【MYS-6ULX-IOT试用体验】GPIO控制led灯闪烁+板载C编程 - 问答 - 电子技术论坛 - 最好最受欢迎电子论坛!
sunskyday ( 楼主 ) 2017-6-24 07:30:53  显示全部楼层
1)       获取系统的镜像,下载地址为http://down.myir-tech.com/MYS-6ULX/ ,需要下载的文件是mys6ull-debian8.rootfs.sdcard。下载文件大小为1.5G左右。
2)       准备一张SD卡,我用的是8G卡,class6级别。下载完成之后得到一个.sdcard后缀的文件,使用Win32Disk Imager可以打开,然后烧写到SD卡里面。
3)       上电启动开发板。将SD卡放入卡槽,拨码开关设置为0101。连接串口线,USB供电线,即可启动开发板。本次在windows10下用putty连接开发板
4)       启动之后登陆,用户名root,密码为123456,进入系统
5)输入:mkdir gpio_led     建立一个新文件夹
6)输入:vi gpio_led.c  ,编写C语言程序,从驱动层控制led灯不断闪烁
#include
#include
#include
#include
#include
#include
//#define DEBUG        1
#define ARRAY_SIZE(x)        (sizeof(x)/sizeof(x[0]))
#define LED_DELAY_US        (200*1000) /* 200 ms */
#ifdef DEBUG
#define dbg_info(fmt, args...)                printf(fmt, #args)
#else
#endif
#define dbg_err(fmt, args...)                printf(fmt, #args)
typedef struct gpio_s {
        int gpio;
        char value_path[64];
        char dir_path[64];
        int value;
}gpio_t;
void leds_ctrl(const char **leds, int count, unsigned int status)
        int i = 0;
        char cmd[128] = {0};
        static unsigned int pre_status = 0;/* It was on by default */
        for (i = 0; i < count; i++, leds++) {
                if ((pre_status ^ status) & (1 << i)) {
                        sprintf(cmd, "echo %d > %s", !!(status&(1 << i)), *leds);
                        if (system(cmd)) {
                                dbg_info("run cmd [%s] failed!n", cmd);
        pre_status = status;
void leds_play(const char **leds, int count)
        unsigned int status = 1;
        unsigned int mask;
        if (count > 32) {
                dbg_err("too many leds!(%d, expected <= 32)", count);
                return;
        mask = (0x1 << count) - 1;
        for (;;) {
                leds_ctrl(leds, count, status);
                usleep(LED_DELAY_US);
                status = (status << 1) | ((status >> (count -1))&0x1);
int main (int argc, char *argv[])
        int keys_fd;
        char ret[2];
        struct input_event t[2];
        fd_set fds;
        struct timeval tv;
        const char* leds[]={argv[1],argv[2]};
        keys_fd = open (argv[1], O_RDONLY);
        if (keys_fd <= 0) {
                dbg_err ("open %s device error!n", argv[1]);
                return 0;
    /* Set all LEDs to ON to info user for key pressing */
        leds_ctrl(leds, ARRAY_SIZE(leds), 0xF);
    leds_ctrl(leds, ARRAY_SIZE(leds), 0);
        leds_play(leds, ARRAY_SIZE(leds));
        return 0;
保存退出vi
7)输入:arm-linux-gnueablihf-gcc -o gpio_led gpio_led.c  直接在开发板上编译代码生成可执行文件
8)输入: ./gpio_led /sys/class/leds/user/brightness  直接控制LED灯
虽然有错误,但是led灯还是按照程序设计那样不断的闪烁
按Ctr+C停止
.......enjoy..........
2个回复
jackeyt 发表于 2017-7-4 15:20:39
这哪里是驱动层,这明明是应用层。
这哪里是驱动层,这明明是应用层。
对,是应用层,,我搞错了,,谢谢提醒
您需要登录后才可以回帖 登录 | 注册
本版积分规则
关闭
站长推荐上一条 /6 下一条
小黑屋|手机版|Archiver|电子发烧友 ( 湘ICP备2023018690号 )
GMT+8, 2024-4-16 17:08 , Processed in 0.538305 second(s), Total 69, Slave 47 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
微信扫描
快速回复 返回顶部 返回列表
