`#include #include #define uchar unsigned char #define uint unsigned int ***it cs=P3^5; ***it clk=P3^3; ***it dati=P3^4; ***it dato=P3^4; ***it lcden=P2^3; ***it lcdrs=P2^5; ***it dula =P2^6; ***it wela=P2^7; uchar dat=0x00; uchar count=0x00; uchar numu; uchar CH; uchar dis[]={0x01,0x02,0x03,0x04}; uchar code tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90}; uchar code tablewe[]={0xfd,0xfb,0xf7,0xf0,0xdf,0xfe}; uchar table[3]; //adc0832初始化函数,用途读入数据 uchar adc0832(uchar CH) { uchar i,test,adval; adval=0x00; test=0x00; clk=0; dati=1; _nop_();cs=0; _nop_();clk=1;_nop_(); if(CH==0x00) { clk=0; dati=1; _nop_(); clk=1; _nop_(); clk=0; dati=0; _nop_(); clk=1; _nop_(); } else { clk=0; dati=1; _nop_(); clk=1; _nop_(); clk=1; _nop_(); clk=0; dati=1; _nop_(); clk=1; _nop_(); } clk=0; dati=1; for(i=0;i<8;i++) {_nop_(); adval<<=1; clk=1; _nop_(); clk=0; if(dato) adval|=0x01; else adval|=0x00; } for(i=0;i<8;i++) {test>>=1; if(dato) test|=0x80; else test|=0x00; _nop_(); clk=1; _nop_(); clk=0; } if(adval==test) dat=test;_nop_(); cs=1; dato=1;clk=1;return dat;} void delay1(uint z) { uint x,y; for(x=z;x>0;x--) for(y=110;y>0;y--); } //写命令操作函数 void write_com(uchar com) { lcdrs =0; P0=com; delay1(5); lcden=1; delay1(5); lcden=0; } //写数据操作函数 void write_data(uchar date) { lcdrs=1; P0=date; delay1(5); lcden=1; delay1(5); lcden=0; } //对显示频进行初始化函数 void init() { dula=0; wela =0; lcden =0; write_com(0x38); write_com(0x0c); write_com(0x06); write_com(0x01); } void delay(void)//延时函数 {uint r; for(r=10;r<500;r++) ; } //原取数字函数 void convdata(uchar i) { dis[0]=i/51; dis[1]=(i%51)*10/51; dis[2]=((i%51)*10%51)*10/51; } //显示函数 void display(void) { table[0]=tab[dis[0]]; delay(); table[1]='.'; table[2]=tab[dis[1]]; delay(); P2=0x08; table[3]=tab[dis[2]]; delay(); write_com(80); for(numu=0;numu<16;numu++) { if (numu==8||numu==11||numu==10||numu==9) { write_data(table[numu-8]); delay1(5); } else write_data(' '); } } //主函数 void main(void) { P2=0xff; P0=0xff; delay(); delay(); CH=0x00; TMOD=0x01; TH0=15535/256; TL0=15536%256; IE=0x82; TR0=1; init(); while(1) {dat=adc0832(CH); convdata(dat); display(); }} void timero(void) interrupt 1 { TMOD=0x01; TMOD=0x01; TH0=15535/256; TL0=15536%256; IE=0x82; TR0=1; count++; if(count==0x01) {count=0x00;dat=adc0832(CH);}} ` |
2个回答
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
609 浏览 0 评论
【每周推荐】采用11代Intel CPU,基于youyeetoo X1开发板搭建少儿AI智能STEAM积木平台
855 浏览 0 评论
2574 浏览 2 评论
【youyeetoo X1 windows 开发板体验】+ 影音处理和AI模型移植
2274 浏览 5 评论
I.MX6ULL-飞凌 ElfBoard ELF1板卡- 移植zbar的方法
1708 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
5793 浏览 31 评论
GMT+8, 2024-4-25 04:37 , Processed in 0.501820 second(s), Total 72, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
