这是官方给的驱动8571的程序,和5571连上之后进不去发送中断,新手,请多指教
#include const unsigned char Sine_Tab[6] = {0x100,0x78,0x56,0x21,0x32,0x96}; int main(void) { WDTCTL = WDTPW + WDTHOLD; // Stop Watchdog timer P1SEL |= BIT6 + BIT7; // Assign I2C pins to USCI_B0 P1SEL2|= BIT6 + BIT7; // Assign I2C pins to USCI_B0 UCB0CTL1 |= UCSWRST; // Enable SW reset UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC; // I2C Master, synchronous mode UCB0CTL1 = UCSSEL_2 + UCSWRST; // Use SMCLK, keep SW reset UCB0BR0 = 12; // fSCL = SMCLK/12 = ~100kHz UCB0BR1 = 0; UCB0I2CSA = 0x98; // Set slave address UCB0CTL1 &= ~UCSWRST; // Clear SW reset, resume operation IE2 |= UCB0TXIE; // Enable TX ready interrupt UCB0CTL1 |= UCTR + UCTXSTT; // I2C TX, start condition UCB0TXBUF = 0x010; // Write DAC control byte // _enable_interrupts(); while(1) { __bis_SR_register(CPUOFF + GIE); } } #pragma vector = USCIAB0TX_VECTOR __interrupt void USCIAB0TX_ISR(void) { static unsigned char ByteCtr=0; UCB0TXBUF = Sine_Tab[ByteCtr++]; // Transmit data byte ByteCtr &= 0x1f; // Do not exceed table } |
1888 浏览 0 评论
3641 浏览 4 评论
5027 浏览 0 评论
1732 浏览 1 评论
9353 浏览 8 评论
664浏览 2评论
707浏览 1评论
668浏览 1评论
1186浏览 1评论
1189浏览 1评论
GMT+8, 2024-4-20 05:34 , Processed in 0.698188 second(s), Total 69, Slave 58 queries .
