MSP430提供的USB官方例程里有一句语法看不懂?求指教!!!里面时钟具体是怎么配置的?我只看见一句话USBHAL_initClocks(8000000); // Config clocks. MCLK=SMCLK=FLL=8MHz; ACLK=REFO=32kHz,这句话如何理解???
具体程序例程见下面: /* --COPYRIGHT--,BSD * Copyright (c) 2014, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * --/COPYRIGHT--*/ /* * ======== main.c ======== * "Simple Send" * * This example shows a very simplified way of sending. This might be used in * an application where the main functionality doesn't change much if a USB * host is present or not. It simply calls USBCDC_sendDataInBackground(); if no * host is present, it simply carries on. * * Simply build, run, and attach to a USB host. Run a terminal application * and open the COM port associated with this device. (In Windows, check the * Device Manager.) The time should be displayed, every second. * * Note that this code is identical to example H9, except for one line of * code: the call to USBCDC_sendDataInBackground() instead of * USBHID_sendDataInBackground(). This reflects the symmetry between writing * MSP430 code for CDC vs. HID-Datapipe. * *+----------------------------------------------------------------------------+ * Please refer to the MSP430 USB API Stack Programmer's Guide, located * in the root directory of this installation for more details. * ---------------------------------------------------------------------------*/ #include #include "driverlib.h" #include "USB_config/descriptors.h" #include "USB_API/USB_Common/device.h" #include "USB_API/USB_Common/u***.h" //USB-specific functions #include "USB_API/USB_CDC_API/U***Cdc.h" #include "USB_app/u***Constructs.h" /* * NOTE: Modify hal.h to select a specific evaluation board and customize for * your own board. */ #include "hal.h" // Function declarations void convertTimeBinToASCII(uint8_t* timeStr); void initRTC(void); // Application globals volatile uint8_t hour = 4, min = 30, sec = 00; // Real-time clock (RTC) values. 4:30:00 volatile uint8_t bSendTimeToHost = FALSE; // RTC-->main(): "send the time over USB" uint8_t timeStr[9]; // Stores the time as an ASCII string /* * ======== main ======== */ void main(void) { WDT_A_hold(WDT_A_BASE); //Stop watchdog timer // Minimum Vcore setting required for the USB API is PMM_CORE_LEVEL_2 PMM_setVCore(PMM_CORE_LEVEL_2); USBHAL_initPorts(); // Config GPIOS for low-power (output low) USBHAL_initClocks(8000000); // Config clocks. MCLK=SMCLK=FLL=8MHz; ACLK=REFO=32kHz USB_setup(TRUE,TRUE); // Init USB & events; if a host is present, connect initRTC(); // Start the real-time clock __enable_interrupt(); // Enable interrupts globally while (1) { // Enter LPM0, which keeps the DCO/FLL active but shuts off the // CPU. For USB, you can't go below LPM0! __bis_SR_register(LPM0_bits + GIE); // If USB is present, sent the time to the host. Flag is set every sec if (bSendTimeToHost) { bSendTimeToHost = FALSE; convertTimeBinToASCII(timeStr); // This function begins the USB send operation, and immediately // returns, while the sending happens in the background. // Send timeStr, 9 bytes, to intf #0 (which is enumerated as a // COM port). 1000 retries. (Retries will be attempted if the // previous send hasn't completed yet). If the bus isn't present, // it simply returns and does nothing. if (USBCDC_sendDataInBackground(timeStr, 9, CDC0_INTFNUM, 1000)) { _NOP(); // If it fails, it'll end up here. Could happen if // the cable was detached after the connectionState() } // check, or if somehow the retries failed } } //while(1) } //main() // Starts a real-time clock on TimerA_0. Earlier we assigned ACLK to be driven // by the REFO, at 32768Hz. So below we set the timer to count up to 32768 and // roll over; and generate an interrupt when it rolls over. void initRTC(void) { TA0CCR0 = 32768; TA0CTL = TASSEL_1+MC_1+TACLR; // ACLK, count to CCR0 then roll, clear TAR TA0CCTL0 = CCIE; // Gen int at rollover (TIMER0_A0 vector) } // Timer0 A0 interrupt service routine. Generated when TimerA_0 (real-time // clock) rolls over from 32768 to 0, every second. #if defined(__TI_COMPILER_VERSION__) || (__IAR_SYSTEMS_ICC__) #pragma vector=TIMER0_A0_VECTOR __interrupt void TIMER0_A0_ISR (void) #elif defined(__GNUC__) && (__MSP430__) void __attribute__ ((interrupt(TIMER0_A0_VECTOR))) TIMER0_A0_ISR (void) #else #error Compiler not found! #endif { if (sec++ == 60) { sec = 0; if (min++ == 60) { min = 0; if (hour++ == 24) { hour = 0; } } } bSendTimeToHost = TRUE; // Time to update __bic_SR_register_on_exit(LPM3_bits); // Exit LPM } // Convert a number 'bin' of value 0-99 into its ASCII equivalent. Assumes // str is a two-byte array. void convertTwoDigBinToASCII(uint8_t bin, uint8_t* str) { str[0] = '0'; if (bin >= 10) { str[0] = (bin / 10) + 48; } str[1] = (bin % 10) + 48; } // Convert the binary globals hour/min/sec into a string, of format "hr:mn:sc" // Assumes str is an nine-byte string. void convertTimeBinToASCII(uint8_t* str) { uint8_t hourStr[2], minStr[2], secStr[2]; convertTwoDigBinToASCII(hour, hourStr); convertTwoDigBinToASCII(min, minStr); convertTwoDigBinToASCII(sec, secStr); str[0] = hourStr[0]; str[1] = hourStr[1]; str[2] = ':'; str[3] = minStr[0]; str[4] = minStr[1]; str[5] = ':'; str[6] = secStr[0]; str[7] = secStr[1]; str[8] = 'n'; } /* * ======== UNMI_ISR ======== */ #if defined(__TI_COMPILER_VERSION__) || (__IAR_SYSTEMS_ICC__) #pragma vector = UNMI_VECTOR __interrupt void UNMI_ISR (void) #elif defined(__GNUC__) && (__MSP430__) void __attribute__ ((interrupt(UNMI_VECTOR))) UNMI_ISR (void) #else #error Compiler not found! #endif { switch (__even_in_range(SYSUNIV, SYSUNIV_BUSIFG )) { case SYSUNIV_NONE: __no_operation(); break; case SYSUNIV_NMIIFG: __no_operation(); break; case SYSUNIV_OFIFG: UCS_clearFaultFlag(UCS_XT2OFFG); UCS_clearFaultFlag(UCS_DCOFFG); SFR_clearInterrupt(SFR_OSCILLATOR_FAULT_INTERRUPT); break; case SYSUNIV_ACCVIFG: __no_operation(); break; case SYSUNIV_BUSIFG: // If the CPU accesses USB memory while the USB module is // suspended, a "bus error" can occur. This generates an NMI. If // USB is automatically disconnecting in your software, set a // breakpoint here and see if execution hits it. See the // Programmer's Guide for more information. SYSBERRIV = 0; // Clear bus error flag USB_disable(); // Disable } } //Released_Version_5_00_01 |
6个回答
有谁知道,困扰好几天了,求解啊!!!
虽然程序没有看懂,但是调试结果出来了,MCLK=SMCLK=DCOCLKDIV=8MHz;,FLL Reference select is REFLCLK. ACLK=REFO=32kHz
另外,USB通讯时,单片机需要外界高频晶振4MHZ,TONGGUO PPL锁相环为USB通信模块配置精确的48MHZ的参考时钟。从官方技术手册上图:USB通信模式模块结构框图中可以看出提供48MHZ PLL 是有XT1和XT2控制的。我理解的意思是MSP430自带的USB模块通讯是需要外部晶振的。并且要通过寄存器设置,使得能够达到48MHZ PLL 。恩,应该是这样吧,不知道理解的对不对?
+1,不会
我就看看,我也在弄USB
请问u***例程哪里可以找到
2631个成员聚集在这个小组
加入小组MSP430FR5994 使用库函数 定时器触发AD问题请教
1624 浏览 2 评论
2169 浏览 1 评论
4565 浏览 1 评论
2366 浏览 1 评论
1705 浏览 1 评论
706浏览 3评论
1636浏览 2评论
930浏览 0评论
GMT+8, 2024-4-20 21:08 , Processed in 1.079567 second(s), Total 52, Slave 44 queries .
