下面是ti提供的一个源代码:
/* ============================================================================== System Name: HVACI_Sensored File Name: HVACI_Sensored.C Description: Primary system file for the Real Implementation of Sensored Field Orientation Control for Induction Motors. Supports F2803x. ================================================================================= */ // Include header files used in the main function #include "PeripheralHeaderIncludes.h" #define MATH_TYPE IQ_MATH #include "IQmathLib.h" #include "HVACI_Sensored.h" #include "HVACI_Sensored-Settings.h" #include #ifdef FLASH #pragma CODE_SECTION(MainISR,"ramfuncs"); #pragma CODE_SECTION(OffsetISR,"ramfuncs"); #endif // Prototype statements for functions found within this file. interrupt void MainISR(void); interrupt void OffsetISR(void); void DeviceInit(); void MemCopy(); void InitFlash(); void HVDMC_Protection(void); // State Machine function prototypes //------------------------------------ // Alpha states void A0(void); //state A0 void B0(void); //state B0 void C0(void); //state C0 // A branch states void A1(void); //state A1 void A2(void); //state A2 void A3(void); //state A3 // B branch states void B1(void); //state B1 void B2(void); //state B2 void B3(void); //state B3 // C branch states void C1(void); //state C1 void C2(void); //state C2 void C3(void); //state C3 // Variable declarations void (*Alpha_State_Ptr)(void); // Base States pointer void (*A_Task_Ptr)(void); // State pointer A branch void (*B_Task_Ptr)(void); // State pointer B branch void (*C_Task_Ptr)(void); // State pointer C branch // Used for running BackGround in flash, and ISR in RAM extern Uint16 *RamfuncsLoadStart, *RamfuncsLoadEnd, *RamfuncsRunStart; int16 VTimer0[4]; // Virtual Timers slaved off CPU Timer 0 (A events) int16 VTimer1[4]; // Virtual Timers slaved off CPU Timer 1 (B events) int16 VTimer2[4]; // Virtual Timers slaved off CPU Timer 2 (C events) int16 SerialCommsTimer; // Global variables used in this system float32 T = 0.001/ISR_FREQUENCY; // Samping period (sec), see HVACI_Sensored-Settings.H Uint16 OffsetFlag=0; _iq offsetA=0; _iq offsetB=0; _iq offsetC=0; _iq K1=_IQ(0.998); //Offset filter coefficient K1: 0.05/(T+0.05); _iq K2=_IQ(0.001999); //Offset filter coefficient K2: T/(T+0.05); extern _iq IQsinTable[]; extern _iq IQcosTable[]; _iq VdTesting = _IQ(0.2); // Vd reference (pu) _iq VqTesting = _IQ(0.2); // Vq reference (pu) _iq IdRef = _IQ(0.1); // Id reference (pu) _iq IqRef = _IQ(0.05); // Iq reference (pu) _iq SpeedRef = _IQ(0.3); // Speed reference (pu) Uint32 IsrTicker = 0; Uint16 BackTicker = 0; Uint16 lsw=0; // LoopSwitch Uint16 TripFlagDMC=0; // PWM trip status // Default ADC initialization int ChSel[16] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}; int TrigSel[16] = {5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5}; int ACQPS[16] = {8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8}; int16 DlogCh1 = 0; int16 DlogCh2 = 0; int16 DlogCh3 = 0; int16 DlogCh4 = 0; volatile Uint16 EnableFlag = FALSE; Uint16 SpeedLoopPrescaler = 10; // Speed loop prescaler Uint16 SpeedLoopCount = 1; // Speed loop counter // Instance a current model object CURMOD cm1 = CURMOD_DEFAULTS; // Instance a current model constant object CURMOD_CONST cm1_const = CURMOD_CONST_DEFAULTS; // Instance a QEP interface driver QEP qep1 = QEP_DEFAULTS; // Instance a Capture interface driver CAPTURE cap1 = CAPTURE_DEFAULTS; // Instance a few transform objects (ICLARKE is added into SVGEN module) CLARKE clarke1 = CLARKE_DEFAULTS; PARK park1 = PARK_DEFAULTS; IPARK ipark1 = IPARK_DEFAULTS; // Instance PI regulators to regulate the d and q axis currents, and speed PI_CONTROLLER pi_spd = PI_CONTROLLER_DEFAULTS; PI_CONTROLLER pi_id = PI_CONTROLLER_DEFAULTS; PI_CONTROLLER pi_iq = PI_CONTROLLER_DEFAULTS; // Instance a PWM driver instance PWMGEN pwm1 = PWMGEN_DEFAULTS; // Instance a PWM DAC driver instance PWMDAC pwmdac1 = PWMDAC_DEFAULTS; // Instance a Space Vector PWM modulator. This modulator generates a, b and c // phases based on the d and q stationery reference frame inputs SVGEN svgen1 = SVGEN_DEFAULTS; // Instance a ramp controller to smoothly ramp the frequency RMPCNTL rc1 = RMPCNTL_DEFAULTS; // Instance a ramp(sawtooth) generator to simulate an Anglele RAMPGEN rg1 = RAMPGEN_DEFAULTS; // Instance a speed calculator based on QEP SPEED_MEAS_QEP speed1 = SPEED_MEAS_QEP_DEFAULTS; // Instance a speed calculator based on capture Qep (for eQep of 280x only) SPEED_MEAS_CAP speed2 = SPEED_MEAS_CAP_DEFAULTS; // Create an instance of DATALOG Module DLOG_4CH dlog = DLOG_4CH_DEFAULTS; void main(void) { DeviceInit(); // Device Life support & GPIO // Only used if running from FLASH // Note that the variable FLASH is defined by the compiler #ifdef FLASH // Copy time critical code and Flash setup code to RAM // The RamfuncsLoadStart, RamfuncsLoadEnd, and RamfuncsRunStart // symbols are created by the linker. Refer to the linker files. MemCopy(&RamfuncsLoadStart, &RamfuncsLoadEnd, &RamfuncsRunStart); // Call Flash Initialization to setup flash waitstates // This function must reside in RAM InitFlash(); // Call the flash wrapper init function #endif //(FLASH) // Waiting for enable flag set while (EnableFlag==FALSE) { BackTicker++; } // Timing sync for background loops // Timer period definitions found in device specific PeripheralHeaderIncludes.h CpuTimer0Regs.PRD.all = mSec1; // A tasks CpuTimer1Regs.PRD.all = mSec5; // B tasks CpuTimer2Regs.PRD.all = mSec50; // C tasks // Tasks State-machine init Alpha_State_Ptr = &A0; A_Task_Ptr = &A1; B_Task_Ptr = &B1; C_Task_Ptr = &C1; // Initialize PWM module pwm1.PeriodMax = SYSTEM_FREQUENCY*1000000*T/2; // Prescaler X1 (T1), ISR period = T x 1 pwm1.HalfPerMax=pwm1.PeriodMax/2; pwm1.Deadband = 2.0*SYSTEM_FREQUENCY; // 120 counts -> 2.0 usec for TBCLK = SYSCLK/1 PWM_INIT_MACRO(1,2,3,pwm1) // Initialize PWMDAC module pwmdac1.PeriodMax=500; // @60Mhz, 1500->20kHz, 1000-> 30kHz, 500->60kHz pwmdac1.HalfPerMax=pwmdac1.PeriodMax/2; PWMDAC_INIT_MACRO(6,pwmdac1) // PWM 6A,6B PWMDAC_INIT_MACRO(7,pwmdac1) // PWM 7A,7B // Initialize DATALOG module dlog.iptr1 = &DlogCh1; dlog.iptr2 = &DlogCh2; dlog.iptr3 = &DlogCh3; dlog.iptr4 = &DlogCh4; dlog.trig_value = 0x1; dlog.size = 0x0C8; dlog.prescalar = 5; dlog.init(&dlog); // Initialize ADC for DMC Kit Rev 1.1 ChSel[0]=1; // Dummy meas. avoid 1st sample issue Rev0 Picollo*/ ChSel[1]=1; // ChSelect: ADC A1-> Phase A Current ChSel[2]=9; // ChSelect: ADC B1-> Phase B Current ChSel[3]=3; // ChSelect: ADC A3-> Phase C Current ChSel[4]=15; // ChSelect: ADC B7-> Phase A Voltage ChSel[5]=14; // ChSelect: ADC B6-> Phase B Voltage ChSel[6]=12; // ChSelect: ADC B4-> Phase C Voltage ChSel[7]=7; // ChSelect: ADC A7-> DC Bus Voltage ADC_MACRO_INIT(ChSel,TrigSel,ACQPS) // Initialize QEP module qep1.LineEncoder = 2048; qep1.MechScaler = _IQ30(0.25/qep1.LineEncoder); qep1.PolePairs = POLES/2; qep1.CalibratedAngle = 0; QEP_INIT_MACRO(1,qep1) // Initialize CAP module CAP_INIT_MACRO(1) // Initialize the Speed module for QEP based speed calculation speed1.K1 = _IQ21(1/(BASE_FREQ*T)); speed1.K2 = _IQ(1/(1+T*2*PI*5)); // Low-pass cut-off frequency speed1.K3 = _IQ(1)-speed1.K2; speed1.BaseRpm = 120*(BASE_FREQ/POLES); // Initialize the Speed module for capture eQEP based speed calculation (low speed range) speed2.InputSelect = 1; speed2.BaseRpm = 120*(BASE_FREQ/POLES); speed2.SpeedScaler = 60*(SYSTEM_FREQUENCY*1000000/(1*2048*speed2.BaseRpm)); // Initialize the RAMPGEN module rg1.StepAngleMax = _IQ(BASE_FREQ*T); // Initialize the CUR_MOD constant module cm1_const.Rr = RR; cm1_const.Lr = LR; cm1_const.fb = BASE_FREQ; cm1_const.Ts = T; CUR_CONST_MACRO(cm1_const) // Initialize the CUR_MOD module cm1.Kr = _IQ(cm1_const.Kr); cm1.Kt = _IQ(cm1_const.Kt); cm1.K = _IQ(cm1_const.K); // Initialize the PI module for Id pi_spd.Kp=_IQ(2.0); pi_spd.Ki=_IQ(T*SpeedLoopPrescaler/0.5); pi_spd.Umax =_IQ(0.95); pi_spd.Umin =_IQ(-0.95); // Initialize the PI module for Iq pi_id.Kp=_IQ(1.0); pi_id.Ki=_IQ(T/0.004); pi_id.Umax =_IQ(0.3); pi_id.Umin =_IQ(-0.3); // Initialize the PI module for speed pi_iq.Kp=_IQ(1.0); pi_iq.Ki=_IQ(T/0.004); pi_iq.Umax =_IQ(0.80); pi_iq.Umin =_IQ(-0.80); // Note that the vectorial sum of d-q PI outputs should be less than 1.0 which refers to maximum duty cycle for SVGEN. // Another duty cycle limiting factor is current sense through shunt resistors which depends on hardware/software implementation. // Depending on the application requirements 3,2 or a single shunt resistor can be used for current waveform reconstruction. // The higher number of shunt resistors allow the higher duty cycle operation and better dc bus utilization. // The users should adjust the PI saturation levels carefully during open loop tests (i.e pi_id.Umax, pi_iq.Umax and Umins) as in project manuals. // Violation of this procedure yields distorted current waveforms and unstable closed loop operations which may damage the inverter. //Call HVDMC Protection function HVDMC_Protection(); // Reassign ISRs. EALLOW; // This is needed to write to EALLOW protected registers PieVectTable.ADCINT1 = &OffsetISR; // Enable PIE group 1 interrupt 1 for ADC1_INT PieCtrlRegs.PIEIER1.bit.INTx1 = 1; // Enable EOC interrupt(after the 4th conversion) AdcRegs.ADCINTOVFCLR.bit.ADCINT1=1; AdcRegs.ADCINTFLGCLR.bit.ADCINT1=1; AdcRegs.INTSEL1N2.bit.INT1CONT=1; AdcRegs.INTSEL1N2.bit.INT1SEL=4; AdcRegs.INTSEL1N2.bit.INT1E=1; // Enable CPU INT1 for ADC1_INT: IER |= M_INT1; // Enable global Interrupts and higher priority real-time debug events: EINT; // Enable Global interrupt INTM ERTM; // Enable Global realtime interrupt DBGM EDIS; // IDLE loop. Just sit and loop forever: for(;;) //infinite loop { // State machine entry & exit point //=========================================================== (*Alpha_State_Ptr)(); // jump to an Alpha state (A0,B0,...) //=========================================================== } } //END MAIN CODE //================================================================================= // STATE-MACHINE SEQUENCING AND SYNCRONIZATION FOR SLOW BACKGROUND TASKS //================================================================================= //--------------------------------- FRAMEWORK ------------------------------------- void A0(void) { // loop rate synchronizer for A-tasks if(CpuTimer0Regs.TCR.bit.TIF == 1) { CpuTimer0Regs.TCR.bit.TIF = 1; // clear flag //----------------------------------------------------------- (*A_Task_Ptr)(); // jump to an A Task (A1,A2,A3,...) //----------------------------------------------------------- VTimer0[0]++; // virtual timer 0, instance 0 (spare) SerialCommsTimer++; } Alpha_State_Ptr = &B0; // Comment out to allow only A tasks } void B0(void) { // loop rate synchronizer for B-tasks if(CpuTimer1Regs.TCR.bit.TIF == 1) { CpuTimer1Regs.TCR.bit.TIF = 1; // clear flag //----------------------------------------------------------- (*B_Task_Ptr)(); // jump to a B Task (B1,B2,B3,...) //----------------------------------------------------------- VTimer1[0]++; // virtual timer 1, instance 0 (spare) } Alpha_State_Ptr = &C0; // Allow C state tasks } void C0(void) { // loop rate synchronizer for C-tasks if(CpuTimer2Regs.TCR.bit.TIF == 1) { CpuTimer2Regs.TCR.bit.TIF = 1; // clear flag //----------------------------------------------------------- (*C_Task_Ptr)(); // jump to a C Task (C1,C2,C3,...) //----------------------------------------------------------- VTimer2[0]++; //virtual timer 2, instance 0 (spare) } Alpha_State_Ptr = &A0; // Back to State A0 } //================================================================================= // A - TASKS (executed in every 1 msec) //================================================================================= //-------------------------------------------------------- void A1(void) // SPARE (not used) //-------------------------------------------------------- { //------------------- //the next time CpuTimer0 'counter' reaches Period value go to A2 A_Task_Ptr = &A2; //------------------- } //----------------------------------------------------------------- void A2(void) // SPARE (not used) //----------------------------------------------------------------- { //------------------- //the next time CpuTimer0 'counter' reaches Period value go to A3 A_Task_Ptr = &A3; //------------------- } //----------------------------------------- void A3(void) // SPARE (not used) //----------------------------------------- { //----------------- //the next time CpuTimer0 'counter' reaches Period value go to A1 A_Task_Ptr = &A1; //----------------- } //================================================================================= // B - TASKS (executed in every 5 msec) //================================================================================= //----------------------------------- USER ---------------------------------------- //---------------------------------------- void B1(void) // Toggle GPIO-00 //---------------------------------------- { //----------------- //the next time CpuTimer1 'counter' reaches Period value go to B2 B_Task_Ptr = &B2; //----------------- } //---------------------------------------- void B2(void) // SPARE //---------------------------------------- { //----------------- //the next time CpuTimer1 'counter' reaches Period value go to B3 B_Task_Ptr = &B3; //----------------- } //---------------------------------------- void B3(void) // SPARE //---------------------------------------- { //----------------- //the next time CpuTimer1 'counter' reaches Period value go to B1 B_Task_Ptr = &B1; //----------------- } //================================================================================= // C - TASKS (executed in every 50 msec) //================================================================================= //--------------------------------- USER ------------------------------------------ //---------------------------------------- void C1(void) // Toggle GPIO-34, GPIO42/44 //---------------------------------------- { if(EPwm1Regs.TZFLG.bit.OST==0x1) // TripZ for PWMs is low (fault trip) { TripFlagDMC=1; GpioDataRegs.GPBTOGGLE.bit.GPIO42 = 1; } if(GpioDataRegs.GPADAT.bit.GPIO15 == 1) // Over Current Prot. for Integrated Power Module is high (fault trip) { TripFlagDMC=1; GpioDataRegs.GPBTOGGLE.bit.GPIO44 = 1; } GpioDataRegs.GPBTOGGLE.bit.GPIO34 = 1; // Turn on/off LD3 on the controlCARD //----------------- //the next time CpuTimer2 'counter' reaches Period value go to C2 C_Task_Ptr = &C2; //----------------- } //---------------------------------------- void C2(void) // SPARE //---------------------------------------- { //----------------- //the next time CpuTimer2 'counter' reaches Period value go to C3 C_Task_Ptr = &C3; //----------------- } //----------------------------------------- void C3(void) // SPARE //----------------------------------------- { //----------------- //the next time CpuTimer2 'counter' reaches Period value go to C1 C_Task_Ptr = &C1; //----------------- } //MainISR interrupt void MainISR(void) { // Verifying the ISR IsrTicker++; // =============================== LEVEL 1 ====================================== // Checks target independent modules, duty cycle waveforms and PWM update // Keep the motors disconnected at this level! // ============================================================================== #if (BUILDLEVEL==LEVEL1) // ------------------------------------------------------------------------------ // Connect inputs of the RMP module and call the ramp control macro // ------------------------------------------------------------------------------ rc1.TargetValue = SpeedRef; RC_MACRO(rc1) // ------------------------------------------------------------------------------ // Connect inputs of the RAMP GEN module and call the ramp generator macro // ------------------------------------------------------------------------------ rg1.Freq = rc1.SetpointValue; RG_MACRO(rg1) // ------------------------------------------------------------------------------ // Connect inputs of the INV_PARK module and call the inverse park trans. macro // There are two option for trigonometric functions: // IQ sin/cos look-up table provides 512 discrete sin and cos points in Q30 format // IQsin/cos PU functions interpolate the data in the lookup table yielding higher resolution. // ------------------------------------------------------------------------------ ipark1.Ds = VdTesting; ipark1.Qs = VqTesting; //ipark1.Sine =_IQ30toIQ(IQsinTable[_IQtoIQ9(rg1.Out)]); //ipark1.Cosine=_IQ30toIQ(IQcosTable[_IQtoIQ9(rg1.Out)]); ipark1.Sine=_IQsinPU(rg1.Out); ipark1.Cosine=_IQcosPU(rg1.Out); IPARK_MACRO(ipark1) // ------------------------------------------------------------------------------ // Connect inputs of the SVGEN module and call the space-vector gen. macro // ------------------------------------------------------------------------------ svgen1.Ualpha = ipark1.Alpha; svgen1.Ubeta = ipark1.Beta; SVGENDQ_MACRO(svgen1) // ------------------------------------------------------------------------------ // Connect inputs of the PWM_DRV module and call the PWM signal generation macro // ------------------------------------------------------------------------------ pwm1.MfuncC1 = svgen1.Ta; pwm1.MfuncC2 = svgen1.Tb; pwm1.MfuncC3 = svgen1.Tc; PWM_MACRO(1,2,3,pwm1) // Calculate the new PWM compare values // ------------------------------------------------------------------------------ // Connect inputs of the PWMDAC module // ------------------------------------------------------------------------------ pwmdac1.MfuncC1 = svgen1.Ta; pwmdac1.MfuncC2 = svgen1.Tb; PWMDAC_MACRO(6,pwmdac1) // PWMDAC 6A, 6B pwmdac1.MfuncC1 = svgen1.Tc; pwmdac1.MfuncC2 = svgen1.Tb-svgen1.Tc; PWMDAC_MACRO(7,pwmdac1) // PWMDAC 7A, 7B // ------------------------------------------------------------------------------ // Connect inputs of the DATALOG module // ------------------------------------------------------------------------------ DlogCh1 = (int16)_IQtoIQ15(svgen1.Ta); DlogCh2 = (int16)_IQtoIQ15(svgen1.Tb); DlogCh3 = (int16)_IQtoIQ15(svgen1.Tc); DlogCh4 = (int16)_IQtoIQ15(svgen1.Tb-svgen1.Tc); #endif // (BUILDLEVEL==LEVEL1) // =============================== LEVEL 2 ====================================== // Level 2 verifies the analog-to-digital conversion, offset compensation, // clarke/park transformations (CLARKE/PARK), // ============================================================================== #if (BUILDLEVEL==LEVEL2) // ------------------------------------------------------------------------------ // Connect inputs of the RMP module and call the ramp control macro // ------------------------------------------------------------------------------ rc1.TargetValue = SpeedRef; RC_MACRO(rc1) // ------------------------------------------------------------------------------ // Connect inputs of the RAMP GEN module and call the ramp generator macro // ------------------------------------------------------------------------------ rg1.Freq = rc1.SetpointValue; RG_MACRO(rg1) // ------------------------------------------------------------------------------ // Measure phase currents, subtract the offset and normalize from (-0.5,+0.5) to (-1,+1). // Connect inputs of the CLARKE module and call the clarke transformation macro // ------------------------------------------------------------------------------ clarke1.As = _IQmpy2(_IQ12toIQ(AdcResult.ADCRESULT1)-offsetA); // Phase A curr. clarke1.Bs = _IQmpy2(_IQ12toIQ(AdcResult.ADCRESULT2)-offsetB); // Phase B curr. CLARKE_MACRO(clarke1) // ------------------------------------------------------------------------------ // Connect inputs of the PARK module and call the park trans. macro // ------------------------------------------------------------------------------ park1.Alpha = clarke1.Alpha; park1.Beta = clarke1.Beta; park1.Angle = rg1.Out; park1.Sine = _IQsinPU(park1.Angle); park1.Cosine = _IQcosPU(park1.Angle); PARK_MACRO(park1) // ------------------------------------------------------------------------------ // Connect inputs of the INV_PARK module and call the inverse park trans. macro // ------------------------------------------------------------------------------ ipark1.Ds = VdTesting; ipark1.Qs = VqTesting; ipark1.Sine = park1.Sine; ipark1.Cosine= park1.Cosine; IPARK_MACRO(ipark1) // ------------------------------------------------------------------------------ // Connect inputs of the SVGEN module and call the space-vector gen. macro // ------------------------------------------------------------------------------ svgen1.Ualpha = ipark1.Alpha; svgen1.Ubeta = ipark1.Beta; SVGENDQ_MACRO(svgen1) // ------------------------------------------------------------------------------ // Connect inputs of the PWM_DRV module and call the PWM signal generation macro // ------------------------------------------------------------------------------ pwm1.MfuncC1 = svgen1.Ta; pwm1.MfuncC2 = svgen1.Tb; pwm1.MfuncC3 = svgen1.Tc; PWM_MACRO(1,2,3,pwm1) // Calculate the new PWM compare values // ------------------------------------------------------------------------------ // Connect inputs of the PWMDAC module // ------------------------------------------------------------------------------ pwmdac1.MfuncC1 = clarke1.As; pwmdac1.MfuncC2 = clarke1.Bs; PWMDAC_MACRO(6,pwmdac1) // PWMDAC 6A, 6B pwmdac1.MfuncC1 = rg1.Out; pwmdac1.MfuncC2 = svgen1.Ta; PWMDAC_MACRO(7,pwmdac1) // PWMDAC 7A, 7B // ------------------------------------------------------------------------------ // Connect inputs of the DATALOG module // ------------------------------------------------------------------------------ DlogCh1 = (int16)_IQtoIQ15(clarke1.As); DlogCh2 = (int16)_IQtoIQ15(clarke1.Bs); DlogCh3 = (int16)_IQtoIQ15(rg1.Out); DlogCh4 = (int16)_IQtoIQ15(svgen1.Ta); #endif // (BUILDLEVEL==LEVEL2) // =============================== LEVEL 3 ====================================== // Level 3 verifies the dq-axis current regulation performed by PI and // speed measurement modules // ============================================================================== #if (BUILDLEVEL==LEVEL3) // ------------------------------------------------------------------------------ // Connect inputs of the RMP module and call the ramp control macro // ------------------------------------------------------------------------------ rc1.TargetValue = SpeedRef; RC_MACRO(rc1) // ------------------------------------------------------------------------------ // Connect inputs of the RAMP GEN module and call the ramp generator macro // ------------------------------------------------------------------------------ rg1.Freq = rc1.SetpointValue; RG_MACRO(rg1) // ------------------------------------------------------------------------------ // Measure phase currents, subtract the offset and normalize from (-0.5,+0.5) to (-1,+1). // Connect inputs of the CLARKE module and call the clarke transformation macro // ------------------------------------------------------------------------------ clarke1.As = _IQmpy2(_IQ12toIQ(AdcResult.ADCRESULT1)-offsetA); // Phase A curr. clarke1.Bs = _IQmpy2(_IQ12toIQ(AdcResult.ADCRESULT2)-offsetB); // Phase B curr. CLARKE_MACRO(clarke1) // ------------------------------------------------------------------------------ // Connect inputs of the PARK module and call the park trans. macro // ------------------------------------------------------------------------------ park1.Alpha = clarke1.Alpha; park1.Beta = clarke1.Beta; park1.Angle = rg1.Out; park1.Sine = _IQsinPU(park1.Angle); park1.Cosine = _IQcosPU(park1.Angle); PARK_MACRO(park1) // ------------------------------------------------------------------------------ // Connect inputs of the PI module and call the PI IQ controller macro // ------------------------------------------------------------------------------ pi_iq.Ref = IqRef; pi_iq.Fbk = park1.Qs; PI_MACRO(pi_iq) // ------------------------------------------------------------------------------ // Connect inputs of the PI module and call the PI ID controller macro // ------------------------------------------------------------------------------ pi_id.Ref = IdRef; pi_id.Fbk = park1.Ds; PI_MACRO(pi_id) // ------------------------------------------------------------------------------ // Connect inputs of the INV_PARK module and call the inverse park trans. macro // ------------------------------------------------------------------------------ ipark1.Ds = pi_id.Out; ipark1.Qs = pi_iq.Out ; ipark1.Sine = park1.Sine; ipark1.Cosine = park1.Cosine; IPARK_MACRO(ipark1) // ------------------------------------------------------------------------------ // Call the QEP macro (if incremental encoder used for speed sensing) // Connect inputs of the SPEED_FR module and call the speed calculation macro // ------------------------------------------------------------------------------ QEP_MACRO(1,qep1) speed1.ElecTheta = _IQ24toIQ((int32)qep1.ElecTheta); speed1.DirectionQep = (int32)(qep1.DirectionQep); SPEED_FR_MACRO(speed1) // ------------------------------------------------------------------------------ // Call the CAP macro (if sprocket or spur gear used for speed sensing) // Connect inputs of the SPEED_PR module and call the speed calculation macro // ------------------------------------------------------------------------------ CAP_MACRO(1,cap1) if(cap1.CapReturn ==0) // Check the capture return { speed2.EventPeriod=(int32)(cap1.EventPeriod); // Read out new event period SPEED_PR_MACRO(speed2) // Call the speed macro } // ------------------------------------------------------------------------------ // Connect inputs of the SVGEN module and call the space-vector gen. macro // ------------------------------------------------------------------------------ svgen1.Ualpha = ipark1.Alpha; svgen1.Ubeta = ipark1.Beta; SVGENDQ_MACRO(svgen1) // ------------------------------------------------------------------------------ // Connect inputs of the PWM_DRV module and call the PWM signal generation macro // ------------------------------------------------------------------------------ pwm1.MfuncC1 = svgen1.Ta; pwm1.MfuncC2 = svgen1.Tb; pwm1.MfuncC3 = svgen1.Tc; PWM_MACRO(1,2,3,pwm1) // Calculate the new PWM compare values // ------------------------------------------------------------------------------ // Connect inputs of the PWMDAC module // ------------------------------------------------------------------------------ pwmdac1.MfuncC1 = clarke1.As; pwmdac1.MfuncC2 = clarke1.Bs; PWMDAC_MACRO(6,pwmdac1) // PWMDAC 6A, 6B pwmdac1.MfuncC1 = rg1.Out; pwmdac1.MfuncC2 = speed1.ElecTheta; PWMDAC_MACRO(7,pwmdac1) // PWMDAC 7A, 7B // ------------------------------------------------------------------------------ // Connect inputs of the DATALOG module // ------------------------------------------------------------------------------ DlogCh1 = (int16)_IQtoIQ15(clarke1.As); DlogCh2 = (int16)_IQtoIQ15(svgen1.Ta); DlogCh3 = (int16)_IQtoIQ15(rg1.Out); DlogCh4 = (int16)_IQtoIQ15(speed1.ElecTheta); #endif // (BUILDLEVEL==LEVEL3) // =============================== LEVEL 4 ====================================== // Level 4 verifies the current model (CUR_MOD). // ============================================================================== #if (BUILDLEVEL==LEVEL4) // ------------------------------------------------------------------------------ // Connect inputs of the RMP module and call the ramp control macro // ------------------------------------------------------------------------------ rc1.TargetValue = SpeedRef; RC_MACRO(rc1) // ------------------------------------------------------------------------------ // Connect inputs of the RAMP GEN module and call the ramp generator macro // ------------------------------------------------------------------------------ rg1.Freq = rc1.SetpointValue; RG_MACRO(rg1) // ------------------------------------------------------------------------------ // Measure phase currents, subtract the offset and normalize from (-0.5,+0.5) to (-1,+1). // Connect inputs of the CLARKE module and call the clarke transformation macro // ------------------------------------------------------------------------------ clarke1.As = _IQmpy2(_IQ12toIQ(AdcResult.ADCRESULT1)-offsetA); // Phase A curr. clarke1.Bs = _IQmpy2(_IQ12toIQ(AdcResult.ADCRESULT2)-offsetB); // Phase B curr. CLARKE_MACRO(clarke1) // ------------------------------------------------------------------------------ // Connect inputs of the PARK module and call the park trans. macro // ------------------------------------------------------------------------------ park1.Alpha = clarke1.Alpha; park1.Beta = clarke1.Beta; park1.Angle = rg1.Out; park1.Sine = _IQsinPU(park1.Angle); park1.Cosine= _IQcosPU(park1.Angle); PARK_MACRO(park1) // ------------------------------------------------------------------------------ // Connect inputs of the PI module and call the PID IQ controller macro // ------------------------------------------------------------------------------ pi_iq.Ref = IqRef; pi_iq.Fbk = park1.Qs; PI_MACRO(pi_iq) // ------------------------------------------------------------------------------ // Connect inputs of the PI module and call the PID ID controller macro // ------------------------------------------------------------------------------ pi_id.Ref = IdRef; pi_id.Fbk = park1.Ds; PI_MACRO(pi_id) // ------------------------------------------------------------------------------ // Connect inputs of the INV_PARK module and call the inverse park trans. macro // ------------------------------------------------------------------------------ ipark1.Ds = pi_id.Out; ipark1.Qs = pi_iq.Out ; ipark1.Sine = park1.Sine; ipark1.Cosine = park1.Cosine; IPARK_MACRO(ipark1) // ------------------------------------------------------------------------------ // Call the QEP macro (if incremental encoder used for speed sensing) // Connect inputs of the SPEED_FR module and call the speed calculation macro // ------------------------------------------------------------------------------ QEP_MACRO(1,qep1) speed1.ElecTheta = _IQ24toIQ((int32)qep1.ElecTheta); speed1.DirectionQep = (int32)(qep1.DirectionQep); SPEED_FR_MACRO(speed1) // ------------------------------------------------------------------------------ // Call the CAP macro (if sprocket or spur gear used for speed sensing) // Connect inputs of the SPEED_PR module and call the speed calculation macro // ------------------------------------------------------------------------------ CAP_MACRO(1,cap1) if(cap1.CapReturn ==0) // Check the capture return { speed2.EventPeriod=(int32)(cap1.EventPeriod); // Read out new event period SPEED_PR_MACRO(speed2) // Call the speed macro } // ------------------------------------------------------------------------------ // Connect inputs of the CUR_MOD module and call the current model // calculation function. // ------------------------------------------------------------------------------ cm1.IDs = park1.Ds; cm1.IQs = park1.Qs; cm1.Wr = speed1.Speed; CUR_MOD_MACRO(cm1) // ------------------------------------------------------------------------------ // Connect inputs of the SVGEN module and call the space-vector gen. macro // ------------------------------------------------------------------------------ svgen1.Ualpha = ipark1.Alpha; svgen1.Ubeta = ipark1.Beta; SVGENDQ_MACRO(svgen1) // ------------------------------------------------------------------------------ // Connect inputs of the PWM_DRV module and call the PWM signal generation macro // ------------------------------------------------------------------------------ pwm1.MfuncC1 = svgen1.Ta; pwm1.MfuncC2 = svgen1.Tb; pwm1.MfuncC3 = svgen1.Tc; PWM_MACRO(1,2,3,pwm1) // Calculate the new PWM compare values // ------------------------------------------------------------------------------ // Connect inputs of the PWMDAC module // ------------------------------------------------------------------------------ pwmdac1.MfuncC1 = clarke1.As; pwmdac1.MfuncC2 = cm1.Theta; PWMDAC_MACRO(6,pwmdac1) // PWMDAC 6A, 6B pwmdac1.MfuncC1 = rg1.Out; pwmdac1.MfuncC2 = speed1.ElecTheta ; PWMDAC_MACRO(7,pwmdac1) // PWMDAC 7A, 7B // ------------------------------------------------------------------------------ // Connect inputs of the DATALOG module // ------------------------------------------------------------------------------ DlogCh1 = (int16)_IQtoIQ15(svgen1.Ta); DlogCh2 = (int16)_IQtoIQ15(cm1.Theta); DlogCh3 = (int16)_IQtoIQ15(clarke1.As); DlogCh4 = (int16)_IQtoIQ15(clarke1.Bs); #endif // (BUILDLEVEL==LEVEL4) // =============================== LEVEL 5 ====================================== // Level 5 verifies verifies the speed regulator performed by PI module. // The system speed loop is closed by using the measured speed from capture // signal as a feedback. // ============================================================================== #if (BUILDLEVEL==LEVEL5) // ------------------------------------------------------------------------------ // Connect inputs of the RMP module and call the ramp control macro // ------------------------------------------------------------------------------ rc1.TargetValue = SpeedRef; RC_MACRO(rc1) // ------------------------------------------------------------------------------ // Connect inputs of the RAMP GEN module and call the ramp generator macro // ------------------------------------------------------------------------------ rg1.Freq = rc1.SetpointValue; RG_MACRO(rg1) // ------------------------------------------------------------------------------ // Measure phase currents, subtract the offset and normalize from (-0.5,+0.5) to (-1,+1). // Connect inputs of the CLARKE module and call the clarke transformation macro // ------------------------------------------------------------------------------ clarke1.As = _IQmpy2(_IQ12toIQ(AdcResult.ADCRESULT1)-offsetA); // Phase A curr. clarke1.Bs = _IQmpy2(_IQ12toIQ(AdcResult.ADCRESULT2)-offsetB); // Phase B curr. CLARKE_MACRO(clarke1) // ------------------------------------------------------------------------------ // Connect inputs of the PARK module and call the park trans. macro // ------------------------------------------------------------------------------ park1.Alpha = clarke1.Alpha; park1.Beta = clarke1.Beta; park1.Angle = cm1.Theta; park1.Sine = _IQsinPU(park1.Angle); park1.Cosine= _IQcosPU(park1.Angle); PARK_MACRO(park1) // ------------------------------------------------------------------------------ // Connect inputs of the PI module and call the PID IQ controller macro // ------------------------------------------------------------------------------ if (SpeedLoopCount==SpeedLoopPrescaler) { pi_spd.Ref = rc1.SetpointValue; pi_spd.Fbk = speed1.Speed; PI_MACRO(pi_spd) SpeedLoopCount=1; } else SpeedLoopCount++; // ------------------------------------------------------------------------------ // Connect inputs of the PI module and call the PID IQ controller macro // ------------------------------------------------------------------------------ pi_iq.Ref = pi_spd.Out; pi_iq.Fbk = park1.Qs; PI_MACRO(pi_iq) // ------------------------------------------------------------------------------ // Connect inputs of the PI module and call the PID ID controller macro // ------------------------------------------------------------------------------ pi_id.Ref = IdRef; pi_id.Fbk = park1.Ds; PI_MACRO(pi_id) // ------------------------------------------------------------------------------ // Connect inputs of the INV_PARK module and call the inverse park trans. macro // ------------------------------------------------------------------------------ ipark1.Ds = pi_id.Out; ipark1.Qs = pi_iq.Out ; ipark1.Sine = park1.Sine; ipark1.Cosine = park1.Cosine; IPARK_MACRO(ipark1) // ------------------------------------------------------------------------------ // Call the QEP macro (if incremental encoder used for speed sensing) // Connect inputs of the SPEED_FR module and call the speed calculation macro // ------------------------------------------------------------------------------ QEP_MACRO(1,qep1) speed1.ElecTheta = _IQ24toIQ((int32)qep1.ElecTheta); speed1.DirectionQep = (int32)(qep1.DirectionQep); SPEED_FR_MACRO(speed1) /* ------------------------------------------------------------------------------ // Call the CAP macro (if sprocket or spur gear used for speed sensing) // Connect inputs of the SPEED_PR module and call the speed calculation macro // ------------------------------------------------------------------------------ CAP_MACRO(1,cap1) if(cap1.CapReturn ==0) // Check the capture return { speed2.EventPeriod=(int32)(cap1.EventPeriod); // Read out new event period SPEED_PR_MACRO(speed2) // Call the speed macro } */ // ------------------------------------------------------------------------------ // Connect inputs of the CUR_MOD module and call the current model // calculation function. // ------------------------------------------------------------------------------ cm1.IDs = park1.Ds; cm1.IQs = park1.Qs; cm1.Wr = speed1.Speed; CUR_MOD_MACRO(cm1) // ------------------------------------------------------------------------------ // Connect inputs of the SVGEN module and call the space-vector gen. macro // ------------------------------------------------------------------------------ svgen1.Ualpha = ipark1.Alpha; svgen1.Ubeta = ipark1.Beta; SVGENDQ_MACRO(svgen1) // ------------------------------------------------------------------------------ // Connect inputs of the PWM_DRV module and call the PWM signal generation macro // ------------------------------------------------------------------------------ pwm1.MfuncC1 = svgen1.Ta; pwm1.MfuncC2 = svgen1.Tb; pwm1.MfuncC3 = svgen1.Tc; PWM_MACRO(1,2,3,pwm1) // Calculate the new PWM compare values // ------------------------------------------------------------------------------ // Connect inputs of the PWMDAC module // ------------------------------------------------------------------------------ pwmdac1.MfuncC1 = clarke1.As; pwmdac1.MfuncC2 = cm1.Theta; PWMDAC_MACRO(6,pwmdac1) // PWMDAC 6A, 6B pwmdac1.MfuncC1 = rg1.Out; pwmdac1.MfuncC2 = speed1.ElecTheta ; PWMDAC_MACRO(7,pwmdac1) // PWMDAC 7A, 7B // ------------------------------------------------------------------------------ // Connect inputs of the DATALOG module // ------------------------------------------------------------------------------ DlogCh1 = (int16)_IQtoIQ15(svgen1.Ta); DlogCh2 = (int16)_IQtoIQ15(cm1.Theta); DlogCh3 = (int16)_IQtoIQ15(clarke1.As); DlogCh4 = (int16)_IQtoIQ15(clarke1.Bs); #endif // (BUILDLEVEL==LEVEL5) // ------------------------------------------------------------------------------ // Call the DATALOG update function. // ------------------------------------------------------------------------------ dlog.update(&dlog); // Enable more interrupts from this timer AdcRegs.ADCINTFLG.bit.ADCINT1=1; // Acknowledge interrupt to recieve more interrupts from PIE group 3 PieCtrlRegs.PIEACK.all = PIEACK_GROUP1; }// MainISR Ends Here //==========================================================/ //====================Offset Compensation===================/ //==========================================================/ interrupt void OffsetISR(void) { // Verifying the ISR IsrTicker++; // DC offset measurement for ADC if (IsrTicker>=5000) { offsetA= _IQmpy(K1,offsetA)+_IQmpy(K2,_IQ12toIQ(AdcResult.ADCRESULT1)); //Phase A offset offsetB= _IQmpy(K1,offsetB)+_IQmpy(K2,_IQ12toIQ(AdcResult.ADCRESULT2)); //Phase B offset offsetC= _IQmpy(K1,offsetC)+_IQmpy(K2,_IQ12toIQ(AdcResult.ADCRESULT3)); //Phase C offset } if (IsrTicker > 20000) { EALLOW; PieVectTable.ADCINT1=&MainISR; EDIS; } // Enable more interrupts from this timer AdcRegs.ADCINTFLG.bit.ADCINT1=1; // Acknowledge interrupt to recieve more interrupts from PIE group 1 PieCtrlRegs.PIEACK.all = PIEACK_GROUP1; }//End of offset compensation //==========================================================/ //===============Protection Configuration===================/ //==========================================================/ void HVDMC_Protection(void) { // Configure Trip Mechanism for the Motor control software // -Cycle by cycle trip on CPU halt // -One shot IPM trip zone trip // These trips need to be repeated for EPWM1 ,2 & 3 //=========================================================================== //Motor Control Trip Config, EPwm1,2,3 //=========================================================================== EALLOW; // CPU Halt Trip EPwm1Regs.TZSEL.bit.CBC6=0x1; EPwm2Regs.TZSEL.bit.CBC6=0x1; EPwm3Regs.TZSEL.bit.CBC6=0x1; EPwm1Regs.TZSEL.bit.OSHT1 = 1; //enable TZ1 for OSHT EPwm2Regs.TZSEL.bit.OSHT1 = 1; //enable TZ1 for OSHT EPwm3Regs.TZSEL.bit.OSHT1 = 1; //enable TZ1 for OSHT // What do we want the OST/CBC events to do? // TZA events can force EPWMxA // TZB events can force EPWMxB EPwm1Regs.TZCTL.bit.TZA = TZ_FORCE_LO; // EPWMxA will go low EPwm1Regs.TZCTL.bit.TZB = TZ_FORCE_LO; // EPWMxB will go low EPwm2Regs.TZCTL.bit.TZA = TZ_FORCE_LO; // EPWMxA will go low EPwm2Regs.TZCTL.bit.TZB = TZ_FORCE_LO; // EPWMxB will go low EPwm3Regs.TZCTL.bit.TZA = TZ_FORCE_LO; // EPWMxA will go low EPwm3Regs.TZCTL.bit.TZB = TZ_FORCE_LO; // EPWMxB will go low EDIS; // Clear any spurious OV trip EPwm1Regs.TZCLR.bit.OST = 1; EPwm2Regs.TZCLR.bit.OST = 1; EPwm3Regs.TZCLR.bit.OST = 1; }//End of protection configuration //============================================================== 一直不明白这个注释(State Machine function prototypes)下的几种状态到底是干嘛的?还有就是里面的几种函数是怎么实现的。我自己也尝试了斜坡函数,但是发现出来的数据不对。 |
相关推荐 |
嵌入式操作教程_数字信号处理_音频编解码:3-6 AAC音频解码实验
423 浏览 0 评论
数字信号处理实验操作教程:3-3 mp3音频编码实验(AD7606采集)
1313 浏览 0 评论
嵌入式DSP教学实验箱操作教程:2-20 数模转换实验(模拟SPI总线输出电压值)
1325 浏览 0 评论
目前在2837x系列用的最多的、性能最好、性价比最高的是哪一款?
1089 浏览 0 评论
国产嵌入式DSP教学实验箱_操作教程:22-AD采集DA输出实验(采集输出正弦波)
2275 浏览 0 评论
GMT+8, 2024-4-23 18:50 , Processed in 0.783959 second(s), Total 42, Slave 32 queries .
