回帖奖励 3 分积分 回复本帖可获得 3 分积分奖励! 每人限 1 次(中奖概率 80%)
[问答] ORCAD原理图问题,在画原理图时输出网表时老报这样的错
[复制链接]
实习生
发表于 2017-12-17 17:45:05   1038 查看 2 回复 显示全部楼层 倒序浏览
分享
在画原理图时输出网表时老报这样的错,谁知道啊
#1 WARNING(ORCAP-36006): Part Name "008_LENS_JACK_0_IRCUT_JACK_20_3_008_LENS_JACK_0" is renamed to "008_LENS_JACK_0_IRCUT_JACK_20_3".
#2 WARNING(ORCAP-36006): Part Name "ZH_2X16_LT_0_HEAD2X16_SMT_20MIL_ZH_2X16_LT_0" is renamed to "ZH_2X16_LT_0_HEAD2X16_SMT_20MIL".
#3 WARNING(ORCAP-36006): Part Name "HOLE1_0_MTG212C135_300CL_HOLE1_0" is renamed to "HOLE1_0_MTG212C135_300CL_HOLE1_".
#4 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R19 and R18 for part "R".
              VALUE
#5 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R20 and R18 for part "R".
              VALUE
#6 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R21 and R18 for part "R".
              VALUE
#7 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R22 and R18 for part "R".
              VALUE
#8 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R23 and R18 for part "R".
              VALUE
#9 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R24 and R18 for part "R".
              VALUE
#10 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R25 and R18 for part "R".
              VALUE
#11 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R26 and R18 for part "R".
              VALUE
#12 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R27 and R18 for part "R".
              VALUE
#13 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R28 and R18 for part "R".
              VALUE
#14 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R29 and R18 for part "R".
              VALUE
#15 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R30 and R18 for part "R".
              VALUE
#16 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R32 and R18 for part "R".
              VALUE
#17 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R33 and R18 for part "R".
              VALUE
#18 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R34 and R18 for part "R".
              VALUE
#19 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R35 and R18 for part "R".
              VALUE
#20 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R36 and R18 for part "R".
              VALUE
#21 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R37 and R18 for part "R".
              VALUE
#22 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R38 and R18 for part "R".
              VALUE
#23 ERROR(ORCAP-36001): Conflicting values of Source Part names found on R39(R_0603) and R18(R_0402) for part "R".
#24 ERROR(ORCAP-36001): Conflicting values of Source Part names found on R40(R_0603) and R18(R_0402) for part "R".
#25 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R41 and R18 for part "R".
              VALUE
#26 ERROR(ORCAP-36001): Conflicting values of Source Part names found on R42(R_0603) and R18(R_0402) for part "R".
#27 ERROR(ORCAP-36001): Conflicting values of Source Part names found on R43(R_0603) and R18(R_0402) for part "R".
#28 ERROR(ORCAP-36001): Conflicting values of Source Part names found on R44(R_0603) and R18(R_0402) for part "R".
#29 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R54 and R18 for part "R".
              VALUE
#30 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R55 and R18 for part "R".
              VALUE
#31 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R56 and R18 for part "R".
              VALUE
#32 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R57 and R18 for part "R".
              VALUE
#33 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R60 and R18 for part "R".
              VALUE
#34 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R61 and R18 for part "R".
              VALUE
#35 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R62 and R18 for part "R".
              VALUE
#36 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R63 and R18 for part "R".
              VALUE
#37 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R64 and R18 for part "R".
              VALUE
#38 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R65 and R18 for part "R".
              VALUE
#39 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R66 and R18 for part "R".
              VALUE
#40 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R67 and R18 for part "R".
              VALUE
#41 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R68 and R18 for part "R".
              VALUE
#42 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R69 and R18 for part "R".
              VALUE
#43 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R70 and R18 for part "R".
              VALUE
#44 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R71 and R18 for part "R".
              VALUE
#45 ERROR(ORCAP-36003): Conflicting values of following Component Definition properties found on R72 and R18 for part "R".
              VALUE
#46 WARNING(ORCAP-36006): Part Name "AP1511B_0_SOT-26_SOT23-6_AP1511B" is renamed to "AP1511B_0_SOT-26_SOT23-6_AP1511".
#47 WARNING(ORCAP-36006): Part Name "SGM2019-XV_1_SOT-23-5_SGM2019-2.8V" is renamed to "SGM2019-XV_1_SOT-23-5_SGM2019-2".
#48 WARNING(ORCAP-36006): Part Name "SGM2019-XV_1_SOT-23-5_SGM2019-1.8V" is renamed to "SGM2019-XV_1_SOT-23-5_SGM2019-1".
#49 WARNING(ORCAP-36006): Part Name "27M_OSC3225_0_OSC3225_27M_OSC3225_0" is renamed to "27M_OSC3225_0_OSC3225_27M_OSC32".
#50 ERROR(ORCAP-36018): Aborting Netlisting... Please correct the above errors and retry.
标签:ORCAD
实习生
发表于 2017-12-25 10:15:33
回帖奖励 +3 分积分
命名冲突了
回复
点赞 举报
试用达人
发表于 2018-1-11 13:09:45
回帖奖励 +3 分积分
封装与原理图中的引脚名不一样。
回复
点赞 举报
高级模式
站长推荐 上一条 /9 下一条
推荐专区
技术干货集中营
专家问答
方案交易
用户帮助┃咨询与建议┃版主议事
工程师杂谈
工程师创意
招聘|求职}工程师职场
论坛电子赛事
社区活动专版
发烧友活动
嵌入式论坛
ARM技术论坛
Android论坛
Linux论坛
单片机/MCU论坛
MSP430技术论坛
FPGA|CPLD|ASIC论坛
STM32/STM8技术论坛
NXP MCU 技术论坛
PIC单片机论坛
DSP论坛
瑞萨单片机论坛
嵌入式系统论坛
电源技术论坛
电源技术论坛
无线充电技术
硬件设计论坛
PCB设计论坛
电路设计论坛
电子元器件论坛
控制|传感
总线技术|接口技术
测试测量论坛
LabVIEW论坛
Matlab论坛
测试测量技术专区
仪器仪表技术专区
EDA设计论坛
multisim论坛
PADS技术论坛
Protel|AD|DXP论坛
Allegro论坛
proteus论坛|仿真论坛
EasyEDA-中国人自已的EDA工具
Orcad论坛
综合技术与应用
电机控制
智能电网
光电及显示
工程资源中心
汽车电子技术论坛
医疗电子论坛
开源硬件
无线通信论坛
无线通信技术专区
天线|RF射频|微波|雷达技术
IC设计论坛
芯片测试与失效分析
Mixed Signal/SOC[数模混合芯片设计]
Analog/RF IC设计
设计与制造封装测试
厂商专区
TI论坛
TI Deyisupport社区
检测技术与质量
电磁兼容(EMC)设计与整改
安规知识论坛
检测与认证
消费电子论坛
手机技术论坛
平板电脑/mid论坛
音视/视频/机顶盒论坛
电子论坛综合区
聚丰众筹官方社区
新人报道区
聚丰供应链
论坛服务区
供求信息发布
供需广告
电子展览展会专区
芯片求购|供应发布区
