书接上回:https://bbs.elecfans.com/forum.php?mod=viewthread&tid=1135193
自从拿到这个板子,无线无法查找到。加入群后。得知有最新固件,烧录后还是一样,无法通过app扫描到。登录系统后进入一个工程模式:
<<$ welcome to the PRODUCT TEST mode !!when the device don't set dsn, system will switch to the mode cmmand list: help # show the text set < opt > [ val ] # opt list: -h # show set cmd help text -dsn val # set the dsn with val get < opt > [ val ] # opt list: -h # show get cmd help text -dsn # get the value of dsn reboot # the command for reboot the linux system quit/Q/q # quit the product test mode
^H <<$ : Command not found >>$ ? <<$ ?: Command not found
经过各种尝试后。都无法解决。。。之后询问厂家,才知道要设置dsn码。好吧。设置一下:
>>$ set -dsn 2342423 <<$ OK >>$reboot 按照提示执行过。果然可以进入正常op系统,如下: root@OpenWrt:/# ifconfig br-lan Link encap:Ethernet HWaddr B2:FB:3C:84:F4:8C inet addr:192.168.230.1 Bcast:192.168.230.255 Mask:255.255.255.0 inet6 addr: fe80::b0fb:3cff:fe84:f48c/64 Scope:Link inet6 addr: fd8b:b8cf:9360::1/60 Scope:Global UP BROADCAST RUNNING MUL tiCAST 终于过了设置这关,接下来继续前进~~
