我做的4*4矩阵按键,每次按键按下显示一个数字,0~F显示,数码管依次显示出按键按下的数值,但是为什么按键一按下,单片机就停止工作了呢?能不能按键按下单片机继续工作,松开后再返回数值?这是程序,求大神解答
#include ***it P3_0 = P3^0; code unsigned char seven_seg[] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};//数码管数字数组 code unsigned char key_scan[] = {0xef,0xdf,0xbf,0x7f};//让按键列线依次出现出现低电平,共需要4个扫描数据 code unsigned char key_num[] = { 0xee,0xed,0xeb,0xe7, //0 1 2 3 0xde,0xdd,0xdb,0xd7, //4 5 6 7 0xbe,0xbd,0xbb,0xb7, //8 9 10 11 0x7e,0x7d,0x7b,0x77 // 12 13 14 15 }; //按键按下的键值 code unsigned char led_num[] = { 0xe1,0xe2,0xe4,0xe8, //0 1 2 3 0xd1,0xd2,0xd4,0xd8, //4 5 6 7 0xb1,0xb2,0xb4,0xb8, //8 9 10 11 0x71,0x72,0x74,0x78 // 12 13 14 15 }; //按键按下的灯值 unsigned char XH[10]; unsigned char cp,cp1; void delay(unsigned int x) //延时函数 { while(x--); } void display(unsigned char xs) //显示函数 { P0 = 0xff; switch(cp) { case 0: P3_0 = 0;P3_0 = 1;P0 = 0x01;P3_0 = 0;P0 = seven_seg[xs];break; case 1: P3_0 = 0;P3_0 = 1;P0 = 0x02;P3_0 = 0;P0 = 0xbf;break; case 2: P3_0 = 0;P3_0 = 1;P0 = 0x04;P3_0 = 0;P0 = seven_seg[XH[1]];break; case 3: P3_0 = 0;P3_0 = 1;P0 = 0x08;P3_0 = 0;P0 = seven_seg[XH[2]];break; case 4: P3_0 = 0;P3_0 = 1;P0 = 0x10;P3_0 = 0;P0 = seven_seg[XH[3]];break; case 5: P3_0 = 0;P3_0 = 1;P0 = 0x20;P3_0 = 0;P0 = seven_seg[XH[4]];break; case 6: P3_0 = 0;P3_0 = 1;P0 = 0x40;P3_0 = 0;P0 = 0xbf;break; case 7: P3_0 = 0;P3_0 = 1;P0 = 0x80;P3_0 = 0;P0 = seven_seg[cp1];break; } cp++; if(cp >= 8) cp = 0; } unsigned char key(void) //按键函数 { unsigned char i,j; for(i = 0;i < 4;i++) { P2 = key_scan[i]; if(P2 != key_scan[i]) { delay(300); //消除按键抖动,有按键确实按下 if(P2 != key_scan[i]) //如果有按键按下,P2口不是原来扫描数据 for(j = 0;j < 16;j++) //让键盘行线输出扫描数据 { if(P2 == key_num[j]) { while(P2 == key_num[j]) ; cp1++; //4个显示的数的数组 if(cp1 >= 4) cp1 = 4; XH[cp1] = j; return(j); } } } } return(6); } void main(void) //主函数 { unsigned char k; //定义一个变量k while(1) { k = key(); //把扫描的值赋值给k display(k); //显示k P1 = led_num[k]; } } |
15个回答
大家好,我是菜鸟
给你一个简单易懂的矩阵键盘程序试试,消抖、自锁、不会死。
unsigned char key(void) //按键函数 { unsigned char temp1,temp2,temp3; //临时变量 static bit sign=0; //按键自锁标志 static unsigned char count=0; //消抖计数变量 P2=0xf0; //先给P2赋一个初值 if(P2!=0xf0) //判断P2不等于所赋初值,说明有健按下 { if(sign==0) //如果按键自锁标志为0 { count++; //消抖计数 if(count>=100) //消抖计数自>=100,估算主循环周期调整 { //摒弃Delay延时方式, count=100; //防止溢出 sign=1; //按键自锁标志置1,键不抬起,按其他键无效 temp1=P2; //temp1保存高4位变化 P2=0x0f; //再给P2赋值0x0f temp2=P2; //temp2保存低4位变化 temp3=temp2|temp1; //temp3=高4位+低4位 return temp3; //返回键值 } } } else //按键抬起 { sign=0; //按键自锁标志清0 count=0; //消抖计数清0 } } 评分
主要是你的按键检测代码逻辑问题,你设置了松手后才能继续往下执行,给你的感觉当然是单片机不工作了。其实单片机还在工作,只不过做的事情效率太低了。 至于解决办法,就让其他人来帮你把
评分
嗯嗯,谢谢了 |
HARRY007 发表于 2017-7-20 13:11 嗯嗯,我再好好改改 |
unsigned char key(void) //按键函数 你的这个函数里面,问题很大 |
你的按键扫描程序中没有返回函数,所以你的程序执行逻辑错误哦!你试着把按键扫面部分加一个返回函数!
恩恩,谢啦,现在已经成功了 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
【每周推荐】采用11代Intel CPU,基于youyeetoo X1开发板搭建少儿AI智能STEAM积木平台
788 浏览 0 评论
2275 浏览 2 评论
【youyeetoo X1 windows 开发板体验】+ 影音处理和AI模型移植
2141 浏览 5 评论
I.MX6ULL-飞凌 ElfBoard ELF1板卡- 移植zbar的方法
1682 浏览 0 评论
2930 浏览 3 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
5539 浏览 31 评论
GMT+8, 2024-4-20 07:44 , Processed in 0.574630 second(s), Total 58, Slave 49 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
