发 帖
【四旋翼飞行器】76小时吃透四轴算法!史上最强软硬结合实战项目,👉戳此立抢👈
LT8711UX应用
2017-12-14 09:03:21  2481 Type-c usb HDMI LT8711UX
分享
有兴趣的朋友可以联系下
2017-12-14 09:03:21   评论 分享淘帖
8 个讨论
LT8711UX
1. Description
The LT8711UX is a high performance Type-C/DP1.2 to HDMI2.0 converter, designed to connect a USB Type-C source or a DP1.2 source to an HDMI2.0 sink.
The LT8711UX integrates a DP1.2 compliant receiver, and an HDMI2.0 compliant transmitter. Also, two CC controllers are included for CC communication to implement DP Alt Mode and power delivery function, one for upstream Type-C port and another for downstream port. On-chip USB3.0 switch is a high-speed bi-directional passive switch which provides flexible switching to accommodate connector flipping. This switch also handles muxing between 2-ch data / 2-ch video and all 4-ch video.
Two digital audio output interfaces are available, I2S and SPDIF. Both support 8-ch LPCM or compressed audio at maximum 192kHz sample rate.
The device is capable of automatic operation which is enabled by an integrated microprocessor that uses an embedded SPI flash for firmware storage. System control is also available through the use of a dedicated configuration I2C slave interface.
2. Features
• USB Type-C
• DP1.2 Receiver
• HDMI2.0 Transmitter
• Digital Audio Outputs
• Miscellaneous
3. Application
• Docking Station
• Dongle
LT8711UX
2017-12-14 09:03:46 评论
举报
LT8711UX
1. Description
2. Features
• USB Type-C
• DP1.2 Receiver
• Miscellaneous
3. Application
• Docking Station
• Dongle
2017-12-14 09:04:02 评论
举报
2017-12-14 09:04:38 评论
举报
楼主分享的东西不错
2017-12-14 10:21:30 评论
举报
LT8711H支持Type-C 转HDMI 1.4,同时支持USB3.0和PD功能;LT8711X-A支持Type-C 转VGA 和7.1 声道数字音频输出,同时支持USB3.0和PD功能;LT8712支持Type-C 转两路HDMI 1.4,一路VGA和7.1 声道数字音频输出,同时支持USB3.0和PD功能。两路HDMI 输出可同时支持4Kx2K 分辨率,并且支持多码流同时输出技术(MST)。另外一路HDMI 通道可配置成Displayport通道,实现3个不同视频格式同时输出。LT8712 是目前市场上最完美的单芯片Type-C HUB 解决方案。
      此芯片组已经量产并开始批量出货。更多的产品信息以及样片、技术支持
2017-12-15 10:39:21 评论
举报
有需求可以联系下
游生18105995017
QQ2840038952
看了之后涨了很多知识
2017-12-18 16:36:05 评论
举报
供货周期短,价格优势大,提供高效技术支持
2018-7-30 17:27:45 评论
举报
我司是一级代理商,可提供代理证+芯片规格书+参考设计+技术支持,欢迎来电索取资料,游生18105995017 QQ:2840038952 价格美丽
2018-11-7 09:46:17 评论
举报
只有小组成员才能发言,加入小组>>
16个成员聚集在这个小组
加入小组
创建小组步骤
关闭
站长推荐 上一条 /7 下一条
快速回复 返回顶部 返回列表
