`main() { InitSysCtrl() EALLOW; #if (CPU_FRQ_150MHZ) // Default - 150 MHz SYSCLKOUT #define ADC_MODCLK 0x3 // HSPCLK = SYSCLKOUT/2*ADC_MODCLK2 = 150/(2*3) = 25.0 MHz #endif #if (CPU_FRQ_100MHZ) #define ADC_MODCLK 0x2 // HSPCLK = SYSCLKOUT/2*ADC_MODCLK2 = 100/(2*2) = 25.0 MHz #endif EDIS; EALLOW; SysCtrlRegs.HISPCP.all = ADC_MODCLK; EDIS; DINT; InitPieCtrl(); // Disable CPU interrupts and clear all CPU interrupt flags: IER = 0x0000; IFR = 0x0000; InitPieVectTable(); EALLOW; // This is needed to write to EALLOW protected register PieVectTable.ADCINT = &adc_isr; EDIS; // This is needed to disable write to EALLOW protected registers InitAdc(); // For this example, init the ADC // Step 5. User specific code, enable interrupts: // Enable ADCINT in PIE PieCtrlRegs.PIEIER1.bit.INTx6 = 1; IER |= M_INT1; // Enable CPU Interrupt 1 EINT; // Enable Global interrupt INTM ERTM; // Enable Global realtime interrupt DBGM LoopCount = 0; ConversionCount = 0; // Configure ADC AdcRegs.ADCTRL1.bit.CPS=1; //二分频 AdcRegs.ADCTRL3.bit.ADCCLKPS=1; //分频 ADCCLK=6MHz AdcRegs.ADCTRL1.bit.ACQ_PS=4; //采样时间宽度为5个ADCCLK AdcRegs.ADCTRL1.bit.SEQ_CASC=1; //级联模式 AdcRegs.ADCMAXCONV.all = 0x0001; // Setup 2 conv's on SEQ1 AdcRegs.ADCCHSELSEQ1.bit.CONV00 = 0x2; // Setup ADCINA3 as 1st SEQ1 conv. AdcRegs.ADCCHSELSEQ1.bit.CONV01 = 0x3; // Setup ADCINA2 as 2nd SEQ1 conv. AdcRegs.ADCTRL2.bit.EPWM_SOCA_SEQ1 = 1;// Enable SOCA from ePWM to start SEQ1 AdcRegs.ADCTRL2.bit.INT_ENA_SEQ1 = 1; // Enable SEQ1 interrupt (every EOS) // Assumes ePWM1 clock is already enabled in InitSysCtrl(); EPwm1Regs.ETSEL.bit.SOCAEN = 1; // Enable SOC on A group EPwm1Regs.ETSEL.bit.SOCASEL = 4; // Select SOC from from CPMA on upcount EPwm1Regs.ETPS.bit.SOCAPRD = 1; // Generate pulse on 1st event EPwm1Regs.TBCTL.bit.HSPCLKDIV=1; EPwm1Regs.TBCTL.bit.CLKDIV=0; EPwm1Regs.CMPA.half.CMPA = EPwm1Regs.TBPRD /2; // Set compare A value EPwm1Regs.TBPRD = 49999; // Set period for ePWM1 EPwm1Regs.TBCTL.bit.CTRMODE = 0; // count up and start // Wait for ADC interrupt for(;;) { LoopCount++; } } interrupt void adc_isr(void) { Voltage1[ConversionCount] = AdcRegs.ADCRESULT0 >>4; Voltage2[ConversionCount] = AdcRegs.ADCRESULT1 >>4; // If 40 conversions have been logged, start over if(ConversionCount == 9) { ConversionCount = 0; } else ConversionCount++; // Reinitialize for next ADC sequence AdcRegs.ADCTRL2.bit.RST_SEQ1 = 1; // Reset SEQ1 AdcRegs.ADCST.bit.INT_SEQ1_CLR = 1; // Clear INT SEQ1 bit PieCtrlRegs.PIEACK.all = PIEACK_GROUP1; // Acknowledge interrupt to PIE return; } 参照ADC_soc实例程序改的。我可以正常进入中断程序,但是ADCRESULT0和ADCRESULT1的值总是没有变化。 求大神帮帮忙看看。困扰我1个星期了! ` |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
嵌入式操作教程_数字信号处理_音频编解码:3-6 AAC音频解码实验
441 浏览 0 评论
数字信号处理实验操作教程:3-3 mp3音频编码实验(AD7606采集)
1333 浏览 0 评论
嵌入式DSP教学实验箱操作教程:2-20 数模转换实验(模拟SPI总线输出电压值)
1377 浏览 0 评论
目前在2837x系列用的最多的、性能最好、性价比最高的是哪一款?
1138 浏览 0 评论
国产嵌入式DSP教学实验箱_操作教程:22-AD采集DA输出实验(采集输出正弦波)
2329 浏览 0 评论
GMT+8, 2024-4-24 22:08 , Processed in 0.559919 second(s), Total 71, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
