我用28035实现如下功能: PWM1的计数器为零时触发一路AD采样,为周期时触发另外一路AD采样,同时PWM1和PWM2的计数器是同步的。具体设置见下面。 问题是:PWM1的计数器为零时触发AD采样和PWM1和PWM2的计数器同步两个同时存在时,则pwm输出完全乱掉了,不只是pwm1和pwm2,连pwm3和pwm6都乱掉了,如果注释掉红字的一行或者绿色的三行都能正常运行。就是说pwm1过零时同时触发ad和pwm同步信号就有问题,而单独执行一个就ok,我在手册里没有看到说这两个不能同时设置。 请问上述问题是我设置不对还是别的问题?有没有好的解决办法? EPwm3Regs.TBPRD = 3124; EPwm3Regs.TBPHS.half.TBPHS = 0x0000; EPwm3Regs.TBCTR = 0x0000; EPwm3Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP; EPwm3Regs.TBCTL.bit.PHSEN = TB_DISABLE; EPwm3Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; EPwm3Regs.TBCTL.bit.CLKDIV = TB_DIV1; EPwm3Regs.CMPA.half.CMPA = 1500; EPwm3Regs.AQCTLB.all = 0x0018; EPwm6Regs.TBPRD = 3124; EPwm6Regs.TBPHS.half.TBPHS = 0x0000; EPwm6Regs.TBCTR = 0x0000; EPwm6Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP; EPwm6Regs.TBCTL.bit.PHSEN = TB_DISABLE; EPwm6Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; EPwm6Regs.TBCTL.bit.CLKDIV = TB_DIV1; EPwm6Regs.CMPA.half.CMPA = 0; EPwm6Regs.AQCTLB.all = 0x0018; EPwm1Regs.TBPRD = 1500; EPwm1Regs.TBPHS.half.TBPHS = 0x0000; EPwm1Regs.TBCTR = 0x0000; EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE; EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; EPwm1Regs.TBCTL.bit.PRDLD = TB_SHADOW; EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV1; EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_CTR_ZERO; EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_PRD; EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_PRD; EPwm1Regs.CMPA.half.CMPA = 0; EPwm1Regs.CMPB = 0; EPwm1Regs.AQCTLA.all = 0x0090; EPwm1Regs.AQCTLB.all = 0x0900; EPwm1Regs.ETSEL.bit.SOCAEN = 1; EPwm1Regs.ETSEL.bit.SOCASEL = 1; EPwm1Regs.ETSEL.bit.SOCBEN = 1; EPwm1Regs.ETSEL.bit.SOCBSEL = 2; EPwm1Regs.ETPS.bit.SOCAPRD = 1; EPwm1Regs.ETPS.bit.SOCBPRD = 1; EPwm2Regs.TBPRD = 1500; EPwm2Regs.TBPHS.half.TBPHS = 0x0000; EPwm2Regs.TBCTR = 0x0000; EPwm2Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; EPwm2Regs.TBCTL.bit.PHSEN = TB_ENABLE; EPwm2Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; EPwm2Regs.TBCTL.bit.CLKDIV = TB_DIV1; EPwm2Regs.TBCTL.bit.PRDLD = TB_SHADOW; // EPwm2Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_DISABLE; EPwm2Regs.CMPCTL.bit.LOADAMODE = CC_CTR_PRD; EPwm2Regs.CMPCTL.bit.LOADBMODE = CC_CTR_PRD; EPwm2Regs.CMPA.half.CMPA = 0; EPwm2Regs.CMPB = 0; EPwm2Regs.AQCTLA.all = 0x0090; EPwm2Regs.AQCTLB.all = 0x0900; |
1个回答
应该是可以设置的,但也没看出来你的代码有什么问题,不知道你说的PWM输出乱了是个具体的什么情况?
另外,是否有在以上的ePWM初始化之前先关闭同步时钟信号(EALLOW;SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 0; EDIS;),初始化完之后再打开(EALLOW;SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 1; EDIS;)? 如果可以,建议将程序简化以排除其它因素的影响(猜测是某些顺序导致?),或者将整个工程共享出来测试一下。 If a post answers your question, please mark it with the "verify answer" button. |
1898 浏览 0 评论
3648 浏览 4 评论
5032 浏览 0 评论
1736 浏览 1 评论
9382 浏览 8 评论
669浏览 2评论
714浏览 1评论
676浏览 1评论
1197浏览 1评论
1773浏览 1评论
GMT+8, 2024-4-25 02:48 , Processed in 0.714880 second(s), Total 76, Slave 60 queries .
