FSQ26,二手26G信号分析仪,二手FSQ26 FSQ26,二手26G信号分析仪,二手FSQ26
20Hz至26.5GHz。
FSQ不仅继承了FSU的出色的频谱分析仪特性和功能,而且其解调和分析带宽可高达120MHz,还提供了基站频谱杂散发射和多载波测量所必需的高动态范围。因此,FSQ是进行下列产品开发和生产的理想工具:WLAN、WiMAX、WCDMA、HSPA/HSPA+、GSM/EDGE/GPRS、CDMA2000/1x EV-DO、TD-SCDMA、LTE TDD/LTE FDD、Bluetooth等。
为了解决日益增加的数据吞吐量问题,未来移动无线和相关领域对带宽的要求必然越来越高。即使今天,GSM或3GPP基站的多载波信号在功率输出阶段常常需要进行放大,尽管这样一方面可以降低技术要求和成本,但同时也增加了传输带宽。随着分析带宽要求的提高,现有频谱分析仪产品已经难于满足分析要求,市场需要具有更高分析带宽的产品,而同时满足动态范围的苛刻要求。
R&S®FSQ不仅继承了R&S®FSU的出色的频谱分析仪特性和功能,而且其解调和分析带宽可高达120MHz。因此,R&S®FSQ是进行下列产品开发和生产的理想工具:
FSQ26,二手26G信号分析仪,二手FSQ26 FSQ26,二手26G信号分析仪,二手FSQ26 FSQ26,二手26G信号分析仪,二手FSQ26 FSQ26,二手26G信号分析仪,二手FSQ26
•WLAN
•3GPP和 GSM-MCPA
•WiMAX
除此之外,当与下列应用选件一起工作时,R&S® FSQ26还能支持2G、2.5G、3G以及4G移动无线系统的测量应用:
GSM/EDGE Application Firmware | R&S®FS-K5 |
AM/FM/PM Measurement Demodulator
for R&S®FSQ/FSU/FSP/FSUP Analyzers and the R&S®ESCI/ESPI Test Receivers | R&S®FS-K7 |
Bluetooth® Application Firmware | R&S®FS-K8 |
Power Sensor Measurements | R&S®FS-K9 |
GSM/EDGE/EDGE Evolution Measurements | R&S®FS-K10 |
VOR/ILS Measurement Demodulator
for R&S®FSMR/R&S®FSU/R&S®FSQ - Analysis for VOR and ILS signals | R&S®FS-K15 |
Application Firmware for Noise Figure and Gain Measurements for R&S®FSP, R&S®FSU and R&S®FSQ (preamplifier recommended, e.g. R&S®FSU-B25)
Outperforming any conventional noise measurement system | R&S®FS-K30 |
Application Firmware for phase noise measurements | R&S®FS-K40 |
Firmware General Purpose Vector Signal Analyzer
Universal demodulation, analysis and documentation of digital radio signals
This option is available for instruments for:
R&S®FSUP8: as of serial number 100024
R&S®FSUP26: as of serial number 100068
R&S®FSUP50: as of serial number 100013 | R&S®FSQ-K70 |
3GPP BTS/Node B FDD Application Firmware
3GPP transmitter measurements with R&S®FSQ signal analyzers and R&S®FSU, R&S®FSG, R&S®FSUP, R&S®FSMR, R&S®FMU and R&S®FSP spectrum analyzers | R&S®FS-K72 |
3GPP UE FDD Application Firmware (including HSUPA)
3GPP transmitter measurements with R&S®FSQ signal analyzers and R&S®FSU, R&S®FSG, R&S®FSUP, R&S®FSMR, R&S®FMU and R&S®FSP spectrum analyzers | R&S®FS-K73 |
3GPP HSPA+ UE Application Firmware
3GPP transmitter measurements with R&S®FSQ signal analyzers and R&S®FSU, R&S®FSG and R&S®FSP spectrum analyzers.
Requires R&S®FS-K73 | R&S®FS-K73+ |
3GPP HSDPA Base Transceiver Station (BTS) Application Firmware
3GPP transmitter measurements with R&S®FSQ signal analyzers and R&S®FSU, R&S®FSG, R&S®FSUP, R&S®FSMR, R&S®FMU and R&S®FSP spectrum analyzers.
Requires R&S®FS-K72 | R&S®FS-K74 |
3GPP HSPA+ BTS Application Firmware
Requires R&S®FS-K74 | R&S®FS-K74+ |
3GPP TD-SCDMA BTS Application Firmware
Base station and mobile station tests on TD-SCDMA with the R&S®FSQ, R&S®FSU and R&S®FSP | R&S®FS-K76 |
3GPP TD-SCDMA Mobile Station (MS) Application Firmware
Base station and mobile station tests on TD-SCDMA with the R&S®FSQ, R&S®FSU and R&S®FSP | R&S®FS-K77 |
CDMA2000® / IS-95 (cdmaOne) / 1xEV-DV BTS Test Application Firmware | R&S®FS-K82 |
CDMA2000® /1xEV-DV MS Application Firmware | R&S®FS-K83 |
CDMA2000® 1xEV-DO Base Station Test Application Firmware (including Rev A)
Transmitter measurement on 3GPP2 signals with Signal Analyzer R&S®FSQ and Spectrum Analyzers R&S®FSU and R&S®FSP | R&S®FS-K84 |
CDMA2000® 1xEV-DO Mobile Station Test Application Firmware
Transmitter measurement on 3GPP2 signals with Signal Analyzer R&S®FSQ and Spectrum Analyzers R&S®FSU and R&S®FSP | R&S®FS-K85 |
WLAN 802.11a/b/g/j Application Firmware | R&S®FSQ-K90 |
WLAN Application Firmware
WLAN IEEE 802.11 a/b/g/j TX Application Firmware | R&S®FSQ-K91 |
R&S®FSQ-K91 Upgrade to IEEE 802.11n | R&S®FSQ-K91n |
TX measurements on OFDM signals in line with IEEE 802.16-2004 | R&S®FSQ-K92 |
R&S®FSQ-K92 to R&S®FSQ-K93 Upgrade
(R&S®FSQ-K92 required) | R&S®FSQ-K92U |
TX measurements on OFDMA signals in line with IEEE 802.16-2004, IEEE 802.16e-2005 | R&S®FSQ-K93 |
TX measurements on WiMAXTM MIMO signals in line with IEEE 802.16e-2005 | R&S®FSQ-K94 |
Analysis of EUTRA/LTE FDD downlink signals
3GPP LTE transmitter measurements on base stations and modules with the R&S®FSG and R&S®FSQ Signal Analyzer | R&S®FSQ-K100 |
Analysis of EUTRA/LTE FDD uplink signals
3GPP LTE transmitter measurements on user equipment and modules with the R&S®FSG and R&S®FSQ Signal Analyzer | R&S®FSQ-K101 |
Analysis of EUTRA/LTE downlink MIMO signals
(requires R&S®FSQ-K100) | R&S®FSQ-K102 |
Analysis of EUTRA/LTE TDD downlink signals
Transmitter measurements on LTE signals | R&S®FSQ-K104 |
Analysis of EUTRA/LTE TDD uplink signals
Transmitter measurements on LTE signals | R&S®FSQ-K105 |
TETRA Release 2 Analysis
TETRA/TEDS measurements for the R&S®FSU / R&S®FSQ | R&S®FS-K110 |
另外,随着今后对分析带宽要求的提高,还可以将¸FSQ的I/Q解调带宽扩展至120 MHz。
只要您来电咨询,我们就会根据您的需求而来给您回复一个完美的价格!您可以拿我们的价格去与别家商家对比,您在挑选仪器的时候“价比三家”“货比三家”“质比三家”最后您能得到最好的!
另出售:
频谱分析仪: 8590E,8591E,8593E,8594E,8595E,8596E,8560E,8561E,8562E,8563E,8564E,8565E,E4401B,E4402B,E4403B,E4404B,
E4405B,E4407B,E4408B,E4407B,E4440A,E4411B,E4443A,E4445A,E4446A,E4447A,E4448A,8560EC,8591EC,8562EC,8563EC,8564EC,
8565EC,R3131A,R3132,R3162,R3463,R3465,R3265A,MT8801B,MT8801C,FSP3,FSP7,FSP13,FSP30,FSP40.FSL3,FSU8
二手示波器:泰克TDS220,TDS210,TDS1001,TDS1002,TDS1012B,TDS2102B,TDS2024B,TDS3012B,TDS3014B,TDS3032B,TDS3034B,
TDS3052B,TDS3054B,TDS7104B,CSA7404,TDS7404,TDS7054,TDS784,TDS794,TDS520,TDS620,TDS640A,TDS684,TDS694,
安捷伦54825A,54845A,54833,54642,54852,54853,MSO6012A,MSO6102A,DSO8064A,DSO81004A,DSO81204A,DSO81304A
二手信号发生器:安捷伦E4432B,E4421B,E4433B,E4432A,E8267C,E8267D,E4420A,E4420B,E4421A,E4422A,E4422B,E8257D,
E4428C,E5181A,8664A,8665B,8648A,8648C,8656A,8647A,N9310A,N5182A,8648B,8648D,8643A,8643B,7664A,8665A,8665B,
8662A,8663A,8663B,83751A,83751B,美国埃法玛可尼IFR2023B,IFR2025B,IFR2024,罗德与施瓦茨SMIQ03B,SMIQ02,SMIQ03,
SMT02,SMT03,SMT06,SME02,SME03,SME03E,SME06,SML01,SML02,SML03,SMY01,SMY02,MG3633A,MG3641A,MG3642A,MG3681A.
手机综合测试仪:8960,E5515A,E5515B,E5515C,CMU200,CMD55,E8285A,6392A,6392B
综合测试仪:CMD55,CTS55,CMS50,CMS52,CMS54,CMD60,CMD65,CMD80,8920A,8920B,8921A.MT8801B,MT8801C,MT8802A,8922M,HP8922,
HP8922G,8922G
WIFI测试仪:IQVIEW,IQFLEX,IQNXN,N4010A
蓝牙测试仪:MT8850A,MT8852A,MT8852B,E1852B,IQVIEW,IQFLEX,N4010A
信号分析仪:E4406A,N9010A,N9020A,N9030A,SMIQ03 ,SME03
音频分析仪:ATS-1,ATS-2,SYS2722,SYS2322,VP-7723D,VP-7727D,VP-7723A
EMI接收机:ESVS10,ESHS10,ESHS30,ESVD,ESVB,ESCS
电源:66311B,66319B,2303,2306,66309D,E3644A,66312A
尽管有些事情是不可能提前预知,我们需要做的工作仅有一项:销售产品和服务。我司销售的二手仪器,以低价的成本为客户提供更大的利润空间,以优质的服务赢得我们的客户市场,赢得客户对我们公司长期的信任。公司新到一批成色好的仪器,包括无线测试、频谱分析仪、网络分析仪、频率计、数字万用表,价格和成色的优势值得你拥有!
深圳市迈凯瑞仪器仪表有限公司
深圳市龙华新区东环一路天汇大厦D栋6楼D-615室
段青:13622377874
电话:0755-83598906-805
传真:0755-23595225
QQ:3288284852
深圳市迈凯瑞仪器仪表有限公司,欢迎您的来电。
