扫一扫,分享给好友
我想用DMA接收串口1数据,当数据接受完之后产生中断,可是我写了一段程序发现DMA好像都接收不到数据,更别说是进中断了,我不知道我的程序到底是哪里出了问题,希望大神们可以帮我看看,以下是程序(因为是新手,一个就2个积分,希望大家不要嫌少)
#include "usart1.h" #include "public.h" #include "jxl12864.h" extern u8 ECG_data[BUFF_SIZE] ; u8 ECG_dataChannel = 0; /////DMA接收到的数据存放位置说明 u8 ECG_data1[BUFF_SIZE] ; u8 ECG_data2[BUFF_SIZE] ; ///芯片一秒钟发送约4555个字(一个字即两字节 如 AA为一个字) void USART1_Config(void) { GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOAtiNG; GPIO_Init(GPIOA, &GPIO_InitStructure); USART_InitStructure.USART_BaudRate = 57600; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No ; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_Init(USART1, &USART_InitStructure); USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); //使能接收中断 // USART_ITConfig(USART1, USART_IT_IDLE, ENABLE); //使能空闲中断 USART_DMACmd(USART1, USART_DMAReq_Rx, ENABLE); // 开启串口DMA接收 USART_Cmd(USART1, ENABLE); } void DMA_Config(void) { DMA_InitTypeDef DMA_InitStructure; RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); //开启DMA时钟 DMA_DeInit(DMA1_Channel5); ///将 DMA 的通道 x 寄存器重设为缺省值 DMA_InitStructure.DMA_PeripheralBaseAddr = USART1_DR_Base; ///DMA外设基地址 DMA_InitStructure.DMA_MemoryBaseAddr =(u8)ECG_data1; ///DMA内存基地址 (u8)&data; // DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST; ///方向:从内存到外设 DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; ///方向:从外设到内存 DMA_InitStructure.DMA_BufferSize = BUFF_SIZE; ///传输大小DMA_BufferSize=BUFF_SIZE DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; ////外设地址不增 DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; ///内存地址自增 DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte; ///外设数据单位 DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte; ///内存数据单位 8bit // DMA_InitStructure.DMA_Mode = DMA_Mode_Circular ; ///DMA模式:循环缓存模式 DMA_InitStructure.DMA_Mode = DMA_Mode_Normal ; ///DMA模式:一次传输,正常缓存模式 DMA_InitStructure.DMA_Priority = DMA_Priority_High; ///优先级:高 DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; ///禁止内存到内存的传输 DMA_Init(DMA1_Channel5, &DMA_InitStructure); ///配置DMA1的5通道 DMA_ITConfig(DMA1_Channel5,DMA_IT_TC,ENABLE); //配置DMA接收完成后产生中断 DMA_ITConfig(DMA1_Channel5,DMA_IT_HT,ENABLE); //传输过半 DMA_ITConfig(DMA1_Channel5,DMA_IT_TE,ENABLE); //传输错误 // USART_DMACmd(USART1,USART_DMAReq_Rx,ENABLE); // 开启串口DMA接收 DMA_Cmd (DMA1_Channel5,ENABLE); //使能DMA } static void NVIC_usart1Configuration(void) { NVIC_InitTypeDef NVIC_InitStructure; // NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1); NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //打开usart1全局中断 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; //枪占优先级 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; //响应优先级 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //使能 NVIC_Init(&NVIC_InitStructure); } static void NVIC_DMAConfiguration(void) { NVIC_InitTypeDef NVIC_InitStructure; // NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1); NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel5_IRQn; //打开中断 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; //枪占优先级 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //响应优先级 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //使能 NVIC_Init(&NVIC_InitStructure); } void NVIC_Configuration(void) { NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1); // NVIC_usart1Configuration(); NVIC_DMAConfiguration(); } void DMA1_Channel5_IRQHandler(void) { DMA_InitTypeDef DMA_InitStructure; if( DMA_GetFlagStatus(DMA1_FLAG_TC5) ==SET) { GPIO_SetBits(GPIOC,GPIO_Pin_13); //LED OFF // display_number(6,30,1); DMA_ClearFlag(DMA1_FLAG_TC5); ///清除标志位 } if( DMA_GetFlagStatus(DMA1_FLAG_HT5) ==SET) { // GPIO_SetBits(GPIOC,GPIO_Pin_13); //LED OFF display_number(6,30,1); DMA_ClearFlag(DMA1_FLAG_TC5); ///清除标志位 } if( DMA_GetFlagStatus(DMA1_FLAG_TC5) ==SET) { GPIO_SetBits(GPIOC,GPIO_Pin_13); //LED OFF display_number(6,30,1); DMA_ClearFlag(DMA1_FLAG_TE5); ///清除标志位 } } 补充内容 (2017-2-14 13:16): 我发现如果我打开DMA传输错误中断,会一直进入这个中断中。你们如果觉得不好找,给我一个你们以前写过的程序也行,用DMA接收串口1的数据,数据长度固定 |
6个回答
算了,被我自己研究出来了
DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)(&USART1->DR); //USART1_DR_Base; DMA_InitStructure.DMA_MemoryBaseAddr =(u8)ECG_data1;
问题在这里,把DMA_InitStructure.DMA_MemoryBaseAddr =(u8)ECG_data1;改为DMA_InitStructure.DMA_MemoryBaseAddr =(u32)ECG_data1;就可以了 |
大家编译的时候一定不要忽视警告,如果你编出来的东西有问题,说不定就在警告里
我自己弄出来了
哈哈,那是一个32bit的,库函数里面有定义
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
242 浏览 1 评论
664 浏览 0 评论
MCU友好过渡MPU,米尔基于STM32MP135开发板裸机开发应用笔记
600 浏览 0 评论
自定义系统时钟频率后,用库函数和微带两种方式点亮LED灯,为什么灯的闪烁频率不一致?
1389 浏览 2 评论
1612 浏览 2 评论
GMT+8, 2024-4-18 19:17 , Processed in 0.483645 second(s), Total 75, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
