扫一扫,分享给好友
stm32新人,在做按键控制简单多波形切换,然后发现无论怎样初始一直默认正弦,如果切换三角波需按两下。
程序代码如下 #include "dac.h" //#include "key.h" //#include "SysTick.h" //#define DAC_DHR12R1_ADDRESS 0x40007408 #define DAC_DHR12RD_Address 0x40007420 //0x40007420 uint32_t DualSine12bit[32]; // 波形数据 -正弦波-------// const uint16_t Sine12bit[32] = { 2047, 2447, 2831, 3185, 3498, 3750, 3939, 4056, 4095, 4056, 3939, 3750, 3495, 3185, 2831, 2447, 2047, 1647, 1263, 909, 599, 344, 155, 38, 0, 38, 155, 344, 599, 909, 1263, 1647 }; // 波形数据 -三角波-------// const uint16_t Triangle12bit[32] = { 0,250,500,750,1000,1250,1500,1750, 2000,2250,2500,2750,3000,3250,3500,3750, 4000,3750,3500,3250,3000,2750,2500,2250, 2000,1750,1500,1250,1000,750,500,250 }; // 波形数据 -锯齿波-------// const uint16_t Sawtooth12bit[32] = { 0,100,200,300,400,500,600,700, 800,900,1000,1100,1200,1300,1400,1500, 1600, 1700,1800,1900,2000,2100,2200, 2300,2400,2500,2600,2700,2800,2900,3000,3100 }; // 波形数据 -PWM波-------// const uint16_t Pwm12bit[32] = { 0,0,0,0,0,0,0,0, 0,0,0,0,0,0,0,0, 4095, 4095,4095,4095,4095,4095,4095,4095, 4095, 4095,4095,4095,4095,4095,4095,4095 }; // 波形数据 -梯形波-------// const uint16_t Trapezoidal12bit[32] = { 0,0,0,0,0,0,300,600, 900,1200,1500,1800,2100,2400,2700,3000, 3000,3000,3000,3000,3000,3000,3000,2700, 2400,2100,1800,1500,1200,900,600,300, }; /******************************************************************************* * 函 数 名 : DAC1_Init * 函数功能 : DAC1初始化函数 * 输 入 : 无 * 输 出 : 无 *******************************************************************************/ void TIM6_Configuration(void) { RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM6, ENABLE); TIM_PrescalerConfig(TIM6, 83, TIM_PSCReloadMode_Update); TIM_SetAutoreload(TIM6, 4); TIM_SelectOutputTrigger(TIM6, TIM_TRGOSource_Update); TIM_Cmd(TIM6, ENABLE); } void GPIO_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN; GPIO_Init(GPIOA, &GPIO_InitStructure); } void DAC_DMA_Configuration(void) { DAC_InitTypeDef DAC_InitStructure; DMA_InitTypeDef DMA_InitStructure; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1, ENABLE);//使能DMA时钟 RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);//使能DAC时钟 DAC_InitStructure.DAC_Trigger = DAC_Trigger_T6_TRGO;//选择TIM6触发 DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;//是否使用DAC波形发生 DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Disable;//不使用输出缓冲 DAC_Init(DAC_Channel_1, &DAC_InitStructure);//初始化DAC DMA_DeInit(DMA1_Stream5); DMA_InitStructure.DMA_Channel = DMA_Channel_7; //DMA通道选择 DMA_InitStructure.DMA_PeripheralBaseAddr = DAC_DHR12RD_Address;//外设地址 DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&DualSine12bit;//存储器0地址 DMA_InitStructure.DMA_BufferSize = 64;//数据数目 DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;//外设数据宽度 DMA_InitStructure.DMA_MemoryDataSize = DMA_PeripheralDataSize_HalfWord;//存储器数据宽度 DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral;//传输方向 DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//外设递增 DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;//存储器递增 DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;//模式选择 DMA_InitStructure.DMA_Priority = DMA_Priority_High;//优先级 DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable; //FIFO模式 DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;//FIFO阈值 DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;//储存器突发传输 DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;//外设突发传输 DMA_Init(DMA1_Stream5, &DMA_InitStructure); DMA_Cmd(DMA1_Stream5, ENABLE); DAC_Cmd(DAC_Channel_1, ENABLE); DAC_DMACmd(DAC_Channel_1, ENABLE); } void DAC_Mode_Init(void) { uint32_t idc = 0; for (idc = 0; idc < 32; idc++) { DualSine12bit[idc] = (Sine12bit[idc] << 16) + (Sine12bit[idc]);//初始化数据 } } void Chg_Out_Sine(uint32_t Mod) { uint32_t Idx = 0; switch(Mod) { case (1): { for (Idx = 0; Idx < 32; Idx++) { DualSine12bit[Idx] = (Sine12bit[Idx] << 16) + (Sine12bit[Idx]);//正弦波输出 } };break; case (2): { for (Idx = 0; Idx < 32; Idx++) { DualSine12bit[Idx] = (Triangle12bit[Idx] << 16) + (Triangle12bit[Idx]);//三角波输出 } };break; case (3): { for (Idx = 0; Idx < 32; Idx++) { DualSine12bit[Idx] = (Sawtooth12bit[Idx] << 16) + (Sawtooth12bit[Idx]);//锯齿波输出 } };break; case (4): { for (Idx = 0; Idx < 32; Idx++) { DualSine12bit[Idx] = (Pwm12bit[Idx] << 16) + (Pwm12bit[Idx]);//pwm波输出 } };break; case (5): { for (Idx = 0; Idx < 32; Idx++) { DualSine12bit[Idx] = (Trapezoidal12bit[Idx] << 16) + (Trapezoidal12bit[Idx]);//梯形波输出 } };break; default:break; } } #include "system.h" #include "SysTick.h" #include "led.h" #include "key.h" #include "dac.h" /******************************************************************************* * 函 数 名 : main * 函数功能 : 主函数 * 输 入 : 无 * 输 出 : 无 *******************************************************************************/ int main(void) { u8 i=0; u8 j=0; u8 key=0; DAC_Mode_Init(); SysTick_Init(168); GPIO_Configuration(); TIM6_Configuration(); DAC_DMA_Configuration(); KEY_Init(); LED_Init(); while(1) { key=KEY_Scan(0); if(key==KEY_UP) { switch(j) { case 1: Chg_Out_Sine(1);break; case 2: Chg_Out_Sine(2);break; case 3: Chg_Out_Sine(3);break; case 4: Chg_Out_Sine(4);break; case 5: Chg_Out_Sine(5);break; //defau6lt:break; } j++; } i++; if(i%20==0) { led1=!led1; } delay_ms(10); } } |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
609 浏览 0 评论
【每周推荐】采用11代Intel CPU,基于youyeetoo X1开发板搭建少儿AI智能STEAM积木平台
855 浏览 0 评论
2574 浏览 2 评论
【youyeetoo X1 windows 开发板体验】+ 影音处理和AI模型移植
2274 浏览 5 评论
I.MX6ULL-飞凌 ElfBoard ELF1板卡- 移植zbar的方法
1708 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
5790 浏览 31 评论
GMT+8, 2024-4-25 03:02 , Processed in 0.478255 second(s), Total 38, Slave 31 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
