扫一扫,分享给好友
#include
#define A P0 #include unsigned int c,flag; void timer0() interrupt1; void delay(unsigned int t); void main() { char ls[]={0xff,0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f}; while(1) { char i; for(i=0;i<9;i++) { A=ls[i]; delay(1000); A=_cror_(A,1); } for(i=7;i>0;i--) { A=ls[i]; delay(1000); A=_crol_(A,1); } } } void timer0() interrupt1 { c--; if(c==0) flag=1; } void delay(unsigned int t) { TMOD=0x01; TR0=1; EA=1; ET0=1; TH0=(65536-1000)/256; TL0=(65536-1000)%256; c=t; flag=0; while(flag==0); } |
9个回答
LED普通.C(8): error C132: 'main': not in formal parameter list
LED普通.C(8): error C141: syntax error near '{' LED普通.C(9): error C244: 'ls': can't initialize, bad type or class LED普通.C(9): error C132: 'ls': not in formal parameter list LED普通.C(10): error C141: syntax error near 'while' LED普通.C(10): error C141: syntax error near '1' LED普通.C(13): error C141: syntax error near 'for' LED普通.C(13): error C141: syntax error near '=', expected ')' LED普通.C(13): error C129: missing ';' before '<' Target not created |
#include
#define A P0 #include unsigned int c,flag; // void timer0() interrupt 1; void delay(unsigned int t); void main() { char ls[]={0xff,0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f}; while(1) { char i; for(i=0;i<9;i++) { A=ls[i]; delay(1000); A=_cror_(A,1); } for(i=7;i>0;i--) { A=ls[i]; delay(1000); A=_crol_(A,1); } } } void timer0() interrupt 1 { c--; if(c==0) flag=1; } void delay(unsigned int t) { TMOD=0x01; TR0=1; EA=1; ET0=1; TH0=(65536-1000)/256; TL0=(65536-1000)%256; c=t; flag=0; while(flag==0); } |
终端函数不需要申明,include后面这里没看到,还有就是你有没有把这个c文件添加到工程
还是不行啊 Build target 'Target 1' compiling 定时器延时.c... 定时器延时.C(32): error C132: 'interrupt1': not in formal parameter list 定时器延时.C(32): error C141: syntax error near '{' 定时器延时.C(33): error C132: 'c': not in formal parameter list 定时器延时.C(35): error C244: 'flag': can't initialize, bad type or class 定时器延时.C(35): error C132: 'flag': not in formal parameter list 定时器延时.C(36): error C141: syntax error near '}' Target not created |
错误:void timer0() interrupt1 正确:void timer0() interrupt 1 少了一个空格,中断服务程序不需要声明 |
对,我把声明去了,但还是不行,还是那些错误,这个c文件我添加进去了啊,怎么还是显示没有 |
是的是的,谢谢 |
原来是interrupt和1中间没有加空格,而且多声明了中断函数,感谢大家
{:4_96:}
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
【每周推荐】采用11代Intel CPU,基于youyeetoo X1开发板搭建少儿AI智能STEAM积木平台
765 浏览 0 评论
2235 浏览 2 评论
【youyeetoo X1 windows 开发板体验】+ 影音处理和AI模型移植
2094 浏览 5 评论
I.MX6ULL-飞凌 ElfBoard ELF1板卡- 移植zbar的方法
1682 浏览 0 评论
2646 浏览 3 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
5478 浏览 31 评论
GMT+8, 2024-4-18 22:32 , Processed in 0.521929 second(s), Total 79, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
