const u8 TX_ADDRESS[TX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //发送地址 const u8 RX_ADDRESS[RX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //初始化24L01的IO口 void NRF24L01_Init(void) { GPIO_InitTypeDef GPIO_InitStructure; SPI_InitTypeDef SPI_InitStructure; //使能PB,F,D端口时钟 //PF8-CE PF9-CSN PD3-IRQ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOF|RCC_APB2Periph_GPIOD, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13; //PG13上拉 防止EN25X的干扰 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOG, &GPIO_InitStructure); //初始化指定IO GPIO_SetBits(GPIOG,GPIO_Pin_13);//上拉 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12; //PB12上拉 防止以太网NSS的干扰 GPIO_Init(GPIOB, &GPIO_InitStructure); //初始化指定IO GPIO_SetBits(GPIOB,GPIO_Pin_12);//上拉 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9|GPIO_Pin_8; //PF8 9 推挽 GPIO_Init(GPIOF, &GPIO_InitStructure);//初始化指定IO GPIO_ResetBits(GPIOF,GPIO_Pin_9|GPIO_Pin_8);//PF6,7,8下拉 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD; //PD3 输入 GPIO_Init(GPIOD, &GPIO_InitStructure); GPIO_ResetBits(GPIOD,GPIO_Pin_3);//PD3下拉 SPI2_Init(); //初始化SPI SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; //SPI设置为双线双向全双工 SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //SPI主机 SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //发送接收8位帧结构 SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low; //时钟悬空低 SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge; //数据捕获于第1个时钟沿 SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //NSS信号由软件控制 SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_32; //定义波特率预分频的值:波特率预分频值为16 SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //数据传输从MSB位开始 SPI_InitStructure.SPI_CRCPolynomial = 7; //CRC值计算的多项式 SPI_Init(SPI2, &SPI_InitStructure); //根据SPI_InitStruct中指定的参数初始化外设SPIx寄存器 SPI_Cmd(SPI2, ENABLE); //使能SPI外设 NRF24L01_CE=0; //使能24L01 NRF24L01_CSN=1; //SPI片选取消 } //SPI写寄存器 //reg:指定寄存器地址 //value:写入的值 u8 NRF24L01_Write_Reg(u8 reg,u8 value) { u8 status; NRF24L01_CSN=0; //使能SPI传输 status =SPI2_ReadWriteByte(reg);//发送寄存器号 SPI2_ReadWriteByte(value); //写入寄存器的值 NRF24L01_CSN=1; //禁止SPI传输 return(status); //返回状态值 } //读取SPI寄存器值 //reg:要读的寄存器 u8 NRF24L01_Read_Reg(u8 reg) { u8 reg_val; NRF24L01_CSN = 0; //使能SPI传输 SPI2_ReadWriteByte(reg); //发送寄存器号 reg_val=SPI2_ReadWriteByte(0XFF);//读取寄存器内容 NRF24L01_CSN = 1; //禁止SPI传输 return(reg_val); //返回状态值 } //在指定位置读出指定长度的数据 //reg:寄存器(位置) //*pBuf:数据指针 //len:数据长度 //返回值,此次读到的状态寄存器值 u8 NRF24L01_Read_Buf(u8 reg,u8 *pBuf,u8 len) { u8 status,u8_ctr; NRF24L01_CSN = 0; //使能SPI传输 status=SPI2_ReadWriteByte(reg);//发送寄存器值(位置),并读取状态值 for(u8_ctr=0;u8_ctr
NRF24L01_CSN=1; //关闭SPI传输 return status; //返回读到的状态值 } //在指定位置写指定长度的数据 //reg:寄存器(位置) //*pBuf:数据指针 //len:数据长度 //返回值,此次读到的状态寄存器值 u8 NRF24L01_Write_Buf(u8 reg, u8 *pBuf, u8 len) { u8 status,u8_ctr; NRF24L01_CSN = 0; //使能SPI传输 status = SPI2_ReadWriteByte(reg);//发送寄存器值(位置),并读取状态值 for(u8_ctr=0; u8_ctr
NRF24L01_CSN = 1; //关闭SPI传输 return status; //返回读到的状态值 } //启动NRF24L01发送一次数据 //txbuf:待发送数据首地址 //返回值:发送完成状况 u8 NRF24L01_TxPacket(u8 *txbuf) { u8 sta; SPI2_SetSpeed(SPI_BaudRatePrescaler_32);//spi速度为9Mhz(24L01的最大SPI时钟为10Mhz) NRF24L01_CE=0; NRF24L01_Write_Buf(WR_TX_PLOAD,txbuf,TX_PLOAD_WIDTH);//写数据到TX BUF 32个字节 NRF24L01_CE=1;//启动发送 delay_ns(20); while(NRF24L01_IRQ!=0);//等待发送完成 sta=NRF24L01_Read_Reg(STATUS); //读取状态寄存器的值 NRF24L01_Write_Reg(NRF_WRITE_REG+STATUS,sta); //清除TX_DS或MAX_RT中断标志 if(sta&MAX_TX)//达到最大重发次数 { NRF24L01_Write_Reg(FLUSH_TX,0xff);//清除TX FIFO寄存器 return MAX_TX; } if(sta&TX_OK)//发送完成 { return TX_OK; } return 0xff;//其他原因发送失败 } //启动NRF24L01发送一次数据 //txbuf:待发送数据首地址 //返回值:0,接收完成;其他,错误代码 u8 NRF24L01_RxPacket(u8 *rxbuf) { u8 sta; SPI2_SetSpeed(SPI_BaudRatePrescaler_32); //spi速度为9Mhz(24L01的最大SPI时钟为10Mhz) sta=NRF24L01_Read_Reg(STATUS); //读取状态寄存器的值 NRF24L01_Write_Reg(NRF_WRITE_REG+STATUS,sta); //清除TX_DS或MAX_RT中断标志 if(sta&RX_OK)//接收到数据 { NRF24L01_Read_Buf(RD_RX_PLOAD,rxbuf,RX_PLOAD_WIDTH);//读取数据 NRF24L01_Write_Reg(FLUSH_RX,0xff);//清除RX FIFO寄存器 return 0; } return 1;//没收到任何数据 } //该函数初始化NRF24L01到RX模式 //设置RX地址,写RX数据宽度,选择RF频道,波特率和LNA HCURR //当CE变高后,即进入RX模式,并可以接收数据了 void NRF24L01_RX_Mode(void) { NRF24L01_CE=0; NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P0,(u8*)RX_ADDRESS,RX_ADR_WIDTH);//写RX节点地址 NRF24L01_Write_Reg(NRF_WRITE_REG+EN_AA,0x01); //使能通道0的自动应答 NRF24L01_Write_Reg(NRF_WRITE_REG+EN_RXADDR,0x01);//使能通道0的接收地址 NRF24L01_Write_Reg(NRF_WRITE_REG+RF_CH,40); //设置RF通信频率 NRF24L01_Write_Reg(NRF_WRITE_REG+RX_PW_P0,RX_PLOAD_WIDTH);//选择通道0的有效数据宽度 NRF24L01_Write_Reg(NRF_WRITE_REG+RF_SETUP,0x0f);//设置TX发射参数,0db增益,2Mbps,低噪声增益开启 NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG, 0x0f);//配置基本工作模式的参数;PWR_UP,EN_CRC,16BIT_CRC,接收模式 NRF24L01_CE = 1; //CE为高,进入接收模式 } //该函数初始化NRF24L01到TX模式 //设置TX地址,写TX数据宽度,设置RX自动应答的地址,填充TX发送数据,选择RF频道,波特率和LNA HCURR //PWR_UP,CRC使能 //当CE变高后,即进入RX模式,并可以接收数据了 //CE为高大于10us,则启动发送. void NRF24L01_TX_Mode(void) { NRF24L01_CE=0; NRF24L01_Write_Buf(NRF_WRITE_REG+TX_ADDR,(u8*)TX_ADDRESS,TX_ADR_WIDTH);//写TX节点地址 NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P0,(u8*)RX_ADDRESS,RX_ADR_WIDTH); //设置TX节点地址,主要为了使能ACK NRF24L01_Write_Reg(NRF_WRITE_REG+EN_AA,0x01); //使能通道0的自动应答 NRF24L01_Write_Reg(NRF_WRITE_REG+EN_RXADDR,0x01); //使能通道0的接收地址 NRF24L01_Write_Reg(NRF_WRITE_REG+SETUP_RETR,0x1a);//设置自动重发间隔时间:500us + 86us;最大自动重发次数:10次 NRF24L01_Write_Reg(NRF_WRITE_REG+RF_CH,40); //设置RF通道为40 NRF24L01_Write_Reg(NRF_WRITE_REG+RF_SETUP,0x0f); //设置TX发射参数,0db增益,2Mbps,低噪声增益开启 NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG,0x0e); //配置基本工作模式的参数;PWR_UP,EN_CRC,16BIT_CRC,接收模式,开启所有中断 NRF24L01_CE=1;//CE为高,10us后启动发送 delay_ns(15); } |
5个回答
解决了,更改参数就可以了,传输数据是正确的。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
337 浏览 0 评论
【每周推荐】采用11代Intel CPU,基于youyeetoo X1开发板搭建少儿AI智能STEAM积木平台
838 浏览 0 评论
2384 浏览 2 评论
【youyeetoo X1 windows 开发板体验】+ 影音处理和AI模型移植
2237 浏览 5 评论
I.MX6ULL-飞凌 ElfBoard ELF1板卡- 移植zbar的方法
1694 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
5763 浏览 31 评论
GMT+8, 2024-4-24 14:03 , Processed in 0.621307 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
