EasyEDA硬件开源项目——湿度和温度传感器模块
[复制链接]
版主
发表于 2015-12-31 18:55:40   2184 查看 1 回复 显示全部楼层 倒序浏览
分享
Description:
The SHT15 Breakout is an easy to use, highly accurate, digital temperature and humidity sensor. This board has been fully calibrated and offers high precision and excellent long-term stability at low cost. The digital CMOSens® technology integrates two sensors and readout circuitry on one single chip. All you need is two lines for 2-wire communication, and you’ll have relative humidity and temperature readings to help you sense the world around you!
The two sensors built into the SHT15 have been seamlessly coupled to a 14bit analog to digital converter and a serial interface circuit resulting in superior signal quality, fast response time, and a strong resistance to external disturbances. Additionally, the on board SHT15 features a 0-100% RH measurement range with a temperature accuracy of +/- 0.3°C @ 25°C. There are only four pins that need to be hooked up in order to start using this sensor in a project. One for VCC, one for GND, and the two data lines SDA and SCL.
Features:
Operating Voltages: 2.4V min - 5.5V max
2 factory calibrated sensors for relative humidity & temperature
Digital 2-wire interface (Not I2C, but similar)
Measurement range: 0-100% RH
Absolute RH accuracy: +/- 2% RH (10…90% RH)
Repeatability RH: +/- 0.1% RH
Temp. accuracy: +/- 0.3°C @ 25°C
Precise dewpoint calculation possible
Fast response time
Low power consumption (typ. 30 µW)
描述:
SHT15模块是一个容易用的,高精度的,数字温度和湿度传感器。这个板已经被完整地校验了并且以极低的价格提供高精度和杰出的长期稳定性的 。这个数字CMOS技术集成了两个传感器和在一个单芯片上独处电路。你所需要的使用ige两线的通信,你将会拥有响度idea湿度和温度读出数据帮助你感知外部的世界。
这连个内嵌在SHT15的传感器已经被无缝地整合到14bit 模拟转数字的转换器和一个由较高的信号质量产生的串联接口电路,快速反应时间,以及一个对于外部干扰的强烈阻抗。 另外,这个在板的SHT15在温度精确度为
+/- 0.3°C @ 25°C, 0-100% RH测量范围起着重要的作用。当你开始使用这个工程中的传感器的时候只有四个引脚你需要使用。一个是VCC,一个是GND和两个数据线SDA和SCL。 特性:
工作电压:   2.4V min - 5.5V max
对于相对湿度和温度的2个工厂校验传感器
数字2-线接口(不是I2C,但是类似)
测量范围:  0-100% RH
绝对RH准确度+/- 2% RH (10…90% RH)
可重复性 RH: +/- 0.1% RH
温度.精度 : +/- 0.3°C @ 25°C
精确的露点计算
快速反应时间
低功耗(typ. 30 µW)
SHT1x-Breakout-v14 SCH
SHT1x-Breakout-v14 PCB
EasyEDA项目链接:
https://easyeda.com/oshw/Humidity_and_Temperature_Sensor_Breakout_SHT15_Open_hardware-cTfBXHrNw
EasyEDA链接:   https://easyeda.com
标签:温度传感器
助理工程师
发表于 2016-3-10 16:54:17
学习了
回复
点赞 举报
高级模式
站长推荐 上一条 /7 下一条
推荐专区
技术干货集中营
专家问答
用户帮助┃咨询与建议┃版主议事
工程师杂谈
工程师创意
工程师职场
论坛电子赛事
社区活动专版
发烧友活动
嵌入式论坛
ARM技术论坛
Android论坛
Linux论坛
单片机/MCU论坛
FPGA|CPLD|ASIC论坛
DSP论坛
嵌入式系统论坛
电源技术论坛
电源技术论坛
无线充电技术
硬件设计论坛
PCB设计论坛
电路设计论坛
电子元器件论坛
控制|传感
总线技术|接口技术
测试测量论坛
LabVIEW论坛
Matlab论坛
测试测量技术专区
仪器仪表技术专区
EDA设计论坛
multisim论坛
PADS技术论坛
Protel|AD|DXP论坛
Allegro论坛
proteus论坛|仿真论坛
EasyEDA-中国人自已的EDA工具
Orcad论坛
综合技术与应用
电机控制
智能电网
光电及显示
参考设计中心
汽车电子技术论坛
医疗电子论坛
开源硬件
无线通信论坛
无线通信技术专区
天线|RF射频|微波|雷达技术
IC设计论坛
芯片测试与失效分析
Mixed Signal/SOC[数模混合芯片设计]
Analog/RF IC设计
设计与制造封装测试
厂商专区
TI论坛
TI Deyisupport社区
检测技术与质量
电磁兼容(EMC)设计与整改
安规知识论坛
检测与认证
消费电子论坛
手机技术论坛
平板电脑/mid论坛
音视/视频/机顶盒论坛
电子论坛综合区
聚丰众筹官方社区
新人报道区
聚丰供应链
论坛服务区
供求信息发布
供需广告
招聘┃求职发布区
电子展览展会专区
