扫一扫,分享给好友
/* 在 STM32f10x_conf.h 文件中,
第72行 #define assert_param(expr) ((void)0) // expr:1:返回(void)0,expr:0:返回什么? */ #ifdef USE_FULL_ASSERT //如果定义了USE_FULL_ASSERT /** * @Brief The assert_param macro is used for function's parameters check. * @param expr: If expr is false, it calls assert_failed function which reports * the name of the source file and the source line number of the call * that failed. If expr is true, it returns no value. * @retval None */ #define assert_param(expr) ((expr) ? (void)0 : assert_failed((uint8_t *)__FILE__, __LINE__)) //定义这个宏,expr:1:返回(void)0,expr:0:调用assert_failed函数,返回源文件名,和引起错误的线号。 /* Exported functions ------------------------------------------------------- */ void assert_failed(uint8_t* file, uint32_t line); #else //否则,定义下面这个宏, #define assert_param(expr) ((void)0) // expr:1:返回(void)0,expr:0:返回什么? #endif /* USE_FULL_ASSERT */ /* 在 stm32f10x_gpio.h 文件中, 267行,是什么意思? #define IS_GPIO_EXTI_PORT_SOURCE(PORTSOURCE) (((PORTSOURCE) == GPIO_PortSourceGPIOA) || ((PORTSOURCE) == GPIO_PortSourceGPIOB) || ((PORTSOURCE) == GPIO_PortSourceGPIOC) || ((PORTSOURCE) == GPIO_PortSourceGPIOD) || ((PORTSOURCE) == GPIO_PortSourceGPIOE) || ((PORTSOURCE) == GPIO_PortSourceGPIOF) || ((PORTSOURCE) == GPIO_PortSourceGPIOG)) 后面这么多赋值,相或,是什么意思? */ /* 在 stm32f10x_gpio.h 文件中, 50--56行,是什么意思? typedef enum { EXTI_Mode_Interrupt = 0x00, //EXTI_IMR的偏移地址? EXTI_Mode_Event = 0x04 //EXTI_EMR的偏移地址? }EXTIMode_TypeDef; #define IS_EXTI_MODE(MODE) (((MODE) == EXTI_Mode_Interrupt) || ((MODE) == EXTI_Mode_Event)) //上面这句是?意思 */ /* 在 stm32f10x_exti.h 文件中, void EXTI_Init(EXTI_InitTypeDef* EXTI_InitStruct) { uint32_t tmp = 0; /* Check the parameters */ assert_param(IS_EXTI_MODE(EXTI_InitStruct->EXTI_Mode)); assert_param(IS_EXTI_TRIGGER(EXTI_InitStruct->EXTI_Trigger)); assert_param(IS_EXTI_LINE(EXTI_InitStruct->EXTI_Line)); assert_param(IS_FUNCTIONAL_STATE(EXTI_InitStruct->EXTI_LineCmd)); tmp = (uint32_t)EXTI_BASE; //tmp 取 EXTI_BASE 基地址, if (EXTI_InitStruct->EXTI_LineCmd != DISABLE) // EXTI_LineCmd 使能时, { /* Clear EXTI line configuration */ EXTI->IMR &= ~EXTI_InitStruct->EXTI_Line; //EXTI_Line0 取反,再跟 EXTI->IMR 相与,那 EXTI->IMR 岂不是被屏蔽了? EXTI->EMR &= ~EXTI_InitStruct->EXTI_Line; //EXTI_Line0 取反,再跟 EXTI->EMR 相与,那 EXTI->EMR 岂不是被屏蔽了? tmp += EXTI_InitStruct->EXTI_Mode; //tmp + 模式地址, *(__IO uint32_t *) tmp |= EXTI_InitStruct->EXTI_Line; //tmp 与上 (uint32_t)0x00001 岂不是只有0X0000 0001了? /* Clear Rising Falling edge configuration */ EXTI->RTSR &= ~EXTI_InitStruct->EXTI_Line; //EXTI->RTSR 线0的上升沿触发初岂不是被屏蔽了? EXTI->FTSR &= ~EXTI_InitStruct->EXTI_Line; //EXTI->FTSR 线0的下降沿触发初岂不是被屏蔽了? /* Select the trigger for the selected external interrupts */ if (EXTI_InitStruct->EXTI_Trigger == EXTI_Trigger_Rising_Falling) //EXTI_Trigger_Rising_Falling = 0x10 是 SWIER 的地址了? { /* Rising Falling edge */ EXTI->RTSR |= EXTI_InitStruct->EXTI_Line;//上升沿可以触发 EXTI->FTSR |= EXTI_InitStruct->EXTI_Line;//下降沿可以触发 } else //如果不是上升沿/下降沿同时触发, { tmp = (uint32_t)EXTI_BASE; //指向基地址, tmp += EXTI_InitStruct->EXTI_Trigger; //指向EXTI->RTSR地址, *(__IO uint32_t *) tmp |= EXTI_InitStruct->EXTI_Line;//使 EXTI->RTSR 写入0X0000 0001,使线0可以上升沿触发。 } } else // EXTI_LineCmd 不能时, { tmp += EXTI_InitStruct->EXTI_Mode; //EXTI_BASE 基地址+0X00,是 EXTI_IMR地址, /* Disable the selected external lines */ *(__IO uint32_t *) tmp &= ~EXTI_InitStruct->EXTI_Line; // EXTI_IMR 与上 0XFFFF FFFE,b也就是把线0的中断屏蔽了。 } } |
相关推荐 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
806 浏览 1 评论
842 浏览 0 评论
MCU友好过渡MPU,米尔基于STM32MP135开发板裸机开发应用笔记
614 浏览 0 评论
自定义系统时钟频率后,用库函数和微带两种方式点亮LED灯,为什么灯的闪烁频率不一致?
1428 浏览 2 评论
1644 浏览 2 评论
GMT+8, 2024-4-20 13:15 , Processed in 0.411252 second(s), Total 61, Slave 51 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
