[讨论] 【LinkIt 7687试用体验】SPI连接发送
[复制链接]
实习生
发表于 2016-12-22 13:37:46   1050 查看 2 回复 显示全部楼层 倒序浏览
分享
经过很多次调试将spi调试成功了。
fasong_data发送函数传值
jieshou_buffer接受值
也可以自主定义数据流。
spi.c
#include "hal.h"
#include "system_mt7687.h"
#include "top.h"
#include "spi.h"
#include "inttypes.h"
#include "CMSIS.h"
#include "led.h"
uint32_t fasong_length=1;
uint8_t  jieshou_buffer={0x00};
uint32_t jieshou_length=2;
uint8_t  fasong_data={0x00};
void spi_send_and_receive()
fasong_length=1;
jieshou_length=2;
uint32_t clock_frequency = 1000000; //频率//SPI主时钟频率设置,范围从30000HZ到60000000HZ。
hal_spi_master_config_t spi_config;
log_hal_info("---spim_example begin---\r\n");
   hal_gpio_status_t ret;
   ret = hal_gpio_init(HAL_GPIO_29);
   if (HAL_GPIO_STATUS_OK != ret)
     log_hal_error("hal_gpio_init 29 failed\r\n");
     hal_gpio_deinit(HAL_GPIO_29);
     return;
   ret = hal_gpio_init(HAL_GPIO_30);
     log_hal_error("hal_gpio_init 30 failed\r\n");
     hal_gpio_deinit(HAL_GPIO_30);
     return;
   ret = hal_gpio_init(HAL_GPIO_31);
     log_hal_error("hal_gpio_init 31 failed\r\n");
     hal_gpio_deinit(HAL_GPIO_31);
     return;
   ret = hal_gpio_init(HAL_GPIO_32);
     log_hal_error("hal_gpio_init 32 failed\r\n");
     hal_gpio_deinit(HAL_GPIO_32);
     return;
   hal_gpio_init(HAL_GPIO_28);
hal_pinmux_set_function(HAL_GPIO_29, HAL_GPIO_29_SPI_MOSI_M_CM4);
hal_pinmux_set_function(HAL_GPIO_30, HAL_GPIO_30_SPI_MISO_M_CM4);
hal_pinmux_set_function(HAL_GPIO_31, HAL_GPIO_31_SPI_SCK_M_CM4);
hal_pinmux_set_function(HAL_GPIO_32, HAL_GPIO_32_SPI_CS_0_S_CM4);
//spi初始化参数
spi_config.bit_order = HAL_SPI_MASTER_MSB_FIRST;
spi_config.slave_port = HAL_SPI_MASTER_SLAVE_0;
spi_config.clock_frequency = clock_frequency;
spi_config.phase = HAL_SPI_MASTER_CLOCK_PHASE0;
spi_config.polarity = HAL_SPI_MASTER_CLOCK_POLARITY0;
//缓存区属性赋值
hal_spi_master_send_and_receive_config_t spi_send_and_receive_config;
spi_send_and_receive_config.receive_buffer = &jieshou_buffer;
spi_send_and_receive_config.send_data = &fasong_data;
spi_send_and_receive_config.send_length = fasong_length;
spi_send_and_receive_config.receive_length = jieshou_length;
if (HAL_SPI_MASTER_STATUS_OK != hal_spi_master_init(HAL_SPI_MASTER_0, &spi_config)) {
        log_hal_info("hal_spi_master_init fail\n");
         return;
         //此功能在FIFO模式下同时发送和接收数据。
          //此功能在传输完成前不会返回。
          //用户应该判断在发送命令期间接收的数据是否有效,并且此信息可以从SPI器件的数据手册获得。
           ret = hal_spi_master_send_and_receive_polling(HAL_SPI_MASTER_0, &spi_send_and_receive_config);//轮询模式同时发送和接收数据
          if (HAL_SPI_MASTER_STATUS_ERROR== ret) {
                  log_hal_info("spi master send and receive means the byte_order parameter is not configured rightly for the FIFO mode;\n");//表示byte_order参数未正确配置为FIFO模式;
          else if (HAL_SPI_MASTER_STATUS_ERROR_BUSY== ret) {
                  log_hal_info("spi master send and receive means this port of SPI master is busy and not available for use\n");//表示SPI主机的此端口正忙,不可使用;
          else if (HAL_SPI_MASTER_STATUS_ERROR_PORT== ret) {
                  log_hal_info("spi master send and receive means master_port parameter is an invalid port number\n");//表示master_port参数是无效的端口号;,不可使用;
           else if (HAL_SPI_MASTER_STATUS_INVALID_PARAMETER== ret) {
                  log_hal_info("spi master send and receive means an invalid parameter in spi_send_and_receive_config is given\n");//表示spi_send_and_receive_config中的无效参数;
           else{
              log_hal_info("spi master send and receive means this function return successfully\n");//表示此函数成功返回。
          ret=hal_spi_master_deinit(HAL_SPI_MASTER_0);
          if (HAL_SPI_MASTER_STATUS_ERROR_PORT==ret ) {
  log_hal_info("spi master deinit means master_port parameter is an invalid port number\n");//表示master_port参数是无效的端口号;
          else{
  log_hal_info("spi master deinit means this function return successfully. \n");//表示此函数成功返回。
  return;
spi.h
#ifndef _SPI_H_
#define _SPI_H_
#include "hal.h"
#include "top.h"
#include "spi.h"
#include "CMSIS.h"
extern uint32_t fasong_length;
extern uint8_t  jieshou_buffer;
extern uint32_t jieshou_length;
extern uint8_t  fasong_data;
#ifdef __cplusplus
extern "C" {
  #endif
void spi_send_and_receive();
#ifdef __cplusplus
#endif
#endif /* __SPI433_H_ */
标签:无线
实习生
发表于 2017-1-3 11:47:10
你好,,我最近在调试这个MT7687的SPI,,,,,发现,在bit0的那一个bit上,缺少前半个CLK的输出。导致我的从设备通信有误。我用的SPI MODE0。。如图,所示。。。。不知道你有没有遇到这个。。。。
回复
点赞 举报
实习生
发表于 2017-1-18 10:24:14
加我QQ帮你解答 386395277
回复
点赞 举报
145个成员聚集在这个小组
加入小组
创建小组步骤
站长推荐 上一条 /7 下一条
推荐专区
技术干货集中营
专家问答
用户帮助┃咨询与建议┃版主议事
工程师杂谈
工程师创意
工程师职场
论坛电子赛事
社区活动专版
发烧友活动
嵌入式论坛
ARM技术论坛
Android论坛
Linux论坛
单片机/MCU论坛
FPGA|CPLD|ASIC论坛
DSP论坛
嵌入式系统论坛
电源技术论坛
电源技术论坛
无线充电技术
硬件设计论坛
PCB设计论坛
电路设计论坛
电子元器件论坛
控制|传感
总线技术|接口技术
测试测量论坛
LabVIEW论坛
Matlab论坛
测试测量技术专区
仪器仪表技术专区
EDA设计论坛
multisim论坛
PADS技术论坛
Protel|AD|DXP论坛
Allegro论坛
proteus论坛|仿真论坛
EasyEDA-中国人自已的EDA工具
Orcad论坛
综合技术与应用
电机控制
智能电网
光电及显示
参考设计中心
汽车电子技术论坛
医疗电子论坛
开源硬件
无线通信论坛
无线通信技术专区
天线|RF射频|微波|雷达技术
IC设计论坛
芯片测试与失效分析
Mixed Signal/SOC[数模混合芯片设计]
Analog/RF IC设计
设计与制造封装测试
厂商专区
TI论坛
TI Deyisupport社区
检测技术与质量
电磁兼容(EMC)设计与整改
安规知识论坛
检测与认证
消费电子论坛
手机技术论坛
平板电脑/mid论坛
音视/视频/机顶盒论坛
电子论坛综合区
聚丰众筹官方社区
新人报道区
聚丰供应链
论坛服务区
供求信息发布
供需广告
招聘┃求职发布区
电子展览展会专区
