[问答] fft傅里叶变换问题
[复制链接]
技术员
发表于 2017-9-14 15:20:07   418 查看 0 回复 显示全部楼层 倒序浏览
分享
现在固定频率8k采样,如果是50hz的信号相对应就是160个采样点,现在要进行傅里叶变换,有没有大神能帮我看看代码  pwcz函数是在干嘛,整个代码能不能帮我屡屡思路
  1. #include <stdio.h>
  2. #include <stdlib.h>
  3. #include <math.h>
  4.
  5. #define SAMP 160
  6. #define frequency 47.5             //为方便仿真频率先固定
  7. #define MN (1.0*SAMP*50/47.5)
  8. float tmp[21];
  9. float ratio[20];
  10. struct compx
  11. {
  12.     float real;
  13.     float imag;
  14. };
  15. struct compx sum[SAMP+1];
  16. float base;                 /*-基波-*/
  17. float component_O[20];      /* -各次谐波分量-*/
  18. float component_O_rt[20];
  19. float ftmp;
  20. float angle[20];
  21. int N = SAMP;
  22. #define RN SAMP*2
  23. float AD_RESULT[RN];
  24. float CZ_RESULT[RN];
  25.
  26. /*float amend_mt[20]=                   //谐波修正系数
  27.     {
  28.         1.0,0.9752,0.9752,0.9752,0.9752,0.9752,0.9752,0.9752,0.9752,0.9752,
  29.         0.9752*1.08,0.9752*1.015,0.9752*1.022,0.9752*1.025,0.9752*1.030,
  30.         0.9752*1.032,0.9752*1.042,0.9752*1.055,0.9752*1.065,0.9752*1.083
  31.     };
  32. */
  33.
  34.
  35.
  36. struct compx EE(struct compx b1,struct compx b2)
  37. {
  38.     struct compx b3;
  39.     b3.real=(b1.real*b2.real-b1.imag*b2.imag);
  40.     b3.imag=(b1.real*b2.imag+b1.imag*b2.real);
  41.     return(b3);
  42. }
  43.
  44. float pwcz(float x)
  45. {
  46.     float y;
  47.     float e1,e2,e3;
  48.     unsigned int k;
  49.
  50.     if((unsigned int)(x*10)%10<=5)
  51.     {
  52.         k=(unsigned int)x;
  53.         printf("k=%d\t",k);
  54.     }
  55.     else
  56.     {
  57.         k=(unsigned int)x+1;
  58.         printf("k1=%d\t",k);
  59.     }
  60.     e1=(x-k)*(x-(k+1))/2.0;
  61.     e2=(x-(k-1))*(x-(k+1))/-1.0;
  62.     e3=(x-(k-1))*(x-k)/2.0;
  63.     y=e1*AD_RESULT[k-1]+e2*AD_RESULT[k]+e3*AD_RESULT[k+1];
  64.     printf("y=%f\n", y);
  65.     return y;
  66. }
  67.
  68. static void draw_data(float *buf,int len,int mode)
  69. {
  70.     FILE *stream;
  71.     float u;
  72.     float temp;
  73.     stream = fopen( "data.txt", "w" );
  74.     int n = 0;
  75.     while(len> 0)
  76.     {
  77.         temp = *buf;
  78.         if( temp < 0)
  79.         {
  80.             temp = temp/4 + 60;
  81.         }
  82.         else
  83.         {
  84.             temp = temp/4 + 60;
  85.         }
  86.
  87.         fprintf(stream, "%d %f\t", n++, *buf);
  88.         for (u = 0; u < temp-1; u++)
  89.         {
  90.             fprintf( stream, " ");
  91.         }
  92.         fprintf( stream, "*\n");
  93.         buf += 1;
  94.         len -= 1;
  95.     };
  96.     fclose( stream );
  97. }
  98.
  99.
  100.
  101. void main()
  102. {
  103.     for(int n=1;n<=2*N;n++)      // 正弦波加谐波计算测试
  104.     {
  105.         AD_RESULT[n]=220*sin(2*3.1415926*(n-1)/MN)
  106.                         +0*sin(2*2*3.1415926*(n-1)/MN)                          //2次
  107. //                          +22*sin(3*2*3.1415926*(n-1)/MN)                     //3次
  108. //                              +22*sin(4*2*3.1415926*(n-1)/MN)                 //4次
  109. //                                  +22*sin(5*2*3.1415926*(n-1)/MN)             //5次
  110. //                                      +22*sin(6*2*3.1415926*(n-1)/MN)         //6次
  111. //                                      +22*sin(7*2*3.1415926*(n-1)/MN)             //5次
  112. //                                      +22*sin(8*2*3.1415926*(n-1)/MN)             //5次
  113. //                                      +22*sin(9*2*3.1415926*(n-1)/MN)             //5次
  114. //                                      +6.6*sin(10*2*3.1415926*(n-1)/MN)         //10次
  115. //                                      +6.6*sin(11*2*3.1415926*(n-1)/MN)             //5次
  116. //                                      +6.6*sin(12*2*3.1415926*(n-1)/MN)             //5次
  117. //                                      +6.6*sin(13*2*3.1415926*(n-1)/MN)             //5次
  118. //                                      +6.6*sin(14*2*3.1415926*(n-1)/MN)             //5次
  119. //                                      +6.6*sin(15*2*3.1415926*(n-1)/MN)             //5次
  120. //                                      +6.6*sin(16*2*3.1415926*(n-1)/MN)        //16次
  121.                                         +11*sin(17*2*3.1415926*(n-1)/MN)
  122.                                         +11*sin(18*2*3.1415926*(n-1)/MN)
  123.                                         +11*sin(21*2*3.1415926*(n-1)/MN);
  124. //                                      +22*sin(19*2*3.1415926*(n-1)/MN);   //19次
  125. //      printf("AD_RESULT[%d]=%f\n", n, AD_RESULT[n]);
  126.
  127.
  128.     }
  129.     for(n=1;n<=SAMP;n++)     // 正弦波加谐波计算测试
  130.     {
  131.         printf("AD_RESULT[%d]=%f\t", n, AD_RESULT[n]);
  132.         CZ_RESULT[n]=pwcz(n*50.0/frequency);
  133.     }
  134.
  135.     float tmp2;
  136.     float temp;
  137.
  138.     for(int m=1; m<22;m++)
  139.     {
  140.         for(n=1; n<=SAMP; n++)
  141.         {
  142.             sum[m].real+=CZ_RESULT[n]*cos(2*3.1415926*m*n/SAMP);
  143.         }
  144.         for(n=1; n<=SAMP; n++)
  145.         {
  146.             sum[m].imag+=CZ_RESULT[n]*sin(2*3.1415926*m*n/SAMP);
  147.         }
  148.
  149.         tmp2=2*sqrt((sum[m].real*sum[m].real+sum[m].imag*sum[m].imag))/SAMP;
  150.         temp = tmp2;
  151.         component_O[m]=temp;
  152.         ftmp = component_O[m] * component_O[m];
  153.         component_O_rt[m] = sqrt(ftmp);
  154.         ratio[m] = component_O_rt[m]*100/component_O_rt[1];
  155. //      printf("component_O_rt[%d]=%f  ratio[%d] = %f  angle[%d]=%f\n", n, component_O_rt[n], n, ratio[n], n, angle[n]);
  156.         printf("component_O_rt[%d]=%f  ratio[%d] = %f  \n", m, component_O_rt[m], m, ratio[m]);
  157.     }
  158.     draw_data(AD_RESULT, 2*SAMP, 0);
  159.     draw_data(CZ_RESULT, SAMP, 0);
  160. }
复制代码
标签:fft变换
高级模式
站长推荐 上一条 /7 下一条
推荐专区
技术干货集中营
专家问答
用户帮助┃咨询与建议┃版主议事
工程师杂谈
工程师创意
工程师职场
论坛电子赛事
社区活动专版
发烧友活动
嵌入式论坛
ARM技术论坛
Android论坛
Linux论坛
单片机/MCU论坛
FPGA|CPLD|ASIC论坛
DSP论坛
嵌入式系统论坛
电源技术论坛
电源技术论坛
无线充电技术
硬件设计论坛
PCB设计论坛
电路设计论坛
电子元器件论坛
控制|传感
总线技术|接口技术
测试测量论坛
LabVIEW论坛
Matlab论坛
测试测量技术专区
仪器仪表技术专区
EDA设计论坛
multisim论坛
PADS技术论坛
Protel|AD|DXP论坛
Allegro论坛
proteus论坛|仿真论坛
EasyEDA-中国人自已的EDA工具
Orcad论坛
综合技术与应用
电机控制
智能电网
光电及显示
参考设计中心
汽车电子技术论坛
医疗电子论坛
开源硬件
无线通信论坛
无线通信技术专区
天线|RF射频|微波|雷达技术
IC设计论坛
芯片测试与失效分析
Mixed Signal/SOC[数模混合芯片设计]
Analog/RF IC设计
设计与制造封装测试
厂商专区
TI论坛
TI Deyisupport社区
检测技术与质量
电磁兼容(EMC)设计与整改
安规知识论坛
检测与认证
消费电子论坛
手机技术论坛
平板电脑/mid论坛
音视/视频/机顶盒论坛
电子论坛综合区
聚丰众筹官方社区
新人报道区
聚丰供应链
论坛服务区
供求信息发布
供需广告
招聘┃求职发布区
电子展览展会专区
