KeyStone Architecture Literature Number: SPRUGW1B November 2012 Serial Rapid IO (SRIO) 2.3.2 这节 The direct I/O (Load/Store) module serves as the source of all outgoing direct I/O packets. With direct I/O, the RapidIO packet contains the specific address where the data should be stored or read in the destination device. Direct I/O requires that a RapidIO source device keep a local table of addresses for memory within the destination device. Once these tables are established, the RapidIO source controller uses this data to compute the destination address and insert it into the packet header. The RapidIO destination peripheral extracts the destination address from the received 请问下,LSU_REG1 LSU_REG2这两个寄存器填写的地址是真实的内存地址么?还是逻辑的地址? 另外,发送doorbel包的时候,这两个寄存器填写地址是什么?是不是都为0即可? |
1个回答
填写实际地址,参考SRIO例程中的DIO通信测试
http://www.deyisupport.com/question_answer/dsp_arm/c6000_multicore/f/53/t/47664.aspx |
1872 浏览 0 评论
3613 浏览 4 评论
5019 浏览 0 评论
1725 浏览 1 评论
9311 浏览 8 评论
654浏览 2评论
695浏览 1评论
651浏览 1评论
1178浏览 1评论
1174浏览 1评论
GMT+8, 2024-3-29 02:47 , Processed in 0.576561 second(s), Total 44, Slave 38 queries .
版权所有 © 深圳华秋电子有限公司
