFF);
        //写满量程校准寄存器
        AD7705_WriteByte(WR_FULL_REG);
          AD7705_WriteByte(WR_CLOCK_REG);  // next write to clock reg,AIN1,  0010 0000
          AD7705_WriteByte(0x00);          // CLKDIS=0,CLKDIV=0,CLK=0,FS1=0,FS2=0  0001 0000
          AD7705_WriteByte(WR_SETUP_REG);  // next write to setup reg,AIN1   0001 0000
          AD7705_WriteByte(0x04);          // 正常状态启动装换,GAIN=1,B/U=0,BUF=0,FSYNC=0,增益=1,双极性 }
        AD7705_WriteByte(0x10);          // CLKDIS=0,CLKDIV=0,CLK=0,FS1=0,FS2=0  0001 0000
                              // 外部主时钟频率为2.4576MHz
          AD7705_WriteByte(0x44);          // SELF-CAL,GAIN=1,B/U=0,BUF=0,FSYNC=0,自校准模式,增益=1,双极性
        uchar idata a=0;
           AD7705_WriteByte(RD_DATA_REG);    //READ FROM DATA REG,AIN1
        a=AD7705_ReadByte();
          return a;
本帖子中包含更多资源
您需要 登录 才可以下载或查看,没有帐号?注册
x
标签:显示 stc90c51 ad7705
高级工程师
发表于 2018-1-23 13:55:35
回帖奖励 +2 分积分
你的主程序没有循环,也就是只显示了执行一次的结果,另外可以试试显示任意数值,看看显示部分是否正确,主程序可以改成如下,看看效果如何
void main(void)
        int a;
        char z[16]="01231";
        AD7705_Init();
        AD7705_Start();
        v_Lcd_Init_f();        while(1)
               a=AD7705_ReadVol();
               sprintf(z,"%d",a);
回复
点赞 举报
实习生
发表于 2018-1-23 14:10:02    楼主|
void main(void)
按照您的程序改了一下 还是显示255这个数字不动,正常我没给输入,他数值不是应该很小么,哎................
回复
点赞 举报
实习生
发表于 2018-1-23 14:10:03    楼主|
void main(void)
回复
点赞 举报
高级工程师
发表于 2018-1-23 14:28:26
回帖奖励 +2 分积分
ADC不给输入的话有可能是任意值,也可能是固定值,可以分开测试,先测试显示部分,是否ADC范围内的任意数值都能正确显示,等显示正确了,那剩下的就是AD部分的问题了
回复
点赞 举报
实习生
发表于 2018-1-23 14:35:43    楼主|
谢谢 我刚刚试了一下,显示部分是可以显示更大的数值的,那应该是ad问题?可是我读取所有的寄存器都显示这一个数值  我应该给输入?
回复
点赞 举报
高级工程师
发表于 2018-1-23 14:42:19
没用过这款AD,对于ADC的测试,就是给ADC的输入端一个电压,这个电压最好是通过一个可调电阻,这样可以得到不同数值的电压,然后读取ADC转换后的结果,进行数据格式转换,将ADC转换的结果转换成电压值,与ADC的输入电压对比,在一定的误差范围内,就可以认为ADC调通了,再进行不同电压的转换,多次验证就可以了。
具体ADC的输入如何连接,需要看具体芯片的资料
回复
点赞 举报
实习生
发表于 2018-1-23 15:36:56    楼主|
具体ADC的 ...
谢谢  谢谢  我试一下
回复
点赞 举报
实习生
发表于 2018-1-23 16:47:55
稍微看了下楼主的问题,我用过AD7710,与这个有些类似,也碰到过类似的问题,你可以量一下DRDY信号的,当时我这面的具体解决方式是,写完寄存器之后,延迟时间等待DRDY信号变低后,选择采集电压通道,然后进行延迟,等待DRDY信号变低,但有时DRDY信号变低后采集的电压信号不对,处理方式:增加延迟时间,这个延迟时间与当时手册给出的延迟时间是有很大差距的,建议楼主采用增加延迟时间的方式处理一下,仅供参考~
回复
点赞 举报
实习生
发表于 2018-1-23 19:11:59    楼主|
gshuang12 发表于 2018-1-23 16:47
稍微看了下楼主的问题,我用过AD7710,与这个有些类似,也碰到过类似的问题,你可以量一下DRDY信号的,当时我这面的具体解决方式是,写完寄存器之后,延迟时间等待DRDY信号变低后,选择采集电压通道,然后进行延迟,等待DRDY信号变低,但有时DRDY信号变低后采集的电压信号不对,处理方式:增加延迟时间,这个延迟时间与当时 ...
谢谢谢谢
我实在是找不出来病了
回复
点赞 举报
高级模式
您需要登录后才可以回帖 登录 | 注册
关闭
站长推荐 上一条 /8 下一条
快速回复 返回顶部 返回列表
推荐专区
技术干货集中营
专家问答
用户帮助┃咨询与建议┃版主议事
工程师杂谈
工程师创意
工程师职场
论坛电子赛事
社区活动专版
发烧友活动
嵌入式论坛
ARM技术论坛
Android论坛
Linux论坛
单片机/MCU论坛
MSP430技术论坛
FPGA|CPLD|ASIC论坛
STM32/STM8技术论坛
NXP MCU 技术论坛
PIC单片机论坛
DSP论坛
瑞萨单片机论坛
嵌入式系统论坛
电源技术论坛
电源技术论坛
无线充电技术
硬件设计论坛
PCB设计论坛
电路设计论坛
电子元器件论坛
控制|传感
总线技术|接口技术
测试测量论坛
LabVIEW论坛
Matlab论坛
测试测量技术专区
仪器仪表技术专区
EDA设计论坛
multisim论坛
PADS技术论坛
Protel|AD|DXP论坛
Allegro论坛
proteus论坛|仿真论坛
EasyEDA-中国人自已的EDA工具
Orcad论坛
综合技术与应用
电机控制
智能电网
光电及显示
参考设计中心
汽车电子技术论坛
医疗电子论坛
开源硬件
无线通信论坛
无线通信技术专区
天线|RF射频|微波|雷达技术
IC设计论坛
芯片测试与失效分析
Mixed Signal/SOC[数模混合芯片设计]
Analog/RF IC设计
设计与制造封装测试
厂商专区
TI论坛
TI Deyisupport社区
检测技术与质量
电磁兼容(EMC)设计与整改
安规知识论坛
检测与认证
消费电子论坛
手机技术论坛
平板电脑/mid论坛
音视/视频/机顶盒论坛
电子论坛综合区
聚丰众筹官方社区
新人报道区
聚丰供应链
论坛服务区
供求信息发布
供需广告
招聘┃求职发布区
电子展览展会专区
