扫一扫,分享给好友
我刚刚买了beaglebone green 之后升级官方的最新镜像,升级完成后发现无法通过u***模拟网络了,无法通过ssh登录。之后插上网线发现也不能识别,请问这该怎么解决?我通过串口打log看到系统升级应该是成功了,log中会打出下面的错误:
fsck: error 2 (No such file or directory) while executing fsck.ext4 for /dev/mmcblk1p1 fsck exited with status code 8 过一段时间系统还是可以起来。 我用ifconfig查看,发现eth0没有ip地址,显示如下: eth0 Link encap:Ethernet HWaddr 98:5d:ad:35:25:a6 UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:5 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:418 (418.0 B) Interrupt:173 请大家帮帮忙,谢谢! 详细log如下所示; U-Boot SPL 2017.03-00002-gd12b1519b4 (Mar 14 2017 - 10:28:26) Trying to boot from MMC2 U-Boot 2017.03-00002-gd12b1519b4 (Mar 14 2017 - 10:28:26 -0500), Build: jenkins-github_Bootloader-Builder-532 CPU : AM335X-GP rev 2.1 I2C: ready DRAM: 512 MiB Reset Source: Power-on reset has occurred. MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1 Using default environment BeagleBone Black: Model: SeeedStudio BeagleBone Green: BeagleBone: cape eeprom: i2c_probe: 0x54: BeagleBone: cape eeprom: i2c_probe: 0x55: BeagleBone: cape eeprom: i2c_probe: 0x56: BeagleBone: cape eeprom: i2c_probe: 0x57: Net: eth0: MII MODE cpsw Press SPACE to abort autoboot in 2 seconds board_name=[BBG1] ... Card did not respond to voltage select! mmc_init: -95, time 13 Card did not respond to voltage select! mmc_init: -95, time 13 Card did not respond to voltage select! mmc_init: -95, time 12 gpio: pin 56 (gpio 56) value is 0 gpio: pin 55 (gpio 55) value is 0 gpio: pin 54 (gpio 54) value is 0 gpio: pin 53 (gpio 53) value is 1 Card did not respond to voltage select! mmc_init: -95, time 13 Card did not respond to voltage select! mmc_init: -95, time 13 switch to partitions #0, OK mmc1(part 0) is current device Scanning mmc 1:1... gpio: pin 56 (gpio 56) value is 0 gpio: pin 55 (gpio 55) value is 0 gpio: pin 54 (gpio 54) value is 0 gpio: pin 53 (gpio 53) value is 1 switch to partitions #0, OK mmc1(part 0) is current device gpio: pin 54 (gpio 54) value is 1 Checking for: /uEnv.txt ... Checking for: /boot.scr ... Checking for: /boot/boot.scr ... Checking for: /boot/uEnv.txt ... gpio: pin 55 (gpio 55) value is 1 2013 bytes read in 15 ms (130.9 KiB/s) Loaded environment from /boot/uEnv.txt Checking if uname_r is set in /boot/uEnv.txt... gpio: pin 56 (gpio 56) value is 1 Running uname_boot ... loading /boot/vmlinuz-4.4.54-ti-r93 ... 8652712 bytes read in 565 ms (14.6 MiB/s) loading /boot/dtbs/4.4.54-ti-r93/am335x-bonegreen.dtb ... 54498 bytes read in 62 ms (858.4 KiB/s) uboot_overlays: add [enable_uboot_overlays=1] to /boot/uEnv.txt to enable... loading /boot/initrd.img-4.4.54-ti-r93 ... 5035153 bytes read in 335 ms (14.3 MiB/s) debug: [console=ttyO0,115200n8 root=UUID=c7644031-2053-447e-a0a4-3f1f54cf2ece ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet cape_universal=enable] ... debug: [bootz 0x82000000 0x88080000:4cd491 0x88000000] ... ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Ramdisk to 8fb32000, end 8ffff491 ... OK Loading Device Tree to 8fb21000, end 8fb314e1 ... OK Starting kernel ... [ 0.000995] clocksource_probe: no matching clocksources found [ 2.057509] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle [ 2.242790] omap_voltage_late_init: Voltage driver support not added [ 2.254342] PM: Cannot get wkup_m3_ipc handle Loading, please wait... [ 4.749148] remoteproc1: failed to load am335x-pru0-fw [ 4.766420] remoteproc1: request_firmware failed: -2 [ 4.771606] pru-rproc 4a334000.pru0: rproc_boot failed [ 4.879184] remoteproc1: failed to load am335x-pru1-fw [ 4.890168] remoteproc1: request_firmware failed: -2 [ 4.895335] pru-rproc 4a338000.pru1: rproc_boot failed fsck: error 2 (No such file or directory) while executing fsck.ext4 for /dev/mmcblk1p1 fsck exited with status code 8 Debian GNU/Linux 8 beaglebone ttyS0 BeagleBoard.org Debian Image 2017-03-19 Support/FAQ: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian default username:password is [debian:temppwd] beaglebone login: debian Password: Last login: Sun Mar 19 13:57:31 UTC 2017 on ttyS0 Linux beaglebone 4.4.54-ti-r93 #1 SMP Fri Mar 17 13:08:22 UTC 2017 ARMv7l The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. debian@beaglebone:~$ sudo /etc/init.d/ssh force-reload restart status try-restart reload start stop debian@beaglebone:~$ sudo /etc/init.d/ssh force-reload restart status try-restart reload start stop debian@beaglebone:~$ sudo /etc/init.d/s screen-cleanup single sudo sendsigs ssh debian@beaglebone:~$ sudo /etc/init.d/ssh status [sudo] password for debian: ● ssh.service - OpenBSD Secure Shell server Loaded: loaded (/lib/systemd/system/ssh.service; enabled; vendor preset: enabled) Active: active (running) since Sun 2017-03-19 13:55:40 UTC; 57s ago Main PID: 1081 (sshd) CGroup: /system.slice/ssh.service └─1081 /usr/***in/sshd -D Mar 19 13:55:40 beaglebone systemd[1]: Started OpenBSD Secure Shell server. Mar 19 13:55:40 beaglebone sshd[1081]: Server listening on 0.0.0.0 port 22. Mar 19 13:55:40 beaglebone sshd[1081]: Server listening on :: port 22. debian@beaglebone:~$ sudo ifconfig eth0 Link encap:Ethernet HWaddr 98:5d:ad:35:25:a6 UP BROADCAST MULTICAST DYNAMIC MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) Interrupt:173 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:1120 errors:0 dropped:0 overruns:0 frame:0 TX packets:1120 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1 RX bytes:86880 (84.8 KiB) TX bytes:86880 (84.8 KiB) u***0 Link encap:Ethernet HWaddr 98:5d:ad:35:25:a8 inet addr:192.168.7.2 Bcast:192.168.7.3 Mask:255.255.255.252 inet6 addr: fe80::9a5d:adff:fe35:25a8/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:169 errors:0 dropped:0 overruns:0 frame:0 TX packets:40 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:15753 (15.3 KiB) TX bytes:11215 (10.9 KiB) u***1 Link encap:Ethernet HWaddr 98:5d:ad:35:25:ab inet addr:192.168.6.2 Bcast:192.168.6.3 Mask:255.255.255.252 UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) debian@beaglebone:~$ |
只有小组成员才能发言,加入小组>>
160个成员聚集在这个小组
加入小组BBB通过sd卡启动ubuntu16.04后不能升级下载联网的问题
4210 浏览 2 评论
3029 浏览 0 评论
7064 浏览 5 评论
GMT+8, 2024-4-23 18:56 , Processed in 0.434581 second(s), Total 74, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
