[问答] 关于EXTI几个问题请教。
[复制链接]
技术员
发表于 2018-1-14 21:53:23   418 查看 0 回复 显示全部楼层 倒序浏览
分享
/* 在 stm32f10x_conf.h 文件中,
第72行  #define assert_param(expr) ((void)0)                // expr:1:返回(void)0,expr:0:返回什么?
#ifdef  USE_FULL_ASSERT                //如果定义了USE_FULL_ASSERT
  * @Brief  The assert_param macro is used for function's parameters check.
  * @param  expr: If expr is false, it calls assert_failed function which reports
  *         the name of the source file and the source line number of the call
  *         that failed. If expr is true, it returns no value.
  * @retval None
  #define assert_param(expr) ((expr) ? (void)0 : assert_failed((uint8_t *)__FILE__, __LINE__))                //定义这个宏,expr:1:返回(void)0,expr:0:调用assert_failed函数,返回源文件名,和引起错误的线号。
/* Exported functions ------------------------------------------------------- */
  void assert_failed(uint8_t* file, uint32_t line);
#else                //否则,定义下面这个宏,
#endif /* USE_FULL_ASSERT */
/*  在        stm32f10x_gpio.h 文件中,
        267行,是什么意思?
        #define IS_GPIO_EXTI_PORT_SOURCE(PORTSOURCE) (((PORTSOURCE) == GPIO_PortSourceGPIOA) || \
                                              ((PORTSOURCE) == GPIO_PortSourceGPIOB) || \
                                              ((PORTSOURCE) == GPIO_PortSourceGPIOC) || \
                                              ((PORTSOURCE) == GPIO_PortSourceGPIOD) || \
                                              ((PORTSOURCE) == GPIO_PortSourceGPIOE) || \
                                              ((PORTSOURCE) == GPIO_PortSourceGPIOF) || \
                                              ((PORTSOURCE) == GPIO_PortSourceGPIOG))
        后面这么多赋值,相或,是什么意思?
        50--56行,是什么意思?
        typedef enum
  EXTI_Mode_Interrupt = 0x00,                //EXTI_IMR的偏移地址?
  EXTI_Mode_Event = 0x04                                //EXTI_EMR的偏移地址?
}EXTIMode_TypeDef;
#define IS_EXTI_MODE(MODE) (((MODE) == EXTI_Mode_Interrupt) || ((MODE) == EXTI_Mode_Event))
        //上面这句是?意思
/*  在        stm32f10x_exti.h 文件中,
void EXTI_Init(EXTI_InitTypeDef* EXTI_InitStruct)
  uint32_t tmp = 0;
  /* Check the parameters */
  assert_param(IS_EXTI_MODE(EXTI_InitStruct->EXTI_Mode));
  assert_param(IS_EXTI_TRIGGER(EXTI_InitStruct->EXTI_Trigger));
  assert_param(IS_EXTI_LINE(EXTI_InitStruct->EXTI_Line));
  assert_param(IS_FUNCTIONAL_STATE(EXTI_InitStruct->EXTI_LineCmd));
  tmp = (uint32_t)EXTI_BASE;        //tmp        取 EXTI_BASE 基地址,
  if (EXTI_InitStruct->EXTI_LineCmd != DISABLE)                        // EXTI_LineCmd 使能时,
    /* Clear EXTI line configuration */
    EXTI->IMR &= ~EXTI_InitStruct->EXTI_Line;                //EXTI_Line0 取反,再跟 EXTI->IMR 相与,那 EXTI->IMR 岂不是被屏蔽了?
    EXTI->EMR &= ~EXTI_InitStruct->EXTI_Line;                //EXTI_Line0 取反,再跟 EXTI->EMR 相与,那 EXTI->EMR 岂不是被屏蔽了?
    tmp += EXTI_InitStruct->EXTI_Mode;                                        //tmp + 模式地址,
    *(__IO uint32_t *) tmp |= EXTI_InitStruct->EXTI_Line;                //tmp 与上 (uint32_t)0x00001 岂不是只有0X0000 0001了?
    /* Clear Rising Falling edge configuration */
    EXTI->RTSR &= ~EXTI_InitStruct->EXTI_Line;                //EXTI->RTSR  线0的上升沿触发初岂不是被屏蔽了?
    EXTI->FTSR &= ~EXTI_InitStruct->EXTI_Line;                //EXTI->FTSR  线0的下降沿触发初岂不是被屏蔽了?
    /* Select the trigger for the selected external interrupts */
    if (EXTI_InitStruct->EXTI_Trigger == EXTI_Trigger_Rising_Falling)        //EXTI_Trigger_Rising_Falling = 0x10 是 SWIER 的地址了?
      /* Rising Falling edge */
      EXTI->RTSR |= EXTI_InitStruct->EXTI_Line;//上升沿可以触发
      EXTI->FTSR |= EXTI_InitStruct->EXTI_Line;//下降沿可以触发
    else        //如果不是上升沿/下降沿同时触发,
      tmp = (uint32_t)EXTI_BASE;                                                //指向基地址,
      tmp += EXTI_InitStruct->EXTI_Trigger;        //指向EXTI->RTSR地址,
      *(__IO uint32_t *) tmp |= EXTI_InitStruct->EXTI_Line;//使 EXTI->RTSR 写入0X0000 0001,使线0可以上升沿触发。
  else                        // EXTI_LineCmd 不能时,
    tmp += EXTI_InitStruct->EXTI_Mode;        //EXTI_BASE 基地址+0X00,是 EXTI_IMR地址,
    /* Disable the selected external lines */
    *(__IO uint32_t *) tmp &= ~EXTI_InitStruct->EXTI_Line;        // EXTI_IMR 与上 0XFFFF FFFE,b也就是把线0的中断屏蔽了。
高级模式
站长推荐 上一条 /9 下一条
推荐专区
技术干货集中营
专家问答
方案交易
用户帮助┃咨询与建议┃版主议事
工程师杂谈
工程师创意
招聘|求职}工程师职场
论坛电子赛事
社区活动专版
发烧友活动
嵌入式论坛
ARM技术论坛
Android论坛
Linux论坛
单片机/MCU论坛
MSP430技术论坛
FPGA|CPLD|ASIC论坛
STM32/STM8技术论坛
NXP MCU 技术论坛
PIC单片机论坛
DSP论坛
瑞萨单片机论坛
嵌入式系统论坛
电源技术论坛
电源技术论坛
无线充电技术
硬件设计论坛
PCB设计论坛
电路设计论坛
电子元器件论坛
控制|传感
总线技术|接口技术
测试测量论坛
LabVIEW论坛
Matlab论坛
测试测量技术专区
仪器仪表技术专区
EDA设计论坛
multisim论坛
PADS技术论坛
Protel|AD|DXP论坛
Allegro论坛
proteus论坛|仿真论坛
EasyEDA-中国人自已的EDA工具
Orcad论坛
综合技术与应用
电机控制
智能电网
光电及显示
工程资源中心
汽车电子技术论坛
医疗电子论坛
开源硬件
无线通信论坛
无线通信技术专区
天线|RF射频|微波|雷达技术
IC设计论坛
芯片测试与失效分析
Mixed Signal/SOC[数模混合芯片设计]
Analog/RF IC设计
设计与制造封装测试
厂商专区
TI论坛
TI Deyisupport社区
检测技术与质量
电磁兼容(EMC)设计与整改
安规知识论坛
检测与认证
消费电子论坛
手机技术论坛
平板电脑/mid论坛
音视/视频/机顶盒论坛
电子论坛综合区
聚丰众筹官方社区
新人报道区
聚丰供应链
论坛服务区
供求信息发布
供需广告
电子展览展会专区
芯片求购|供应发布区
