如果是手动触发的话,单核能否开启两个channel进行传输?我现在情况是按照例程定义了两个channel,分别映射不同的param,不同的TCC,但是当我第一次手动触发的时候,设置的传递参数是channe1,可是触发完成后发现,中断完成位确是对应的channel2的TCC。后来我发现无论我输入的是channel1 还是channel2,触发的都是channel2 param所对应的传输。。。 |
5个回答
if (CSL_edma3Init(&context) != CSL_SOK)
[ printf ("Error: EDMA module initialization failedn"); ] hModule = CSL_edma3Open(&edmaObj, INSTNUM, NULL, &status); if ( (hModule == NULL) || (status != CSL_SOK)) [ printf ("Error: EDMA module open failedn"); ] chAttr.regionNum = CSL_EDMA3_REGION_GLOBAL; /*GLOBAL*/ chAttr.chaNum= 0; hChannel1 = CSL_edma3ChannelOpen(&chObj, INSTNUM, &chAttr, &status); if ((hChannel1 == NULL) || (status != CSL_SOK)) [ printf ("Error: Unable to open EDMA Channel:%dn", 0); ] chAttr.chaNum= 1; hChannel2 = CSL_edma3ChannelOpen(&chObj, INSTNUM, &chAttr, &status); if ((hChannel2 == NULL) || (status != CSL_SOK)) [ printf ("Error: Unable to open EDMA Channel:%dn", 1); ] if (CSL_edma3HwChannelSetupQue(hChannel1,CSL_EDMA3_QUE_0) != CSL_SOK) [ printf ("Error: EDMA channel setup queue failedn"); ] if (CSL_edma3HwChannelSetupQue(hChannel2,CSL_EDMA3_QUE_0) != CSL_SOK) [ printf ("Error: EDMA channel setup queue failedn"); ] CSL_edma3MapDMAChannelToParamBlock (hModule, 0, 0); CSL_edma3MapDMAChannelToParamBlock (hModule, 1, 1); Param0= CSL_edma3GetParamHandle(hChannel1, 0, &status); if (Param0 == NULL) [ printf ("Error: EDMA Get Parameter Entry failed for paramID.n"); ] Param1= CSL_edma3GetParamHandle(hChannel2, 1, &status); if (Param1 == NULL) [ printf ("Error: EDMA Get Parameter Entry failed for paramID.n"); ] myParamSetup.option = CSL_EDMA3_OPT_MAKE(CSL_EDMA3_ITCCH_DIS, CSL_EDMA3_TCCH_DIS, CSL_EDMA3_ITCINT_DIS, CSL_EDMA3_TCINT_EN, 0, CSL_EDMA3_TCC_NORMAL, CSL_EDMA3_FIFOWIDTH_NONE, CSL_EDMA3_STATIC_DIS, CSL_EDMA3_SYNC_AB, CSL_EDMA3_ADDRMODE_INCR, CSL_EDMA3_ADDRMODE_INCR ); myParamSetup.srcAddr = (Uint32)DDR;//源地址 myParamSetup.aCntbCnt = CSL_EDMA3_CNT_MAKE(4,512);//因为传输的是Uint32,所以每次array跳变是4byte,一共跳变512 myParamSetup.dstAddr = (Uint32)mem;//目的地址,L2地址必须用全局地址 myParamSetup.srcDstBidx = CSL_EDMA3_BIDX_MAKE(4,4); myParamSetup.linkBcntrld= CSL_EDMA3_LINKBCNTRLD_MAKE(0xFFFF,0);//无link myParamSetup.srcDstCidx = CSL_EDMA3_CIDX_MAKE(0,1); myParamSetup.cCnt = 1; if(CSL_edma3ParamSetup(Param0,&myParamSetup) != CSL_SOK) [ printf ("Error: EDMA Parameter Entry Setup failedn"); ] myParamSetup.option = CSL_EDMA3_OPT_MAKE(CSL_EDMA3_ITCCH_DIS, CSL_EDMA3_TCCH_DIS, CSL_EDMA3_ITCINT_DIS, CSL_EDMA3_TCINT_EN, 1, CSL_EDMA3_TCC_NORMAL, CSL_EDMA3_FIFOWIDTH_NONE, CSL_EDMA3_STATIC_DIS, CSL_EDMA3_SYNC_AB, CSL_EDMA3_ADDRMODE_INCR, CSL_EDMA3_ADDRMODE_INCR ); myParamSetup.srcAddr = (Uint32)mem;//源地址 myParamSetup.aCntbCnt = CSL_EDMA3_CNT_MAKE(4,512);//因为传输的是Uint32,所以每次array跳变是4byte,一共跳变512 myParamSetup.dstAddr = (Uint32)L2+ (0x10000000);//目的地址,L2地址必须用全局地址 myParamSetup.srcDstBidx = CSL_EDMA3_BIDX_MAKE(4,4); myParamSetup.linkBcntrld= CSL_EDMA3_LINKBCNTRLD_MAKE(0xFFFF,0);//无link myParamSetup.srcDstCidx = CSL_EDMA3_CIDX_MAKE(0,1); myParamSetup.cCnt = 1; if(CSL_edma3ParamSetup(Param1,&myParamSetup) != CSL_SOK) [ printf ("Error: EDMA Parameter Entry Setup failedn"); ] regionIntr.region = CSL_EDMA3_REGION_GLOBAL; regionIntr.intr = 0x0003; //中断使能位必须和所设置的TCC相同 regionIntr.intrh = 0x0000; CSL_edma3HwControl(hModule,CSL_EDMA3_CMD_INTR_ENABLE,®ionIntr); regionIntr.intr = 0x0000; CSL_edma3HwChannelControl(hChannel1,CSL_EDMA3_CMD_CHANNEL_SET,NULL); do [ CSL_edma3GetHwStatus(hModule,CSL_EDMA3_QUERY_INTRPEND,®ionIntr); ] while (!(regionIntr.intr & 0x0001));// CSL_edma3HwControl(hModule,CSL_EDMA3_CMD_INTRPEND_CLEAR,®ionIntr); CSL_edma3HwChannelControl(hChannel1,CSL_EDMA3_CMD_CHANNEL_SET,NULL); do [ CSL_edma3GetHwStatus(hModule,CSL_EDMA3_QUERY_INTRPEND,®ionIntr); ] while (!(regionIntr.intr & 0x0002));// CSL_edma3HwControl(hModule,CSL_EDMA3_CMD_INTRPEND_CLEAR,®ionIntr); |
bisong13 发表于 2018-6-19 03:28 2楼是我的代码 |
注意函数CSL_edma3ChannelOpen的内部实现,其返回值为hEdma = (CSL_Edma3ChannelHandle)pEdmaObj;所以按照你的这种配置顺序,每个channel在调用如下函数open channel时,其输入第一个参数必须不一样,否则返回值只会记录最后一个channel的参数,所以你的代码中在后面enable channel时使能的始终是channel2.
CSL_Edma3ChannelHandle CSL_edma3ChannelOpen ( CSL_Edma3ChannelObj* pEdmaObj, CSL_InstNum edmaNum, CSL_Edma3ChannelAttr* pChAttr, CSL_Status* pStatus ) |
zbb9612 发表于 2018-6-19 04:11 感谢!! |
1872 浏览 0 评论
3614 浏览 4 评论
5020 浏览 0 评论
1725 浏览 1 评论
9311 浏览 8 评论
654浏览 2评论
697浏览 1评论
651浏览 1评论
1178浏览 1评论
1174浏览 1评论
GMT+8, 2024-3-29 16:12 , Processed in 0.870377 second(s), Total 80, Slave 64 queries .
版权所有 © 深圳华秋电子有限公司
