版主
发表于 3 天前    楼主|
RL-TCPnet功能测试
      这里专门创建了一个app_tcpnet_lib.c文件用于RL-TCPnet功能的测试,此文件主要实现网络主函数main_TcpNet的调用。
#include "includes.h"
*    函 数 名: TCPnetTest
*    功能说明: TCPent测试函数。
*    形    参: 无
*    返 回 值: 无
void TCPnetTest(void)
     while (1)
         os_evt_wait_or(0x0001, 0xFFFF);
         /* RL-TCPnet主处理函数 */
         while (main_TcpNet() == __TRUE);
回复
点赞 举报
版主
发表于 3 天前    楼主|
HTTP_CGI.c文件中接口函数的实现
     KEIL官网有提供HTTPCGI的接口文件,名为HTTP_CGI.c。我们就是在这个文件上修改实现,主要是函数cgi_process_data和cgi_func,其它函数未使用。关于这两个函数在本章47.7小节有详细讲解,具体实现内容如下:
/*--------------------------- cgi_process_data ------------------------------*/
#include <Net_Config.h>
#include <stdio.h>
#include <string.h>
#include "bsp.h"
* The HTTP server provides a small scripting language.
* The script language is simple and works as follows. Each script line starts
* with a command character, either "i", "t", "c", "#" or ".".
*   "i" - command tells the script interpreter to "include" a file from the
*         virtual file system and output it to the web browser.
*   "t" - command should be followed by a line of text that is to be output
*         to the browser.
*   "c" - command is used to call one of the C functions from the this file.
*         It may be followed by the line of text. This text is passed to
*         'cgi_func()' as a pointer to environment variable.
*   "#' - command is a comment line and is ignored (the "#" denotes a comment)
*   "." - denotes the last script line.
/* at_System.c */
extern  LOCALM localm[];
#define LocM   localm[NETIF_ETH]
/* Net_Config.c */
extern struct tcp_cfg   tcp_config;
extern struct http_cfg  http_config;
#define tcp_NumSocks    tcp_config.NumSocks
#define tcp_socket      tcp_config.Scb
#define http_EnAuth     http_config.EnAuth
#define http_auth_passw http_config.Passw
/* Local variables. */
U8 LEDControl;
/* My structure of CGI status U32 variable. This variable is private for */
/* each HTTP Session and is not altered by HTTP Server. It is only set to  */
/* zero when the cgi_func() is called for the first time.                  */
typedef struct {
  U16 xcnt;
  U16 unused;
} MY_BUF;
#define MYBUF(p)        ((MY_BUF *)p)
* HTTP Server Common Gateway Interface Functions
/*--------------------------- cgi_process_var -------------------------------*/
void cgi_process_var (U8 *qs) {
  /* This function is called by HTTP server to process the Querry_String   */
  /* for the CGI Form GET method. It is called on SUBMIT from the browser. */
  /*.The Querry_String.is SPACE terminated.                                */
  U8 *var;
  int s[4];
  var = (U8 *)alloc_mem (40);
  do {
    /* Loop through all the parameters. */
    qs = http_get_var (qs, var, 40);
    /* Check the returned string, 'qs' now points to the next. */
    if (var[0] != 0) {
      /* Returned string is non 0-length. */
      if (str_scomp (var, "ip=") == __TRUE) {
        /* My IP address parameter. */
        sscanf ((const char *)&var[3], "%d.%d.%d.%d",&s[0],&s[1],&s[2],&s[3]);
        LocM.IpAdr[0]   = s[0];
        LocM.IpAdr[1]   = s[1];
        LocM.IpAdr[2]   = s[2];
        LocM.IpAdr[3]   = s[3];
      else if (str_scomp (var, "msk=") == __TRUE) {
        /* Net mask parameter. */
        sscanf ((const char *)&var[4], "%d.%d.%d.%d",&s[0],&s[1],&s[2],&s[3]);
        LocM.NetMask[0] = s[0];
        LocM.NetMask[1] = s[1];
        LocM.NetMask[2] = s[2];
        LocM.NetMask[3] = s[3];
      else if (str_scomp (var, "gw=") == __TRUE) {
        /* Default gateway parameter. */
        LocM.DefGW[0]   = s[0];
        LocM.DefGW[1]   = s[1];
        LocM.DefGW[2]   = s[2];
        LocM.DefGW[3]   = s[3];
      else if (str_scomp (var, "pdns=") == __TRUE) {
        sscanf ((const char *)&var[5], "%d.%d.%d.%d",&s[0],&s[1],&s[2],&s[3]);
        LocM.PriDNS[0]  = s[0];
        LocM.PriDNS[1]  = s[1];
        LocM.PriDNS[2]  = s[2];
        LocM.PriDNS[3]  = s[3];
      else if (str_scomp (var, "sdns=") == __TRUE) {
        LocM.SecDNS[0]  = s[0];
        LocM.SecDNS[1]  = s[1];
        LocM.SecDNS[2]  = s[2];
        LocM.SecDNS[3]  = s[3];
  }while (qs);
  free_mem ((OS_FRAME *)var);
void cgi_process_data (U8 code, U8 *dat, U16 len) {
  /* This function is called by HTTP server to process the returned Data    */
  /* for the CGI Form POST method. It is called on SUBMIT from the browser. */
  /* Parameters:                                                            */
  /*   code  - callback context code                                        */
  /*           0 = www-url-encoded form data                                */
  /*           1 = filename for file upload (0-terminated string)           */
  /*           2 = file upload raw data                                     */
  /*           3 = end of file upload (file close requested)                */
  /*           4 = any xml encoded POST data (single or last stream)        */
  /*           5 = the same as 4, but with more xml data to follow          */
  /*               Use http_get_content_type() to check the content type    */
  /*   dat   - pointer to POST received data                                */
  /*   len   - received data length                                         */
  U8 *var;
  switch (code) {
    case 0:
      /* Url encoded form data received. */
      break;
    case 1:
      /* Filename for file upload received as encoded by the browser. */
      /* It might contain an absolute path to a file from the sending */
      /* host. Open a file for writing. */
      return;
    case 2:
      /* File content data received. Write data to a file. */
      /* This function will be called several times with   */
      /* code 2 when a big file is being uploaded.         */
      return;
    case 3:
      /* File upload finished. Close a file. */
      return;
    case 4:
      /* XML encoded content type, last packet. */
     // pType = http_get_content_type ();
      /* check the content type for CGX file request. */
      /* pType is a pointer to a 0-terminated string  */
      /* For example: text/xml; charset=utf-8         */
      return;
    case 5:
      /* XML encoded as under 4, but with more to follow. */
      return;
    default:
      /* Ignore all other codes. */
      return;
  if (len == 0) {
    /* No data or all items (radio, checkbox) are off. */
    return;
  do {
    /* Parse all returned parameters. */
    dat = http_get_var (dat, var, 40);
    if (var[0] != 0) {
       if (str_scomp (var, "TICK1=") == __TRUE || str_scomp (var, "pg=") == __TRUE)
          if (str_scomp (var, "pg=") == __TRUE)
              LEDControl = 0;
          if(*(var+9) =='1')
            LEDControl |= 0x01;
          else if(*(var+9) =='2')
            LEDControl |= 0x02;
          else if(*(var+9) =='3')
            LEDControl |= 0x04;
  }while (dat);
  //LED Control
  if(LEDControl & 0x01)
     bsp_LedOn(1);
  else
     bsp_LedOff(1);
  if(LEDControl & 0x02)
     bsp_LedOn(2);
  else
     bsp_LedOff(2);
  if(LEDControl & 0x04)
     bsp_LedOn(3);
  else
     bsp_LedOff(3);
/*--------------------------- cgi_func --------------------------------------*/
U16 cgi_func (U8 *env, U8 *buf, U16 buflen, U32 *pcgi) {
  /* This function is called by HTTP server script interpreter to make a    */
  /* formated output for 'stdout'. It returns the number of bytes written   */
  /* to the output buffer. Hi-bit of return value (len is or-ed with 0x8000)*/
  /* is a repeat flag for the system script interpreter. If this bit is set */
  /* to 1, the system will call the 'cgi_func()' again for the same script  */
  /* line with parameter 'pcgi' pointing to a 4-byte buffer. This buffer    */
  /* can be used for storing different status variables for this function.  */
  /* It is set to 0 by HTTP Server on first call and is not altered by      */
  /* HTTP server for repeated calls. This function should NEVER write more  */
  /* than 'buflen' bytes to the buffer.                                     */
  /* Parameters:                                                            */
  /*   env    - environment variable string                                 */
  /*   buf    - HTTP transmit buffer                                        */
  /*   buflen - length of this buffer (500-1400 bytes - depends on MSS)     */
  /*   pcgi   - pointer to session local buffer used for repeated loops     */
  /*            This is a U32 variable - size is 4 bytes. Value is:         */
  /*            - on 1st call = 0                                           */
  /*            - 2nd call    = as set by this function on first call       */
  U32 len = 0;
  unsigned int mask;
  switch (env[0]) {
    /* Analyze the environment string. It is the script 'c' line starting */
    /* at position 2. What you write to the script file is returned here. */
       case 'T' :
         if(env[1] =='1')
           mask = env[2]-'0';
           len = sprintf((char *)buf,(const char *)&env[4],(LEDControl& mask) ? "checked" : "");
         break;
  return ((U16)len);
/*--------------------------- cgx_content_type ------------------------------*/
#if 0
U8 *cgx_content_type (void) {
  /* User configurable Content-type for CGX script files. If this function */
  /* is missing, or returns a NULL pointer, the default 'text/xml' content */
  /* type from the library is used for xml-script file types.              */
  return ("text/xml; charset=utf-8");
#endif
/*--------------------------- http_encoding ---------------------------------*/
#if 0
U8 *http_encoding (void) {
  /* User configurable character encoding for text types. If this function */
  /* is missing, or returns a NULL pointer, web browser uses a default     */
  /* character encoding, which is set in the browser configuration.        */
  return ("utf-8");
#endif
/*--------------------------- http_accept_host ------------------------------*/
#if 0
BOOL http_accept_host (U8 *rem_ip, U16 rem_port) {
  /* This function checks if a connection from remote host is accepted or  */
  /* not. If this function is missing, all remote hosts are accepted.      */
   if (rem_ip[0] == 192  &&
       rem_ip[1] == 168  &&
       rem_ip[2] == 1    &&
       rem_ip[3] == 1) {
      /* Accept a connection. */
      return (__TRUE);
   /* Deny a connection. */
   return (__FALSE);
#endif
* end of file
回复
点赞 举报
版主
发表于 3 天前    楼主|
47.8.2 STM32F429开发板实验
实验目的:
      1.     学习CGI脚本实现动态网页制作方法和RL-TCPnet的Web服务器实现。
实验内容:
      1.      强烈推荐将网线接到路由器或者交换机上面测试,因为已经使能了DHCP,可以自动获取IP地址。
      2.      用户可在浏览器中直接输入IP地址访问Web服务器,跟大家访问路由器后台一样,也可以通过NetBIOS局域网域名直接访问,即http://armfly/,这样就无需查看具体IP了。
      3.      Web服务器的用户名admin,密码123456。
      4.      例子中利用CGI脚本实现了一个Web浏览器中通过复选框控制LED亮灭的功能。
      5.      关于网页的制作和Web服务器的测试方法,务必看本例子配套的教程,有详细讲解!!!
网页制作:
      详见本章节47.5小节。
配置向导文件设置(Net_Config.c):
      详见本章节47.3小节。
调试文件设置(Net_Debug.c):
      详见本章节47.4小节。
Web服务器访问效果:
      详见本章节47.6小节。
回复
点赞 举报
版主
发表于 3 天前    楼主|
RTX配置:
     RTX配置向导详情如下:
回复
点赞 举报
版主
发表于 3 天前    楼主|
Task Configuration
(1)Number of concurrent running tasks
      允许创建6个任务,实际创建了如下5个任务:
      AppTaskUserIF任务   :按键消息处理。
      AppTaskLED任务     :LED闪烁。
      AppTaskMsgPro任务 :按键检测。
      AppTaskTCPMain任务:RL-TCPnet测试任务。
      AppTaskStart任务  :启动任务,也是最高优先级任务,这里实现RL-TCPnet的时间基准更新。
(2)Number of tasks with user-provided stack
      创建的5个任务都是采用自定义堆栈方式。
(3)Run in privileged mode
      设置任务运行在非特权级模式。
回复
点赞 举报
版主
发表于 3 天前    楼主|
RTX任务调试信息:
回复
点赞 举报
版主
发表于 前天 10:25    楼主|
程序设计:
任务栈大小分配:
      staticuint64_t AppTaskUserIFStk[1024/8];   /* 任务栈 */
      staticuint64_t AppTaskLEDStk[1024/8];      /* 任务栈 */
      staticuint64_t AppTaskMsgProStk[1024/8];  /* 任务栈 */
      staticuint64_t AppTaskTCPMainStk[4096/8]; /* 任务栈 */
       staticuint64_t AppTaskStartStk[1024/8];     /* 任务栈 */
      将任务栈定义成uint64_t类型可以保证任务栈是8字节对齐的,8字节对齐的含义就是数组的首地址对8求余等于0。如果不做8字节对齐的话,部分C语言库函数、浮点运算和uint64_t类型数据运算会出问题。
回复
点赞 举报
版主
发表于 前天 10:26    楼主|
系统栈大小分配:
回复
点赞 举报
版主
发表于 前天 10:26    楼主|
RTX初始化:
*    函 数 名: main
*    功能说明: 标准c程序入口。
*    形    参: 无
*    返 回 值: 无
int main (void)
     /* 初始化外设 */
     bsp_Init();
     /* 创建启动任务 */
     os_sys_init_user (AppTaskStart,              /* 任务函数 */
                       5,                         /* 任务优先级 */
                       &AppTaskStartStk,          /* 任务栈 */
                       sizeof(AppTaskStartStk));  /* 任务栈大小,单位字节数 */
     while(1);
回复
点赞 举报
版主
发表于 前天 10:26    楼主|
硬件外设初始化
      硬件外设的初始化是在 bsp.c 文件实现:
*    函 数 名: bsp_Init
*    功能说明: 初始化所有的硬件设备。该函数配置CPU寄存器和外设的寄存器并初始化一些全局变量。只需要调用一次
*    形    参:无
*    返 回 值: 无
void bsp_Init(void)
         由于ST固件库的启动文件已经执行了CPU系统时钟的初始化,所以不必再次重复配置系统时钟。
         启动文件配置了CPU主时钟频率、内部Flash访问速度和可选的外部SRAM FSMC初始化。
         系统时钟缺省配置为168MHz,如果需要更改,可以修改 system_stm32f4xx.c 文件
     /* 优先级分组设置为4,可配置0-15级抢占式优先级,0级子优先级,即不存在子优先级。*/
     NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);
     SystemCoreClockUpdate();    /* 根据PLL配置更新系统时钟频率变量 SystemCoreClock */
     bsp_InitDWT();      /* 初始化DWT */
     bsp_InitUart();     /* 初始化串口 */
     bsp_InitKey();     /* 初始化按键变量(必须在 bsp_InitTimer() 之前调用) */
     bsp_InitExtIO();    /* FMC总线上扩展了32位输出IO, 操作LED等外设必须初始化 */
     bsp_InitLed();      /* 初始LED指示灯端口 */
回复
点赞 举报
版主
发表于 前天 10:27    楼主|
RTX任务创建:
*    函 数 名: AppTaskCreate
*    功能说明: 创建应用任务
*    形    参: 无
*    返 回 值: 无
static void AppTaskCreate (void)
     HandleTaskUserIF = os_tsk_create_user(AppTaskUserIF,             /* 任务函数 */
                                           1,                         /* 任务优先级 */
                                           &AppTaskUserIFStk,         /* 任务栈 */
                                           sizeof(AppTaskUserIFStk)); /* 任务栈大小,单位字节数 */
     HandleTaskLED = os_tsk_create_user(AppTaskLED,              /* 任务函数 */
                                        2,                       /* 任务优先级 */
                                        &AppTaskLEDStk,          /* 任务栈 */
                                        sizeof(AppTaskLEDStk));  /* 任务栈大小,单位字节数 */
     HandleTaskMsgPro = os_tsk_create_user(AppTaskMsgPro,             /* 任务函数 */
                                           3,                         /* 任务优先级 */
                                           &AppTaskMsgProStk,         /* 任务栈 */
                                           sizeof(AppTaskMsgProStk)); /* 任务栈大小,单位字节数 */
    HandleTaskTCPMain = os_tsk_create_user(AppTaskTCPMain,             /* 任务函数 */
                                           4,                         /* 任务优先级 */
                                           &AppTaskTCPMainStk,         /* 任务栈 */
                                           sizeof(AppTaskTCPMainStk)); /* 任务栈大小,单位字节数 */
回复
点赞 举报
版主
发表于 前天 10:27    楼主|
五个RTX任务的实现:
*    函 数 名: AppTaskUserIF
*    功能说明: 按键消息处理
*    形    参: 无
*    返 回 值: 无
*   优 先 级: 1  (数值越小优先级越低,这个跟uCOS相反)
__task void AppTaskUserIF(void)
     uint8_t ucKeyCode;
    while(1)
         ucKeyCode = bsp_GetKey();
         if (ucKeyCode != KEY_NONE)
              switch (ucKeyCode)
                  /* K1键按下 */
                   case KEY_DOWN_K1:
                       printf("K1键按下\r\n");
                       break;
                   /* K2键按下 */
                   case KEY_DOWN_K2:
                       printf("K2键按下\r\n");
                       break;
                   /* K3键按下 */
                   case KEY_DOWN_K3:
                       printf("K3键按下\r\n");
                       break;
                   /* 其他的键值不处理 */
                   default:
                       break;
         os_dly_wait(20);
*    函 数 名: AppTaskLED
*    功能说明: LED闪烁。
*    形    参: 无
*    返 回 值: 无
*   优 先 级: 2
__task void AppTaskLED(void)
     const uint16_t usFrequency = 500; /* 延迟周期 */
     /* 设置延迟周期 */
     os_itv_set(usFrequency);
    while(1)
         bsp_LedToggle(4);
         /* os_itv_wait是绝对延迟,os_dly_wait是相对延迟。*/
         os_itv_wait();
*    函 数 名: AppTaskMsgPro
*    功能说明: 按键检测
*    形    参: 无
*    返 回 值: 无
*   优 先 级: 3
__task void AppTaskMsgPro(void)
    while(1)
         bsp_KeyScan();
         os_dly_wait(10);
*    函 数 名: AppTaskTCPMain
*    功能说明: RL-TCPnet测试任务
*    形    参: 无
*    返 回 值: 无
*   优 先 级: 4
__task void AppTaskTCPMain(void)
     while (1)
         TCPnetTest();
*    函 数 名: AppTaskStart
*    功能说明: 启动任务,也是最高优先级任务,这里实现RL-TCPnet的时间基准更新。
*    形    参: 无
*    返 回 值: 无
*   优 先 级: 5
__task void AppTaskStart(void)
     /* 初始化RL-TCPnet */
     init_TcpNet ();
     /* 创建任务 */
     AppTaskCreate();
     os_itv_set (100);
    while(1)
         os_itv_wait ();
         /* RL-TCPnet时间基准更新函数 */
         timer_tick ();
         os_evt_set(0x0001, HandleTaskTCPMain);
回复
点赞 举报
版主
发表于 前天 10:27    楼主|
RL-TCPnet功能测试
*    函 数 名: TCPnetTest
*    功能说明: TCPent测试函数。
*    形    参: 无
*    返 回 值: 无
     while (1)
回复
点赞 举报
版主
发表于 前天 10:28    楼主|
#include <stdio.h>
#include <string.h>
#include "bsp.h"
*         to the browser.
/* at_System.c */
/* Net_Config.c */
U8 LEDControl;
typedef struct {
  U16 xcnt;
  U16 unused;
} MY_BUF;
  U8 *var;
  int s[4];
  do {
    if (var[0] != 0) {
  }while (qs);
  /* Parameters:                                                            */
  U8 *var;
  switch (code) {
    case 0:
      break;
    case 1:
      return;
    case 2:
      return;
    case 3:
      return;
    case 4:
      return;
    case 5:
      return;
    default:
      return;
  if (len == 0) {
    return;
  do {
    if (var[0] != 0) {
              LEDControl = 0;
          if(*(var+9) =='1')
            LEDControl |= 0x01;
            LEDControl |= 0x02;
            LEDControl |= 0x04;
  }while (dat);
  //LED Control
     bsp_LedOn(1);
  else
     bsp_LedOff(1);
     bsp_LedOn(2);
  else
     bsp_LedOff(2);
     bsp_LedOn(3);
  else
     bsp_LedOff(3);
  /* Parameters:                                                            */
  U32 len = 0;
  unsigned int mask;
  switch (env[0]) {
       case 'T' :
         if(env[1] =='1')
           mask = env[2]-'0';
         break;
  return ((U16)len);
#if 0
#endif
#if 0
  return ("utf-8");
#endif
#if 0
       rem_ip[1] == 168  &&
       rem_ip[2] == 1    &&
       rem_ip[3] == 1) {
      return (__TRUE);
   return (__FALSE);
#endif
* end of file
#if 0
       rem_ip[1] == 168  &&
       rem_ip[2] == 1    &&
       rem_ip[3] == 1) {
      return (__TRUE);
   return (__FALSE);
#endif
* end of file
回复
点赞 举报
版主
发表于 前天 10:28    楼主|
47.9 总结
      本章节就为大家讲解这么多,其中网页的制作比较麻烦,希望大家实际动手操作一遍,并将其熟练掌握。
回复
点赞 举报
版主
发表于 前天 10:28    楼主|
分享完成,,,,
回复
举报
高级模式
站长推荐 上一条 /7 下一条
推荐专区
技术干货集中营
专家问答
用户帮助┃咨询与建议┃版主议事
工程师杂谈
工程师创意
工程师职场
论坛电子赛事
社区活动专版
发烧友活动
嵌入式论坛
ARM技术论坛
Android论坛
Linux论坛
单片机/MCU论坛
FPGA|CPLD|ASIC论坛
DSP论坛
嵌入式系统论坛
电源技术论坛
电源技术论坛
无线充电技术
硬件设计论坛
PCB设计论坛
电路设计论坛
电子元器件论坛
控制|传感
总线技术|接口技术
测试测量论坛
LabVIEW论坛
Matlab论坛
测试测量技术专区
仪器仪表技术专区
EDA设计论坛
multisim论坛
PADS技术论坛
Protel|AD|DXP论坛
Allegro论坛
proteus论坛|仿真论坛
EasyEDA-中国人自已的EDA工具
Orcad论坛
综合技术与应用
电机控制
智能电网
光电及显示
参考设计中心
汽车电子技术论坛
医疗电子论坛
开源硬件
无线通信论坛
无线通信技术专区
天线|RF射频|微波|雷达技术
IC设计论坛
芯片测试与失效分析
Mixed Signal/SOC[数模混合芯片设计]
Analog/RF IC设计
设计与制造封装测试
厂商专区
TI论坛
TI Deyisupport社区
检测技术与质量
电磁兼容(EMC)设计与整改
安规知识论坛
检测与认证
消费电子论坛
手机技术论坛
平板电脑/mid论坛
音视/视频/机顶盒论坛
电子论坛综合区
聚丰众筹官方社区
新人报道区
聚丰供应链
论坛服务区
供求信息发布
供需广告
招聘┃求职发布区
电子展览展会专区
