6. 创建完工程后,开始添加依赖
dependencies {
compile 'org.eclipse.paho:org.eclipse.paho.client.mqttv3:1.1.0'
compile 'org.eclipse.paho:org.eclipse.paho.android.service:1.1.0'
7. 注册Service
具体的代码(这一部分主要是参考网上
http://www.itnose.net/detail/6652162.html这一个帖子,我以前没做过MQTT手机端,所以主要参考他的,自己研究研究拿来用)
package com.dongyk.service;
import android.app.Service;
public class MQTTService extends Service {
public static final String TAG = MQTTService.class.getSimpleName();
private static MqttAndroidClient client;
private MqttConnectOptions conOpt;
// private String host = "tcp://10.0.2.2:61613";
private String host = "tcp://192.168.1.103:61613";
private String userName = "admin";
private String passWord = "password";
private static String myTopic = "AM3359_TEST";
private String clientId = "am3359_test";
public int onStartCommand(Intent intent, int flags, int startId) {
init();
return super.onStartCommand(intent, flags, startId);
public static void publish(String msg){
String topic = myTopic;
Integer qos = 0;
Boolean retained = false;
try {
client.publish(topic, msg.getBytes(), qos.intValue(), retained.booleanValue());
} catch (MqttException e) {
e.printStackTrace();
private void MQTT_init() {
// 服务器地址(协议+地址+端口号)
String uri = host;
client = new MqttAndroidClient(this, uri, clientId);
// 设置MQTT监听并且接受消息
client.setCallback(mqttCallback);
conOpt = new MqttConnectOptions();
// 清除缓存
conOpt.setCleanSession(true);
// 设置超时时间,单位:秒
conOpt.setConnectionTimeout(10);
// 心跳包发送间隔,单位:秒
conOpt.setKeepAliveInterval(20);
// 用户名
conOpt.setUserName(userName);
// 密码
conOpt.setPassword(passWord.toCharArray());
// last will message
boolean doConnect = true;
String message = "{"terminal_uid":"" + clientId + ""}";
Integer qos = 0;
if ((!message.equals("")) || (!topic.equals(""))) {
try {
conOpt.setWill(topic, message.getBytes(), qos.intValue(), retained.booleanValue());
} catch (Exception e) {
Log.i(TAG, "Exception Occured", e);
doConnect = false;
iMqttActionListener.onFailure(null, e);
if (doConnect) {
doClientConnection();
/** 连接MQTT服务器 */
private void doClientConnection() {
if (!client.isConnected() && isConnectIsNomarl()) {
try {
client.connect(conOpt, null, iMqttActionListener);
// MQTT是否连接成功
private IMqttActionListener iMqttActionListener = new IMqttActionListener() {
@Override
public void onSuccess(IMqttToken arg0) {
Log.i(TAG, "连接成功 ");
try {
// 订阅myTopic话题
client.subscribe(myTopic,1);
@Override
public void onFailure(IMqttToken arg0, Throwable arg1) {
arg1.printStackTrace();
// 连接失败,重连
// MQTT监听并且接受消息
private MqttCallback mqttCallback = new MqttCallback() {
@Override
public void messageArrived(String topic, MqttMessage message) throws Exception {
String str1 = new String(message.getPayload());
MQTTMessage msg = new MQTTMessage();
msg.setMessage(str1);
EventBus.getDefault().post(msg);
String str2 = topic + ";qos:" + message.getQos() + ";retained:" + message.isRetained();
Log.i(TAG, "messageArrived:" + str1);
Log.i(TAG, str2);
@Override
public void deliveryComplete(IMqttDeliveryToken arg0) {
@Override
public void connectionLost(Throwable arg0) {
// 失去连接,重连
/** 判断网络是否连接 */
private boolean isConnectIsNomarl() {
ConnectivityManager connectivityManager = (ConnectivityManager) this.getApplicationContext().getSystemService(Context.CONNECTIVITY_SERVICE);
NetworkInfo info = connectivityManager.getActiveNetworkInfo();
if (info != null && info.isAvailable()) {
String name = info.getTypeName();
Log.i(TAG, "MQTT当前网络名称:" + name);
return true;
} else {
Log.i(TAG, "MQTT 没有可用网络");
return false;
@Nullable
@Override
public IBinder onBind(Intent intent) {
return null;
首先初始化各个参数,之后连接服务器。连接成功之后在
http://127.0.0.1:61680/看到自动创建了名称为”AM3359_TEST”的topic。
8. 启动板子,用手干扰一下热释电,就可以在手机主题上看到这个消息。
9. 因为我的电脑没有公网IP地址,所以目前只能在内网测试一下了,就是把板子,电脑,手机都连接到通同一个路由器上,要不就不成功了。
10 ,其实还有一个 shell 脚本文件 ,就是定时检测热释电,有信号就启动一下MQTT去发个消息。
11. 目前基本功能都已经实现,扩展部分就是SPI 接口的 LCD屏和 WIFI 部分了。不过这些有时间的话做一做,后续做的话会分享给大家。
12. 项目基本完成了,不过还有许多BUG,尚待完善。继续努力。。。
