扫一扫,分享给好友
我写了个程序读光栅尺的值,我用示波器测输出,没有电平输出,苦恼中,求大神帮帮忙,在线等。
LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_UNSIGNED.ALL; ENtiTY Meas IS PORT( MeasIn: IN STD_LOGIC_VECTOR(1 DOWNTO 0); Clk: IN STD_LOGIC; -- Updown: IN STD_LOGIC; Count: OUT STD_LOGIC ); END Meas; -------------------------------------------------------------- ARCHITECTURE Rt1 OF Meas IS CONSTANT Stata0: STD_LOGIC_VECTOR:="00"; CONSTANT Stata1: STD_LOGIC_VECTOR:="10"; CONSTANT Stata2: STD_LOGIC_VECTOR:="11"; CONSTANT Stata3: STD_LOGIC_VECTOR:="01"; -------------------------------------------------------------- SIGNAL Oldstata: STD_LOGIC_VECTOR(1 DOWNTO 0); SIGNAL Temp0: STD_LOGIC; SIGNAL Temp1: STD_LOGIC; SIGNAL Temp2: STD_LOGIC; -------------------------------------------------------------- BEGIN PROCESS BEGIN WAIT UNTIL Clk = '1'; IF MeasIn = Stata0 THEN Oldstata <= MeasIn; Temp0 <= MeasIn(0) XOR MeasIn(1); Temp1 <= Oldstata(0) XOR Oldstata(1); Temp2 <= Temp0 XOR Temp1; IF Temp2 = '1' THEN Count <= '1'; ELSIF Temp2 = '0' THEN Count <= '0'; END IF; ELSIF MeasIn = Stata1 THEN Oldstata <= MeasIn; Temp0 <= MeasIn(0) XOR MeasIn(1); Temp1 <= Oldstata(0) XOR Oldstata(1); Temp2 <= Temp0 XOR Temp1; IF Temp2 = '1' THEN Count <= '1'; ELSIF Temp2 = '0' THEN Count <= '0'; END IF; ELSIF MeasIn = Stata2 THEN Oldstata <= MeasIn; Temp0 <= MeasIn(0) XOR MeasIn(1); Temp1 <= Oldstata(0) XOR Oldstata(1); Temp2 <= Temp0 XOR Temp1; IF Temp2 = '1' THEN Count <= '1'; ELSIF Temp2 = '0' THEN Count <= '0'; END IF; ELSIF MeasIn = Stata3 THEN Oldstata <= MeasIn; Temp0 <= MeasIn(0) XOR MeasIn(1); Temp1 <= Oldstata(0) XOR Oldstata(1); Temp2 <= Temp0 XOR Temp1; IF Temp2 = '1' THEN Count <= '1'; ELSIF Temp2 = '0' THEN Count <= '0'; END IF; END IF; END PROCESS; END Rt1; |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
240 浏览 0 评论
301 浏览 0 评论
1039 浏览 0 评论
354 浏览 0 评论
FPGA零基础学习系列精选:半导体存储器和可编程逻辑器件简介
977 浏览 0 评论
1350 浏览 32 评论
GMT+8, 2024-4-18 22:58 , Processed in 0.472582 second(s), Total 65, Slave 49 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
