EasyEDA开源硬件——纬度和电压传感器模块MPL3115A2
[复制链接]
版主
发表于 2016-1-21 15:34:35   1989 查看 1 回复 显示全部楼层 倒序浏览
分享
Description: Life has its ups and downs, so why not measure them? The MPL3115A2 is a MEMS pressure sensor that provides Altitude data to within 30cm (with oversampling enabled). The sensor outputs are digitized by a high resolution 24-bit ADC and transmitted over I2C, meaning it’s easy to interface with most controllers. Pressure output can be resolved with output in fractions of a Pascal, and Altitude can be resolved in fractions of a meter. The device also provides 12-bit temperature measurements in degrees Celsius.
This breakout board makes it easy to prototype using this tiny device by breaking out the necessary pins to a standard 0.1" spaced header.
The board also has all of the passive components needed to get the device functioning, so you can simply connect it to something that talks I2C and get to work!
Features:
1.95V to 3.6V Supply Voltage, internally regulated by LDO
1.6V to 3.6V Digital Interface Supply Voltage
Fully Compensated internally
Direct Reading, Compensated
Pressure: 20-bit measurement (Pascals)
Altitude: 20-bit measurement (meters)
Temperature: 12-bit measurement (degrees Celsius)
Programmable Events
Autonomous Data Acquisition
Resolution down to 1 ft. / 30 cm
32 Sample FIFO
Ability to log data up to 12 days using the FIFO
1 second to 9 hour data acquisition rate
I2C digital output interface (operates up to 400 kHz)
GitHub (Design Files & Example Code)
GitHub (Library)
Sparkfun link:https://www.sparkfun.com/products/11084
描述 : 生活有高低起伏,如何测量它呢。 MPL3115A2 是一个MEMS压力传感器提供精度在3cm的高度数据。 传感器输出通过一个高分辨率的24-bit ADC数字化,并且通过I2C传输,意味着它很容易与很多的控制器相连接。 压力输出可以用Pascal的分数来解决, 而高度可以用米的分数来描述,它同时提供了用摄氏度描述的12-bit温度测量。
这个板子使得很容易运用这个小器件通过将必要引脚分开为标准的1''间距排针设计原型。
这个板子同样拥有很多需要使这个器件工作的被动元件,,所以你仅仅需要将它连接到I2C接口的器件然后开始工作。特征:
1.95V to 3.6V 电压源,内部通过LDO调节
1.6V to 3.6V 数字接口电压源
内部完全补偿
直接读取,补偿
压力: 20-bit 测量(帕斯卡尔)
高度: 20-bit 测量(米)
温度:12bit 测量 (度)
可编程事件
自动匿名数据获取
分辨率低到 1 ft./30cm
32 采样快速输入输出
通过快速输入输出记录12天的数据
1秒到9小时的数据采样速率
I2C数字输出接口(工作到400Kz)
MPL3115A2_breakout SCH
MPL3115A2_breakout PCB
EasyEDA项目链接:
https://easyeda.com/oshw/Altitude_Pressure_Sensor_Breakout_MPL3115A2_Open_hardware-NEMGASMGY
EasyEDA链接:   https://easyeda.com
标签:传感器
助理工程师
发表于 2016-3-10 16:58:03
官网居然不是全中文的菜单
回复
点赞 举报
高级模式
站长推荐 上一条 /7 下一条
推荐专区
技术干货集中营
专家问答
用户帮助┃咨询与建议┃版主议事
工程师杂谈
工程师创意
工程师职场
论坛电子赛事
社区活动专版
发烧友活动
嵌入式论坛
ARM技术论坛
Android论坛
Linux论坛
单片机/MCU论坛
FPGA|CPLD|ASIC论坛
DSP论坛
嵌入式系统论坛
电源技术论坛
电源技术论坛
无线充电技术
硬件设计论坛
PCB设计论坛
电路设计论坛
电子元器件论坛
控制|传感
总线技术|接口技术
测试测量论坛
LabVIEW论坛
Matlab论坛
测试测量技术专区
仪器仪表技术专区
EDA设计论坛
multisim论坛
PADS技术论坛
Protel|AD|DXP论坛
Allegro论坛
proteus论坛|仿真论坛
EasyEDA-中国人自已的EDA工具
Orcad论坛
综合技术与应用
电机控制
智能电网
光电及显示
参考设计中心
汽车电子技术论坛
医疗电子论坛
开源硬件
无线通信论坛
无线通信技术专区
天线|RF射频|微波|雷达技术
IC设计论坛
芯片测试与失效分析
Mixed Signal/SOC[数模混合芯片设计]
Analog/RF IC设计
设计与制造封装测试
厂商专区
TI论坛
TI Deyisupport社区
检测技术与质量
电磁兼容(EMC)设计与整改
安规知识论坛
检测与认证
消费电子论坛
手机技术论坛
平板电脑/mid论坛
音视/视频/机顶盒论坛
电子论坛综合区
聚丰众筹官方社区
新人报道区
聚丰供应链
论坛服务区
供求信息发布
供需广告
招聘┃求职发布区
电子展览展会专区
