扫一扫,分享给好友
这个图还能再模糊点吗
额 我重新来一张 |
#include "DSP28x_Project.h" void I2CA_Init(void); interrupt void i2c_int1a_isr(void); void InitGpioCtrls(void); void set_7seg_data(char ch); char get_res_data(); #define I2C_SLAVE_ADDR 0xC0 >> 1 #define I2C_NUMBYTES 2 #define I2C_EEPROM_HIGH_ADDR 0x00 #define I2C_EEPROM_LOW_ADDR 0x30 char dt_tx; char dt_rx; char dt_rdy; void main(void) { // Step 1. Initialize System Control: // PLL, WatchDog, enable Peripheral Clocks // This example function is found in the DSP2802x_SysCtrl.c file. InitSysCtrl(); // Step 2. Initalize GPIO: // This example function is found in the DSP2802x_Gpio.c file and // illustrates how to set the GPIO to it's default state. InitGpioCtrls(); // Setup only the GP I/O only for I2C functionality InitI2CGpio(); // Step 3. Clear all interrupts and initialize PIE vector table: // Disable CPU interrupts DINT; // Initialize PIE control registers to their default state. // The default state is all PIE interrupts disabled and flags // are cleared. // This function is found in the DSP2802x_PieCtrl.c file. InitPieCtrl(); // Disable CPU interrupts and clear all CPU interrupt flags: IER = 0x0000; IFR = 0x0000; // Initialize the PIE vector table with pointers to the shell Interrupt // Service Routines (ISR). // This will populate the entire table, even if the interrupt // is not used in this example. This is useful for debug purposes. // The shell ISR routines are found in DSP2802x_DefaultIsr.c. // This function is found in DSP2802x_PieVect.c. InitPieVectTable(); // Interrupts that are used in this example are re-mapped to // ISR functions found within this file. EALLOW; // This is needed to write to EALLOW protected registers PieVectTable.I2CINT1A = &i2c_int1a_isr; EDIS; // This is needed to disable write to EALLOW protected registers // Step 4. Initialize all the Device Peripherals: // This function is found in DSP2802x_InitPeripherals.c // InitPeripherals(); // Not required for this example I2CA_Init(); // Step 5. User specific code // Enable interrupts required for this example // Enable I2C interrupt 1 in the PIE: Group 8 interrupt 1 PieCtrlRegs.PIEIER8.bit.INTx1 = 1; // Enable CPU INT8 which is connected to PIE group 8 IER |= M_INT8; EINT; dt_rdy = 0; dt_rx = 0; set_7seg_data(0); // Application loop for(;;) { if (dt_rdy) { dt_rdy = 0; set_7seg_data(dt_rx); } if (I2caRegs.I2CSTR.bit.XRDY) { dt_tx = get_res_data(); I2caRegs.I2CDXR = dt_tx; set_7seg_data(dt_tx); } } } // end of main void I2CA_Init(void) { // Initialize I2C // I2CCLK = SYSCLK/(I2CPSC+1) #if (CPU_FRQ_40MHZ||CPU_FRQ_50MHZ) I2caRegs.I2CPSC.all = 4; // Prescaler - need 7-12 Mhz on module clk #endif #if (CPU_FRQ_60MHZ) I2caRegs.I2CPSC.all = 6; // Prescaler - need 7-12 Mhz on module clk #endif I2caRegs.I2CCLKL = 10; // NOTE: must be non zero I2caRegs.I2CCLKH = 5; // NOTE: must be non zero I2caRegs.I2COAR = I2C_SLAVE_ADDR; // I2caRegs.I2CMDR.all = 0x0000; // SLAVE, 8bits per data byte, TRX is don't care I2caRegs.I2CCNT = 1; // Get 1 byte I2caRegs.I2CIER.all = 0x18; // Clear interrupts (was 0) I2caRegs.I2CSTR.bit.RRDY = 1; // Clear flag I2caRegs.I2CIER.bit.RRDY = 1; // Enable Receive Interrupt I2caRegs.I2CMDR.all = 0x0020; // Take I2C out of reset // I2caRegs.I2CFFTX.all = 0x6000; // Enable FIFO mode and TXFIFO // I2caRegs.I2CFFRX.all = 0x2040; // Enable RXFIFO, clear RXFFINT, return; } interrupt void i2c_int1a_isr(void) // I2C-A { Uint16 IntSource; // Read interrupt source IntSource = I2caRegs.I2CISRC.all; // Interrupt source = stop condition detected if(IntSource == I2C_RX_ISRC) { // Data received dt_rdy = 1; dt_rx = I2caRegs.I2CDRR; } // end of stop condition detected // Enable future I2C (PIE Group 8) interrupts PieCtrlRegs.PIEACK.all = PIEACK_GROUP8; } void InitGpioCtrls(void) { EALLOW; GpioCtrlRegs.GPAMUX1.all = 0x0000; // GPIO functionality GPIO0-GPIO15 GpioCtrlRegs.GPAMUX2.all = 0x0000; // GPIO functionality GPIO16-GPIO31 GpioCtrlRegs.GPBMUX1.all = 0x0000; // GPIO functionality GPIO32-GPIO34 GpioCtrlRegs.AIOMUX1.all = 0x0000; // Dig.IO funct. applies to AIO2,4,6,10,12,14 GpioCtrlRegs.GPADIR.all = 0xFFFFFFF0; // GPIO0-GPIO7 are GP inputs, GPIO8-GPIO31 are outputs GpioCtrlRegs.GPBDIR.all = 0xFFFFFFFF; // GPIO32-GPIO35 are outputs GpioCtrlRegs.AIODIR.all = 0x00000000; // AIO2,4,6,19,12,14 are digital inputs // Each input can have different qualification // a) input synchronized to SYSCLKOUT // b) input qualified by a sampling window // c) input sent asynchronously (valid for peripheral inputs only) GpioCtrlRegs.GPAQSEL1.all = 0x0000; // GPIO0-GPIO15 Synch to SYSCLKOUT GpioCtrlRegs.GPAQSEL2.all = 0x0000; // GPIO16-GPIO31 Synch to SYSCLKOUT GpioCtrlRegs.GPBQSEL1.all = 0x0000; // GPIO32-GPIO34 Synch to SYSCLKOUT // Pull-ups can be enabled or disabled. // GpioCtrlRegs.GPAPUD.all = 0x0000; // Pullup's enabled GPIO0-GPIO31 // GpioCtrlRegs.GPBPUD.all = 0x0000; // Pullup's enabled GPIO32-GPIO34 GpioCtrlRegs.GPAPUD.all = 0xFFFFFFFF; // Pullup's disabled GPIO0-GPIO31 GpioCtrlRegs.GPBPUD.all = 0xFFFFFFFF; // Pullup's disabled GPIO32-GPIO34 EDIS; } // 12,16,17,18 - GPA; 32,33,34,35 - GPB void set_7seg_data(char ch) { if (ch & 0x01) GpioDataRegs.GPASET.bit.GPIO12 = 1; else GpioDataRegs.GPACLEAR.bit.GPIO12 = 1; if (ch & 0x02) GpioDataRegs.GPASET.bit.GPIO16 = 1; else GpioDataRegs.GPACLEAR.bit.GPIO16 = 1; if (ch & 0x04) GpioDataRegs.GPASET.bit.GPIO17 = 1; else GpioDataRegs.GPACLEAR.bit.GPIO17 = 1; if (ch & 0x08) GpioDataRegs.GPASET.bit.GPIO18 = 1; else GpioDataRegs.GPACLEAR.bit.GPIO18 = 1; if (ch & 0x10) GpioDataRegs.GPBSET.bit.GPIO32 = 1; else GpioDataRegs.GPBCLEAR.bit.GPIO32 = 1; if (ch & 0x20) GpioDataRegs.GPBSET.bit.GPIO33 = 1; else GpioDataRegs.GPBCLEAR.bit.GPIO33 = 1; if (ch & 0x40) GpioDataRegs.GPBSET.bit.GPIO34 = 1; else GpioDataRegs.GPBCLEAR.bit.GPIO34 = 1; if (ch & 0x80) GpioDataRegs.GPBSET.bit.GPIO35 = 1; else GpioDataRegs.GPBCLEAR.bit.GPIO35 = 1; } char get_res_data() { return GpioDataRegs.GPADAT.all & 0x000000FF; } //=========================================================================== // No more. //===========================================================================
大神们 求回复
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
基于51单片机的车辆倒车雷达报警系统,HC-SR04超声波测距,全套资料
586 浏览 0 评论
【原创】收藏!单片机输出4种波形的函数信号发生器毕设(Proteus仿真+原理图+源码和论文)
1542 浏览 1 评论
5852 浏览 6 评论
《Proteus实战攻略从简单电路到单片机电路的仿真》+读后总结与推荐
969 浏览 0 评论
请问2020版本ADS中的symbol如何设置出layout look-alike
68007 浏览 0 评论
GMT+8, 2024-4-19 12:15 , Processed in 0.364669 second(s), Total 45, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
