library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity Second is port (clk,en,res,add,sub:in std_logic;----en使能,res清零,add加,sub减,co进位 sec0,sec1:out std_logic_vector(3 downto 0); co :out std_logic); end Second; architecture sec of Second is begin process(clk,en,res,add,sub) variable s0,s1:std_logic_vector(3 downto 0):="0000"; begin if rising_edge (clk) then s1:=s1+1; s0:=s0+1; end if; sec1<=s1; sec0<=s0; end process; end sec; ---------------------------------------- library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; entity l222 is port ( Clk:in STD_LOGIC;--输入1khz时钟 Rst:in STD_LOGIC;--复位信号 Data:inout STD_LOGIC_VECTOR(7 downto 0);--LCD数据总线 LCDRst,EN,RW,RS:out STD_LOGIC;--LCD控制信号 LED:out STD_LOGIC; sec0,sec1,min0,min1,hour0,hour1,day0,day1,mon0,mon1,year0,year1,year2,year3,week:in STD_LOGIC_VECTOR(3 downto 0) ); end l222; architecture behave of l222 is signal DClk:STD_LOGIC; signal pLED:STD_LOGIC; - ------ begin ------------------------------ LCDRst<='1'; LED<=pLED; ------------------------------ process(Clk,Rst) variable Cnt:INTEGER range 0 to 500; variable a: integer range 0 to 4:=0; variable q: integer range 0 to 20:=1; variable p: integer range 0 to 31:=0; variable c: integer range 1 to 16:=1; variable b: integer range 1 to 16:=1; variable d: integer range 1 to 16:=1; begin if (Rst='0') then EN<='0'; RW<='1'; RS<='0'; Cnt:=0; pLED<='0'; elsif rising_edge (Clk) then Cnt:=Cnt+1; if Cnt=41 then p:=1; elsif Cnt>41 then p:=p+1; if p=11 then p:=1; end if; end if; case Cnt is when 1 => RS<='0';--指令 when 2 => RW<='0';--写 when 3 => EN<='0'; when 4 => Data<=X"30";--基本指令集 when 6 => EN<='1'; when 8 => EN<='0'; when 9 => RW<='1'; when 10 => RS<='0'; when 11 => RS<='0';--指令 when 12 => RW<='0';--写 when 13 => EN<='0'; when 14 => Data<=X"01";--清屏 when 16 => EN<='1'; when 18 => EN<='0'; when 19 => RW<='1'; when 20 => RS<='0'; when 31 => RS<='0';--指令 when 32 => RW<='0';--写 when 33 => EN<='0'; when 34 => Data<=X"0C";--开显示 when 36 => EN<='1'; when 38 => EN<='0'; when 39 => RW<='1'; when 40 => RS<='0'; --when 41 to 190 =>---- -- if p=1 then -- if a=0 then RS<='0'; -- elsif a=1 or a=2 then RS<='1'; -- end if; --elsif p=2 then RW<='0'; --elsif p=3 then EN<='0'; -- elsif p=4 then Data<=aaa(c); c:=c+1; -- elsif p=6 then EN<='1'; -- elsif p=7 then EN<='0'; -- elsif p=8 then RW<='1'; -- elsif p=9 then RS<='0'; a:=a+1; -- if a=3 then a:=0; -- end if; --end if; ----------------------------------------------------------------------------------年------------------ when 201 => RS<='0';--指令 when 202 => RW<='0';--写 when 203 => EN<='0'; when 204 => Data<=X"80";- when 206 => EN<='1'; when 208 => EN<='0'; when 209 => RW<='1'; when 210 => RS<='0'; when 211 => RS<='1';--指令 when 212 => RW<='0';--写 when 213 => EN<='0'; when 214 => case sec1 is when "0000" => Data<=X"31"; when "0001" => Data<=X"31"; when "0010" => Data<=X"32"; when "0011" => Data<=X"33";-- when "0100" => Data<=X"34"; when "0101" => Data<=X"35"; when "0110" => Data<=X"36"; when "0111" => Data<=X"37"; when "1000" => Data<=X"38"; when "1001" => Data<=X"39"; when others => null; end case; when 216 => EN<='1'; when 218 => EN<='0'; when 219 => RW<='1'; when 220 => RS<='0'; when 221 => RS<='1';--指令 when 222 => RW<='0';--写 when 223 => EN<='0'; when 224 => case sec0 is when "0000" => Data<=X"30"; when "0001" => Data<=X"31"; when "0010" => Data<=X"32"; when "0011" => Data<=X"33";-- when "0100" => Data<=X"34"; when "0101" => Data<=X"35"; when "0110" => Data<=X"36"; when "0111" => Data<=X"37"; when "1000" => Data<=X"38"; when "1001" => Data<=X"39"; when others => null; end case; when 226 => EN<='1'; when 228 => EN<='0'; when 229 => RW<='1'; when 230 => RS<='0'; ------------------------------------------------ --------------------------------------------- when 500 => Cnt:=210;pLED<='1'; when others => null; end case; end if; end process; -------------------------------- end behave; -------------------------------- 应有现象00 01 02 03.。。。。。。。。 可真实现象为00 00 00 00 00
2 个讨论
834 浏览 0 评论
371 浏览 0 评论
1094 浏览 0 评论
382 浏览 0 评论
FPGA零基础学习系列精选:半导体存储器和可编程逻辑器件简介
1018 浏览 0 评论
1453 浏览 36 评论
GMT+8, 2024-4-24 20:01 , Processed in 0.440115 second(s), Total 34, Slave 27 queries .
